2.3.2-96-g79dfe0a1
hal
transport
PJON
driver
strategies
AnalogSampling
Timing.h
/* PJON AnalogSampling strategy Transmission Timing table
Copyright 2018, Giovanni Blu Mitolo All rights reserved.
__________________________________________________________
| MODE 1 | Transmission speed 1024Bb - 128B/s |
| ADC prescale 128 | |
| MODE 2 | Transmission speed 1361Bb - 170B/s |
| MODE 3 | Transmission speed 3773Bb - 471B/s |
| ADC prescale 32 | |
| MODE 4 | Transmission speed 5547Bb - 639B/s |
| ADC prescale 16 | |
| MODE 5 | Transmission speed 12658Bb - 1582B/s |
| ADC prescale 8 | Caution, ADC clocked faster than |
| | manifacturer raccomends as maximum |
| | ADC sample rate (prescale 16) |
|___________________|______________________________________|
All benchmarks are obtained with NetworkAnalysis and SpeedTest examples. */
#pragma once
#if defined(__AVR_ATmega88__) || defined(__AVR_ATmega168__) || \
defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__)
#if AS_MODE == 1
#if F_CPU == 16000000L
#define AS_BIT_WIDTH 750
#define AS_BIT_SPACER 1050
#define AS_READ_DELAY 0
#elif AS_MODE == 2
#define AS_BIT_WIDTH 572
#define AS_BIT_SPACER 728
#elif AS_MODE == 3
#ifndef AS_PRESCALE
#define AS_PRESCALE 32
#define AS_BIT_WIDTH 188
#define AS_BIT_SPACER 428
#elif AS_MODE == 4
#ifndef AS_PRESCALE
#define AS_PRESCALE 16
#define AS_BIT_WIDTH 128
#define AS_BIT_SPACER 290
#elif AS_MODE == 5
#ifndef AS_PRESCALE
#define AS_PRESCALE 8
#define AS_BIT_WIDTH 56
#define AS_BIT_SPACER 128
#define AS_READ_DELAY 16
/* ATmega1280/2560 - Arduino Mega/Mega-nano ------------------------------- */
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#if AS_MODE == 1
/* Standard timing is applied below */
#elif AS_MODE == 2
#elif AS_MODE == 3
#ifndef AS_PRESCALE
#elif AS_MODE == 4
#ifndef AS_PRESCALE
#elif AS_MODE == 5
#ifndef AS_PRESCALE
/* TODO - define dedicated timing */
/* ATmega16/32U4 - Arduino Leonardo/Micro --------------------------------- */
#if defined(__AVR_ATmega16U4__) || defined(__AVR_ATmega32U4__)
#if AS_MODE == 1
/* NodeMCU, generic ESP8266 ----------------------------------------------- */
#if defined(ESP8266)
#if AS_MODE == 1
#if F_CPU == 80000000L
/* Fallback to standard timing if not previously defined: */
123
#if AS_MODE == 1
#ifndef AS_BIT_WIDTH
126
#ifndef AS_BIT_SPACER
128
#ifndef AS_READ_DELAY
131
#elif AS_MODE == 2
134
138
139
141
#elif AS_MODE == 3
144
145
146
148
149
151
152
#elif AS_MODE == 4
154
155
156
158
159
161
162
#elif AS_MODE == 5
164
165
166
168
169
171
172
175
/* Synchronous acknowledgement response timeout. (15 milliseconds default).
176
If (latency + CRC computation) > AS_RESPONSE_TIMEOUT synchronous
177
acknowledgement reliability could be affected or disrupted higher
178
AS_RESPONSE_TIMEOUT if necessary. */
179
180
#ifndef AS_RESPONSE_TIMEOUT
#define AS_RESPONSE_TIMEOUT 15000
182
184
/* Maximum initial delay in milliseconds: */
185
186
#ifndef AS_INITIAL_DELAY
187
#define AS_INITIAL_DELAY 1000
188
190
/* Maximum delay in case of collision in microseconds: */
191
192
#ifndef AS_COLLISION_DELAY
193
#define AS_COLLISION_DELAY 64
194
196
/* Maximum transmission attempts */
197
198
#ifndef AS_MAX_ATTEMPTS
199
#define AS_MAX_ATTEMPTS 10
200
202
/* Back-off exponential degree */
203
204
#ifndef AS_BACK_OFF_DEGREE
205
#define AS_BACK_OFF_DEGREE 5
206
208
/* Threshold decrease interval (10 millis) */
209
210
#ifndef AS_THRESHOLD_DECREASE_INTERVAL
211
#define AS_THRESHOLD_DECREASE_INTERVAL 10000
212
