2.3.2-97-g788a030c
drivers
AltSoftSerial
config
AltSoftSerial_Timers.h
/* An Alternative Software Serial Library
* http://www.pjrc.com/teensy/td_libs_AltSoftSerial.html
* Copyright (c) 2014 PJRC.COM, LLC, Paul Stoffregen,
[email protected]
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
* THE SOFTWARE.
#if defined(ALTSS_USE_TIMER1)
#define CONFIG_TIMER_NOPRESCALE() (TIMSK1 = 0, TCCR1A = 0, TCCR1B = (1<<ICNC1) | (1<<CS10))
#define CONFIG_TIMER_PRESCALE_8() (TIMSK1 = 0, TCCR1A = 0, TCCR1B = (1<<ICNC1) | (1<<CS11))
#define CONFIG_TIMER_PRESCALE_256() (TIMSK1 = 0, TCCR1A = 0, TCCR1B = (1<<ICNC1) | (1<<CS12))
#define CONFIG_MATCH_NORMAL() (TCCR1A = TCCR1A & ~((1<<COM1A1) | (1<<COM1A0)))
#define CONFIG_MATCH_TOGGLE() (TCCR1A = (TCCR1A & ~(1<<COM1A1)) | (1<<COM1A0))
#define CONFIG_MATCH_CLEAR() (TCCR1A = (TCCR1A | (1<<COM1A1)) & ~(1<<COM1A0))
#define CONFIG_MATCH_SET() (TCCR1A = TCCR1A | ((1<<COM1A1) | (1<<COM1A0)))
#define CONFIG_CAPTURE_FALLING_EDGE() (TCCR1B &= ~(1<<ICES1))
#define CONFIG_CAPTURE_RISING_EDGE() (TCCR1B |= (1<<ICES1))
#define ENABLE_INT_INPUT_CAPTURE() (TIFR1 = (1<<ICF1), TIMSK1 = (1<<ICIE1))
#define ENABLE_INT_COMPARE_A() (TIFR1 = (1<<OCF1A), TIMSK1 |= (1<<OCIE1A))
#define ENABLE_INT_COMPARE_B() (TIFR1 = (1<<OCF1B), TIMSK1 |= (1<<OCIE1B))
#define DISABLE_INT_INPUT_CAPTURE() (TIMSK1 &= ~(1<<ICIE1))
#define DISABLE_INT_COMPARE_A() (TIMSK1 &= ~(1<<OCIE1A))
#define DISABLE_INT_COMPARE_B() (TIMSK1 &= ~(1<<OCIE1B))
#define GET_TIMER_COUNT() (TCNT1)
#define GET_INPUT_CAPTURE() (ICR1)
#define GET_COMPARE_A() (OCR1A)
#define GET_COMPARE_B() (OCR1B)
#define SET_COMPARE_A(val) (OCR1A = (val))
#define SET_COMPARE_B(val) (OCR1B = (val))
#define CAPTURE_INTERRUPT TIMER1_CAPT_vect
#define COMPARE_A_INTERRUPT TIMER1_COMPA_vect
#define COMPARE_B_INTERRUPT TIMER1_COMPB_vect
#elif defined(ALTSS_USE_TIMER3)
#define CONFIG_TIMER_NOPRESCALE() (TIMSK3 = 0, TCCR3A = 0, TCCR3B = (1<<ICNC3) | (1<<CS30))
#define CONFIG_TIMER_PRESCALE_8() (TIMSK3 = 0, TCCR3A = 0, TCCR3B = (1<<ICNC3) | (1<<CS31))
#define CONFIG_TIMER_PRESCALE_256() (TIMSK3 = 0, TCCR3A = 0, TCCR3B = (1<<ICNC3) | (1<<CS32))
#define CONFIG_MATCH_NORMAL() (TCCR3A = TCCR3A & ~((1<<COM3A1) | (1<<COM3A0)))
