#include <stdint.h>
Classes | |
union | sx126x_rxBufferStatus_t |
data type to receive RX buffer status More... | |
union | sx126x_packetStatus_t |
data type to receive packet status More... | |
union | sx126x_sleepParams_t |
sx126x sleep parameters More... | |
union | sx126x_cadParameters_t |
CAD parameters type. More... | |
struct | sx126x_modulationParams_t |
Typedef for the SX126x modulation settings. More... | |
struct | sx126x_paSettings_t |
PA settings parameters type. More... | |
struct | sx126x_txSettings_t |
Transmission settings parameters type. More... | |
union | sx126x_controlFlags_t |
Control flag data type. More... | |
struct | __attribute__ |
FW config structure, stored in eeprom. More... | |
struct | sx126x_internal_t |
SX126x internal variables. More... | |
#define | SX126x_SPI hwSPI |
default SPI | |
#define | DEFAULT_SX126x_IRQ_PIN (2) |
DEFAULT_SX126x_IRQ_PIN. | |
#define | DEFAULT_SX126x_CS_PIN (SS) |
DEFAULT_SX126x_CS_PIN. | |
#define | SX126x_XTAL_FREQ ( double )32000000 |
XTAL frequency. | |
#define | SX126x_FREQ_DIV ( double )pow( 2.0, 25.0 ) |
Frequency divider. | |
#define | SX126x_FREQ_STEP ( double )( SX126x_XTAL_FREQ / SX126x_FREQ_DIV ) |
Frequency step. | |
#define | SX126x_BW125CR45SF128 SX126x_BW_125KHZ | SX126x_CODING_RATE_4_5, SX126x_SPREADING_FACTOR_128CPS | SX126x_RX_PAYLOAD_CRC_ON, SX126x_AGC_AUTO_ON |
0x72,0x74,0x04 | |
#define | SX126x_BW500CR45SF128 SX126x_BW_500KHZ | SX126x_CODING_RATE_4_5, SX126x_SPREADING_FACTOR_128CPS | SX126x_RX_PAYLOAD_CRC_ON, SX126x_AGC_AUTO_ON |
0x92,0x74,0x04 | |
#define | SX126x_BW31_25CR48SF512 SX126x_BW_31_25KHZ | SX126x_CODING_RATE_4_8, SX126x_SPREADING_FACTOR_512CPS | SX126x_RX_PAYLOAD_CRC_ON, SX126x_AGC_AUTO_ON |
0x48,0x94,0x04 | |
#define | SX126x_BW125CR48SF4096 SX126x_BW_125KHZ | SX126x_CODING_RATE_4_8, SX126x_SPREADING_FACTOR_4096CPS | SX126x_RX_PAYLOAD_CRC_ON, SX126x_AGC_AUTO_ON | SX126x_LOW_DATA_RATE_OPTIMIZE |
0x78,0xc4,0x0C | |
#define | SX126x_BROADCAST_ADDRESS (255u) |
Broadcasting address. | |
#define | SX126x_ATC_TARGET_RANGE_DBM (2u) |
ATC target range +/- dBm. | |
#define | SX126x_RSSI_OFFSET (137u) |
RSSI offset. | |
#define | SX126x_TARGET_RSSI (-70) |
RSSI target. | |
#define | SX126x_PROMISCUOUS (false) |
SX126x promiscuous mode. | |
#define | SX126x_PACKET_HEADER_VERSION (1u) |
SX126x packet header version. | |
#define | SX126x_MIN_PACKET_HEADER_VERSION (1u) |
Minimal SX126x packet header version. | |
#define | SX126x_RETRY_TIMEOUT_MS (500ul) |
Timeout for ACK, adjustments needed if modem configuration changed (air time different) | |
#define | MY_SX126x_TX_TIMEOUT_MS (5*1000ul) |
TX timeout. | |
#define | MY_SX126x_TX_POWER_DBM (13u) |
