PJON_RPI_Interface.h
2 /* PJON RaspeberryPi Interface
3  _____________________________________________________________________________
5  Copyright 2018 Giovanni Blu Mitolo [email protected]
7  Licensed under the Apache License, Version 2.0 (the "License");
8  you may not use this file except in compliance with the License.
9  You may obtain a copy of the License at
11  http://www.apache.org/licenses/LICENSE-2.0
13  Unless required by applicable law or agreed to in writing, software
14  distributed under the License is distributed on an "AS IS" BASIS,
15  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
16  See the License for the specific language governing permissions and
17  limitations under the License. */
19 #pragma once
21 #if defined(RPI)
22 #include <cinttypes>
23 #include <cstdlib>
24 #include <cstring>
25 #include <wiringPi.h>
26 #include <wiringSerial.h>
28 /* Generic constants ---------------------------------------------------- */
30 #ifndef A0
31 #define A0 0
32 #endif
34 #ifndef LED_BUILTIN
35 #define LED_BUILTIN -1
36 #endif
38 /* Fallback to WiringPi core functions ---------------------------------- */
40 #if !defined(PJON_ANALOG_READ)
41 #define PJON_ANALOG_READ(P) analogRead(P)
42 #endif
44 #if !defined(PJON_IO_WRITE)
45 #define PJON_IO_WRITE digitalWrite
46 #endif
48 #if !defined(PJON_IO_READ)
49 #define PJON_IO_READ digitalRead
50 #endif
52 #if !defined(PJON_IO_MODE)
53 #define PJON_IO_MODE pinMode
54 #endif
56 #if !defined(PJON_IO_PULL_DOWN)
57 #define PJON_IO_PULL_DOWN(P) { \
58  PJON_IO_MODE(P, INPUT); \
59  pullUpDnControl(P, PUD_DOWN); \
60  }
61 #endif
63 /* Random ----------------------------------------------------------------- */
65 #ifndef PJON_RANDOM
66 #define PJON_RANDOM(randMax) (int)((1.0 + randMax) * rand() / ( RAND_MAX + 1.0 ) )
67 /* Scale rand()'s return value against RAND_MAX using doubles instead of
68  a pure modulus to have a more distributed result */
69 #endif
71 #ifndef PJON_RANDOM_SEED
72 #define PJON_RANDOM_SEED srand
73 #endif
75 /* Serial ----------------------------------------------------------------- */
77 #ifndef PJON_SERIAL_TYPE
78 #define PJON_SERIAL_TYPE int16_t
79 #endif
81 #ifndef PJON_SERIAL_AVAILABLE
82 #define PJON_SERIAL_AVAILABLE(S) serialDataAvail(S)
83 #endif
85 #ifndef PJON_SERIAL_WRITE
86 #define PJON_SERIAL_WRITE(S, C) write(S, &C, 1)
87 #endif
89 #ifndef PJON_SERIAL_READ
90 #define PJON_SERIAL_READ(S) serialGetchar(S)
91 #endif
93 #ifndef PJON_SERIAL_FLUSH
94 #define PJON_SERIAL_FLUSH(S) serialFlush(S)
95 #endif
97 /* Timing offset in microseconds between expected and real serial
98  byte transmission: */
100 #ifndef TS_FLUSH_OFFSET
101 #define TS_FLUSH_OFFSET 152
102 #endif
104 /* Timing ----------------------------------------------------------------- */
106 #ifndef PJON_DELAY
107 #define PJON_DELAY delay
108 #endif
110 #ifndef PJON_DELAY_MICROSECONDS
111 #define PJON_DELAY_MICROSECONDS delayMicroseconds
112 #endif
114 #ifndef PJON_MICROS
115 #define PJON_MICROS micros
116 #endif
118 #ifndef PJON_MILLIS
119 #define PJON_MILLIS millis
120 #endif
121 #endif