#define CONFIG_MATCH_TOGGLE() (TCCR3A = (TCCR3A & ~(1<<COM3A1)) | (1<<COM3A0))
#define CONFIG_MATCH_CLEAR() (TCCR3A = (TCCR3A | (1<<COM3A1)) & ~(1<<COM3A0))
#define CONFIG_MATCH_SET() (TCCR3A = TCCR3A | ((1<<COM3A1) | (1<<COM3A0)))
#define CONFIG_CAPTURE_FALLING_EDGE() (TCCR3B &= ~(1<<ICES3))
#define CONFIG_CAPTURE_RISING_EDGE() (TCCR3B |= (1<<ICES3))
#define ENABLE_INT_INPUT_CAPTURE() (TIFR3 = (1<<ICF3), TIMSK3 = (1<<ICIE3))
#define ENABLE_INT_COMPARE_A() (TIFR3 = (1<<OCF3A), TIMSK3 |= (1<<OCIE3A))
#define ENABLE_INT_COMPARE_B() (TIFR3 = (1<<OCF3B), TIMSK3 |= (1<<OCIE3B))
#define DISABLE_INT_INPUT_CAPTURE() (TIMSK3 &= ~(1<<ICIE3))
#define DISABLE_INT_COMPARE_A() (TIMSK3 &= ~(1<<OCIE3A))
#define DISABLE_INT_COMPARE_B() (TIMSK3 &= ~(1<<OCIE3B))
#define GET_TIMER_COUNT() (TCNT3)
#define GET_INPUT_CAPTURE() (ICR3)
#define GET_COMPARE_A() (OCR3A)
#define GET_COMPARE_B() (OCR3B)
#define SET_COMPARE_A(val) (OCR3A = (val))
#define SET_COMPARE_B(val) (OCR3B = (val))
#define CAPTURE_INTERRUPT TIMER3_CAPT_vect
#define COMPARE_A_INTERRUPT TIMER3_COMPA_vect
#define COMPARE_B_INTERRUPT TIMER3_COMPB_vect
#elif defined(ALTSS_USE_TIMER4)
#define CONFIG_TIMER_NOPRESCALE() (TIMSK4 = 0, TCCR4A = 0, TCCR4B = (1<<ICNC4) | (1<<CS40))
#define CONFIG_TIMER_PRESCALE_8() (TIMSK4 = 0, TCCR4A = 0, TCCR4B = (1<<ICNC4) | (1<<CS41))
#define CONFIG_TIMER_PRESCALE_256() (TIMSK4 = 0, TCCR4A = 0, TCCR4B = (1<<ICNC4) | (1<<CS42))
#define CONFIG_MATCH_NORMAL() (TCCR4A = TCCR4A & ~((1<<COM4A1) | (1<<COM4A0)))
#define CONFIG_MATCH_TOGGLE() (TCCR4A = (TCCR4A & ~(1<<COM4A1)) | (1<<COM4A0))
#define CONFIG_MATCH_CLEAR() (TCCR4A = (TCCR4A | (1<<COM4A1)) & ~(1<<COM4A0))
#define CONFIG_MATCH_SET() (TCCR4A = TCCR4A | ((1<<COM4A1) | (1<<COM4A0)))
#define CONFIG_CAPTURE_FALLING_EDGE() (TCCR4B &= ~(1<<ICES4))
#define CONFIG_CAPTURE_RISING_EDGE() (TCCR4B |= (1<<ICES4))
#define ENABLE_INT_INPUT_CAPTURE() (TIFR4 = (1<<ICF4), TIMSK4 = (1<<ICIE4))
#define ENABLE_INT_COMPARE_A() (TIFR4 = (1<<OCF4A), TIMSK4 |= (1<<OCIE4A))
#define ENABLE_INT_COMPARE_B() (TIFR4 = (1<<OCF4B), TIMSK4 |= (1<<OCIE4B))
#define DISABLE_INT_INPUT_CAPTURE() (TIMSK4 &= ~(1<<ICIE4))