Set TX power level, default 13dBm (overridden if ATC mode enabled) More... | |
#define | SX126x_169MHZ (169000000ul) |
169 Mhz | |
#define | SX126x_315MHZ (315000000ul) |
315 Mhz | |
#define | SX126x_434MHZ (433920000ul) |
433.92 Mhz | |
#define | SX126x_868MHZ (868100000ul) |
868.1 Mhz | |
#define | SX126x_915MHZ (915000000ul) |
915 Mhz | |
#define | SX126x_RETRIES (5u) |
Retries in case of failed transmission. | |
#define | SX126x_MAX_PACKET_LEN (0x40u) |
This is the maximum number of bytes that can be carried by the LORA. | |
#define | SX126x_PREAMBLE_LENGTH (8u) |
Preamble length, default=8. | |
#define | SX126x_CAD_TIMEOUT_MS (2 * 1000ul) |
channel activity detection timeout | |
#define | SX126x_POWERUP_DELAY_MS 3 |
Power up time of the SX126x. | |
#define | SX126x_SLEEP_WARM_START 0x04 |
Retain configuration during sleep. | |
#define | SX126x_REG_OCP 0x08E7 |
SX126x register adresses. More... | |
#define | SX126x_REG_LORASW 0x0740 |
LoRa SyncWord. | |
#define | SX126x_HEADER_LEN sizeof(sx126x_header_t) |
Size header inside LoRa payload. | |
#define | SX126x_MAX_PAYLOAD_LEN (SX126x_MAX_PACKET_LEN - SX126x_HEADER_LEN) |
Max payload length. | |
Typedefs | |
typedef enum sx126xCommands_e | sx126x_commands_t |
Commands for the SX126x chip. | |
typedef uint16_t | sx126x_sequenceNumber_t |
Sequence number data type. | |
typedef uint8_t | sx126x_RSSI_t |
RSSI data type. | |
typedef int8_t | sx126x_SNR_t |
SNR data type. | |
typedef int8_t | sx126x_powerLevel_t |
Power level in dBm. | |
Enumerations | |
enum | sx126xCommands_e { SX126x_RESET_STATS = 0x00, SX126x_CLR_IRQSTATUS = 0x02, SX126x_CLR_ERROR = 0x07, SX126x_CFG_DIOIRQ = 0x08, SX126x_SET_LORASYMBTIMEOUT = 0xA0, SX126x_WRITE_REGISTER = 0x0D, SX126x_WRITE_BUFFER = 0x0E, SX126x_GET_STATS = 0x10, SX126x_GET_PACKETTYPE = 0x11, SX126x_GET_IRQSTATUS = 0x12, SX126x_GET_RXBUFFERSTATUS = 0x13, SX126x_GET_PACKETSTATUS = 0x14, SX126x_GET_RSSIINST = 0x15, SX126x_GET_ERROR = 0x17, SX126x_READ_REGISTER = 0x1D, SX126x_READ_BUFFER = 0x1E, SX126x_SET_STANDBY = 0x80, SX126x_SET_RX = 0x82, SX126x_SET_TX = 0x83, SX126x_SET_SLEEP = 0x84, SX126x_SET_RFFREQUENCY = 0x86, SX126x_SET_CADPARAMS = 0x88, SX126x_CALIBRATE = 0x89, SX126x_SET_PACKETTYPE = 0x8A, SX126x_SET_MODULATIONPARAMS = 0x8B, SX126x_SET_PACKETPARAMS = 0x8C, SX126x_SET_TXPARAMS = 0x8E, SX126x_SET_BUFFERBASEADDRESS = 0x8F, SX126x_SET_TXFALLBACKMODE = 0x93, SX126x_SET_RXDUTYCYCLE = 0x94, SX126x_SET_PACONFIG = 0x95, SX126x_SET_REGULATORMODE = 0x96, SX126x_SET_TCXOMODE = 0x97, SX126x_CALIBRATEIMAGE = 0x98, SX126x_SET_RFSWITCHMODE = 0x9D, SX126x_SET_STOPRXTIMERONPREAMBLE = 0x9F, SX126x_GET_STATUS = 0xC0, SX126x_SET_FS = 0xC1, SX126x_SET_CAD = 0xC5, SX126x_SET_TXCONTINUOUSWAVE = 0xD1, SX126x_SET_TXCONTINUOUSPREAMBLE = 0xD2 } |
