Arduino.h
18  */
20 #ifndef Arduino_h
21 #define Arduino_h
23 #include <stdlib.h>
24 #include <stdint.h>
25 #include <stdbool.h>
26 #include <stddef.h>
27 #include <stdarg.h>
28 #include <stdio.h>
29 #include <string.h>
30 #include <math.h>
31 #include <string>
32 #include <algorithm>
33 #include "stdlib_noniso.h"
35 #ifdef LINUX_ARCH_RASPBERRYPI
36 #include "RPi.h"
37 #define pinMode(pin, direction) RPi.pinMode(pin, direction)
38 #define digitalWrite(pin, value) RPi.digitalWrite(pin, value)
39 #define digitalRead(pin) RPi.digitalRead(pin)
40 #define digitalPinToInterrupt(pin) RPi.digitalPinToInterrupt(pin)
41 #else
42 #include "GPIO.h"
43 #define pinMode(pin, direction) GPIO.pinMode(pin, direction)
44 #define digitalWrite(pin, value) GPIO.digitalWrite(pin, value)
45 #define digitalRead(pin) GPIO.digitalRead(pin)
46 #define digitalPinToInterrupt(pin) GPIO.digitalPinToInterrupt(pin)
47 #endif
49 #include "interrupt.h"
51 #undef PSTR
52 #define PSTR(x) (x)
53 #undef F
54 #define F(x) (x)
55 #define PROGMEM __attribute__(( section(".progmem.data") ))
56 #define vsnprintf_P(...) vsnprintf( __VA_ARGS__ )
57 #define snprintf_P(...) snprintf( __VA_ARGS__ )
58 #define memcpy_P memcpy
59 #define pgm_read_byte(p) (*(p))
60 #define pgm_read_dword(p) (*(p))
61 #define pgm_read_byte_near(p) (*(p))
63 #define PI 3.1415926535897932384626433832795
64 #define HALF_PI 1.5707963267948966192313216916398
65 #define TWO_PI 6.283185307179586476925286766559
66 #define DEG_TO_RAD 0.017453292519943295769236907684886
67 #define RAD_TO_DEG 57.295779513082320876798154814105
68 #define EULER 2.718281828459045235360287471352
70 #define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
71 #define radians(deg) ((deg)*DEG_TO_RAD)
72 #define degrees(rad) ((rad)*RAD_TO_DEG)
73 #define sq(x) ((x)*(x))
74 #define round(x) ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
76 #define lowByte(w) ((uint8_t) ((w) & 0xff))
77 #define highByte(w) ((uint8_t) ((w) >> 8))
79 #define bitRead(value, bit) (((value) >> (bit)) & 0x01)
80 #define bitSet(value, bit) ((value) |= (1UL << (bit)))
81 #define bitClear(value, bit) ((value) &= ~(1UL << (bit)))
82 #define bitWrite(value, bit, bitvalue) (bitvalue ? bitSet(value, bit) : bitClear(value, bit))
84 #define bit(b) (1UL << (b))
86 #define GET_MACRO(_0, _1, _2, NAME, ...) NAME
87 #define random(...) GET_MACRO(_0, ##__VA_ARGS__, randMinMax, randMax, rand)(__VA_ARGS__)
89 #ifndef delay
90 #define delay _delay_milliseconds
91 #endif
93 #ifndef delayMicroseconds
94 #define delayMicroseconds _delay_microseconds
95 #endif
97 using std::string;
98 using std::min;
99 using std::max;
100 using std::abs;
102 typedef uint8_t byte;
103 typedef string String;
104 typedef char __FlashStringHelper;
106 void yield(void);
107 unsigned long millis(void);
108 unsigned long micros(void);
109 void _delay_milliseconds(unsigned int millis);
110 void _delay_microseconds(unsigned int micro);
111 void randomSeed(unsigned long seed);
112 long randMax(long howbig);
113 long randMinMax(long howsmall, long howbig);
115 #endif