#define DISABLE_INT_COMPARE_A() (TIMSK4 &= ~(1<<OCIE4A))
#define DISABLE_INT_COMPARE_B() (TIMSK4 &= ~(1<<OCIE4B))
#define GET_TIMER_COUNT() (TCNT4)
#define GET_INPUT_CAPTURE() (ICR4)
#define GET_COMPARE_A() (OCR4A)
#define GET_COMPARE_B() (OCR4B)
#define SET_COMPARE_A(val) (OCR4A = (val))
#define SET_COMPARE_B(val) (OCR4B = (val))
#define CAPTURE_INTERRUPT TIMER4_CAPT_vect
#define COMPARE_A_INTERRUPT TIMER4_COMPA_vect
#define COMPARE_B_INTERRUPT TIMER4_COMPB_vect
#elif defined(ALTSS_USE_TIMER5)
#define CONFIG_TIMER_NOPRESCALE() (TIMSK5 = 0, TCCR5A = 0, TCCR5B = (1<<ICNC5) | (1<<CS50))
#define CONFIG_TIMER_PRESCALE_8() (TIMSK5 = 0, TCCR5A = 0, TCCR5B = (1<<ICNC5) | (1<<CS51))
#define CONFIG_TIMER_PRESCALE_256() (TIMSK5 = 0, TCCR5A = 0, TCCR5B = (1<<ICNC5) | (1<<CS52))
#define CONFIG_MATCH_NORMAL() (TCCR5A = TCCR5A & ~((1<<COM5A1) | (1<<COM5A0)))
#define CONFIG_MATCH_TOGGLE() (TCCR5A = (TCCR5A & ~(1<<COM5A1)) | (1<<COM5A0))
#define CONFIG_MATCH_CLEAR() (TCCR5A = (TCCR5A | (1<<COM5A1)) & ~(1<<COM5A0))
#define CONFIG_MATCH_SET() (TCCR5A = TCCR5A | ((1<<COM5A1) | (1<<COM5A0)))
#define CONFIG_CAPTURE_FALLING_EDGE() (TCCR5B &= ~(1<<ICES5))
#define CONFIG_CAPTURE_RISING_EDGE() (TCCR5B |= (1<<ICES5))
#define ENABLE_INT_INPUT_CAPTURE() (TIFR5 = (1<<ICF5), TIMSK5 = (1<<ICIE5))
#define ENABLE_INT_COMPARE_A() (TIFR5 = (1<<OCF5A), TIMSK5 |= (1<<OCIE5A))
#define ENABLE_INT_COMPARE_B() (TIFR5 = (1<<OCF5B), TIMSK5 |= (1<<OCIE5B))
#define DISABLE_INT_INPUT_CAPTURE() (TIMSK5 &= ~(1<<ICIE5))
#define DISABLE_INT_COMPARE_A() (TIMSK5 &= ~(1<<OCIE5A))
#define DISABLE_INT_COMPARE_B() (TIMSK5 &= ~(1<<OCIE5B))
#define GET_TIMER_COUNT() (TCNT5)
#define GET_INPUT_CAPTURE() (ICR5)
123
#define GET_COMPARE_A() (OCR5A)
#define GET_COMPARE_B() (OCR5B)
#define SET_COMPARE_A(val) (OCR5A = (val))
126
#define SET_COMPARE_B(val) (OCR5B = (val))
#define CAPTURE_INTERRUPT TIMER5_CAPT_vect
128
#define COMPARE_A_INTERRUPT TIMER5_COMPA_vect
#define COMPARE_B_INTERRUPT TIMER5_COMPB_vect
131
#elif defined(ALTSS_USE_FTM0)
133
// CH5 = input capture (input, pin 20)
134
// CH6 = compare a (output, pin 21)
// CH0 = compare b (input timeout)
#define CONFIG_TIMER_NOPRESCALE() FTM0_SC = 0; FTM0_CNT = 0; FTM0_MOD = 0xFFFF; \