enum | sx126x_radioStandbyModes_t { SX126x_STDBY_RC = 0x00, SX126x_STDBY_XOSC = 0x01 } |
Declares the oscillator in use while in standby mode. More... | |
enum | sx126x_radioRegulatorMode_t { SX126x_USE_LDO = 0x00, SX126x_USE_DCDC = 0x01 } |
Declares the power regulation used to power the device. More... | |
enum | sx126x_radioPacketTypes_t { SX126x_PACKET_TYPE_GFSK = 0x00, SX126x_PACKET_TYPE_LORA = 0x01, SX126x_PACKET_TYPE_NONE = 0x0F } |
Declares the possible packet type (i.e. modem) used. | |
enum | sx126x_radioModes_t { SX126x_MODE_SLEEP = 0x00, SX126x_MODE_STDBY_RC, SX126x_MODE_STDBY_XOSC, SX126x_MODE_FS, SX126x_MODE_TX, SX126x_MODE_RX, SX126x_MODE_RX_DC, SX126x_MODE_CAD } |
SX126x operation Modes. More... | |
enum | sx126x_loRaSpreadingFactors_t { LORA_SF5 = 0x05, LORA_SF6 = 0x06, LORA_SF7 = 0x07, LORA_SF8 = 0x08, LORA_SF9 = 0x09, LORA_SF10 = 0x0A, LORA_SF11 = 0x0B, LORA_SF12 = 0x0C } |
LoRa spreading factors. | |
enum | sx126x_loRaBandwidths_t { LORA_BW_500 = 6, LORA_BW_250 = 5, LORA_BW_125 = 4, LORA_BW_062 = 3, LORA_BW_041 = 10, LORA_BW_031 = 2, LORA_BW_020 = 9, LORA_BW_015 = 1, LORA_BW_010 = 8, LORA_BW_007 = 0 } |
LoRa Bandwiths. | |
enum | sx126x_loRaCodingRates_t { LORA_CR_4_5 = 0x01, LORA_CR_4_6 = 0x02, LORA_CR_4_7 = 0x03, LORA_CR_4_8 = 0x04 } |
LoRa coding rates. | |
enum | sx126x_loRaCADSymbols_t { LORA_CAD_ON_1_SYMB = 0x00, LORA_CAD_ON_2_SYMB = 0x01, LORA_CAD_ON_4_SYMB = 0x02, LORA_CAD_ON_8_SYMB = 0x03, LORA_CAD_ON_16_SYMB = 0x04 } |
LoRa CAD number of symbols. | |
enum | sx126x_cadExitModes_t { SX126x_CAD_ONLY = 0x00, SX126x_CAD_RX = 0x01 } |
CAD exit type. | |
enum | SX126x_packetTypes_t { PACKET_TYPE_GFSK = 0x00, PACKET_TYPE_LORA = 0x01, PACKET_TYPE_NONE = 0x0F } |
SX126x packet types. | |
enum | sx126x_RampTimes_t { RADIO_RAMP_10_US = 0x00, RADIO_RAMP_20_US = 0x01, RADIO_RAMP_40_US = 0x02, RADIO_RAMP_80_US = 0x03, RADIO_RAMP_200_US = 0x04, RADIO_RAMP_800_US = 0x05, RADIO_RAMP_1700_US = 0x06, RADIO_RAMP_3400_US = 0x07 } |
Ramping time for power amplifier. | |
enum | sx126x_tcxoVoltage_t { SX126x_TCXO_1V6 = 0x00, SX126x_TCXO_1V7, SX126x_TCXO_1V8, SX126x_TCXO_2V2, SX126x_TCXO_2V4, SX126x_TCXO_2V7, SX126x_TCXO_3V0, SX126x_TCXO_3V3 } |
SX126x TCXO output voltages. | |
enum | sx126x_irqMasks_t { SX126x_IRQ_NONE = 0x0000, SX126x_IRQ_TX_DONE = 0x0001, SX126x_IRQ_RX_DONE = 0x0002, SX126x_IRQ_PREAMBLE_DETECTED = 0x0004, SX126x_IRQ_SYNCWORD_VALID = 0x0008, SX126x_IRQ_HEADER_VALID = 0x0010, SX126x_IRQ_HEADER_ERROR = 0x0020, SX126x_IRQ_CRC_ERROR = 0x0040, SX126x_IRQ_CAD_DONE = 0x0080, SX126x_IRQ_CAD_ACTIVITY_DETECTED = 0x0100, SX126x_IRQ_RX_TX_TIMEOUT = 0x0200, SX126x_IRQ_ALL = 0xFFFF } |
IRQ masks. | |