FTM0_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0); \
138
digitalWriteFast(21, HIGH); \
139
NVIC_SET_PRIORITY(IRQ_FTM0, 48); \
140
FTM0_C0SC = 0x18; \
141
NVIC_ENABLE_IRQ(IRQ_FTM0);
#define CONFIG_TIMER_PRESCALE_8() FTM0_SC = 0; FTM0_CNT = 0; FTM0_MOD = 0xFFFF; \
143
FTM0_SC = FTM_SC_CLKS(1) | FTM_SC_PS(3); \
144
145
146
FTM0_C0SC = 0x18; \
147
148
#define CONFIG_TIMER_PRESCALE_128() FTM0_SC = 0; FTM0_CNT = 0; FTM0_MOD = 0xFFFF; \
149
FTM0_SC = FTM_SC_CLKS(1) | FTM_SC_PS(7); \
150
151
152
FTM0_C0SC = 0x18; \
154
#define CONFIG_MATCH_NORMAL() (FTM0_C6SC = 0)
155
#define CONFIG_MATCH_TOGGLE() (FTM0_C6SC = (FTM0_C6SC & 0xC3) | 0x14)
156
#define CONFIG_MATCH_CLEAR() (FTM0_C6SC = (FTM0_C6SC & 0xC3) | 0x18)
157
#define CONFIG_MATCH_SET() (FTM0_C6SC = (FTM0_C6SC & 0xC3) | 0x1C)
158
#define CONFIG_CAPTURE_FALLING_EDGE() (FTM0_C5SC = (FTM0_C5SC & 0xC3) | 0x08)
159
#define CONFIG_CAPTURE_RISING_EDGE() (FTM0_C5SC = (FTM0_C5SC & 0xC3) | 0x04)
160
#define ENABLE_INT_INPUT_CAPTURE() FTM0_C5SC = 0x48; \
161
CORE_PIN20_CONFIG = PORT_PCR_MUX(4)|PORT_PCR_PE|PORT_PCR_PS
162
#define ENABLE_INT_COMPARE_A() FTM0_C6SC |= 0x40; \
163
CORE_PIN21_CONFIG = PORT_PCR_MUX(4)|PORT_PCR_DSE|PORT_PCR_SRE
164
#define ENABLE_INT_COMPARE_B() (FTM0_C0SC = 0x58)
165
#define DISABLE_INT_INPUT_CAPTURE() FTM0_C5SC &= ~0x40; \
166
CORE_PIN20_CONFIG = PORT_PCR_MUX(1)|PORT_PCR_PE|PORT_PCR_PS
167
#define DISABLE_INT_COMPARE_A() FTM0_C6SC &= ~0x40; \
168
CORE_PIN21_CONFIG = PORT_PCR_MUX(1)|PORT_PCR_DSE|PORT_PCR_SRE; \
169
170
#define DISABLE_INT_COMPARE_B() (FTM0_C0SC &= ~0x40)
171
#define GET_TIMER_COUNT() (FTM0_CNT)
172
#define GET_INPUT_CAPTURE() (FTM0_C5V)
173
#define GET_COMPARE_A() (FTM0_C6V)
174
#define GET_COMPARE_B() (FTM0_C0V)
175
#define SET_COMPARE_A(val) (FTM0_C6V = val)
176
#define SET_COMPARE_B(val) if (FTM0_C0SC & FTM_CSC_CHF) FTM0_C0SC = 0x18; \
177
do { FTM0_C0V = (val); } while (FTM0_C0V != (val));
178
#define CAPTURE_INTERRUPT altss_capture_interrupt
179
#define COMPARE_A_INTERRUPT altss_compare_a_interrupt
180
#define COMPARE_B_INTERRUPT altss_compare_b_interrupt
#ifdef ISR
182
#undef ISR
183
#define ISR(f) static void f (void)
185
186
187
