2.3.2-121-g2834d0f8
hal
transport
PJON
driver
strategies
SoftwareBitBang
Timing.h
/* PJON SoftwareBitBang strategy Transmission Timing table
Copyright 2010-2020, Giovanni Blu Mitolo All rights reserved.
Often timing in two different machines do not match, code execution
time can variate and time measurements are not perfectly equal.
Consider that durations defined below may differ from what is specified in
PJDL v5.0. This is done to accomodate machine's inner workings and
effectively produce the specified timing.
Arduino Duemilanove/UNO/Nano is used as timing master, or the machine used
to test all new supported MCUs.
Benchmarks can be executed using NetworkAnalysis and SpeedTest examples.
MODE 1: 1.97kB/s - 15808Bd
MODE 2: 2.21kB/s - 17696Bd
MODE 3: 3.10kB/s - 24844Bd
MODE 4: 3.34kB/s - 26755Bd
Use the same pin number on all connected devices to achieve maximum
timing efficiency, not all different pin combinations work nominally
because of execution timing discrepancies between physical pins. */
#pragma once
/* ATmega88/168/328 - Arduino Duemilanove, Uno, Nano, Mini, Pro, Pro mini */
#if defined(__AVR_ATmega88__) || defined(__AVR_ATmega168__) || \
defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__)
#if SWBB_MODE == 1
#if F_CPU == 16000000L
/* Working on pin: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, A0, A1 */
#define SWBB_BIT_WIDTH 40
#define SWBB_BIT_SPACER 112
#define SWBB_ACCEPTANCE 56
#define SWBB_READ_DELAY 4
#if SWBB_MODE == 2
#define SWBB_BIT_WIDTH 36
#define SWBB_BIT_SPACER 88
#if SWBB_MODE == 3
#define SWBB_BIT_WIDTH 24
#define SWBB_BIT_SPACER 66
#define SWBB_ACCEPTANCE 30
#define SWBB_READ_DELAY 8
#if SWBB_MODE == 4
#define SWBB_BIT_WIDTH 22
#define SWBB_BIT_SPACER 61
#define SWBB_READ_DELAY 7
/* ATmega328PB ------------------------------------------------------------ */
#if defined(__AVR_ATmega328PB__)
#if SWBB_MODE == 1
/* Working on pin: 10 */
#define SWBB_BIT_WIDTH 37
#define SWBB_BIT_SPACER 110
#if SWBB_MODE == 2
#define SWBB_BIT_WIDTH 33
/* ATmega16/32U4 - Arduino Leonardo/Micro --------------------------------- */
#if defined(__AVR_ATmega16U4__) || defined(__AVR_ATmega32U4__)
#if SWBB_MODE == 1
/* Working on pin: 2, 4, 8, 12
Fallback to default timing */
#if SWBB_MODE == 2
#define SWBB_READ_DELAY 12
/* ATmega1280/2560 - Arduino Mega/Mega-nano ------------------------------- */
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#if SWBB_MODE == 1
/* Working on pin: 3, 4, 7, 8, 9, 10, 12 */
#define SWBB_BIT_WIDTH 38
#define SWBB_ACCEPTANCE 62
#define SWBB_READ_DELAY 11
#if SWBB_MODE == 2
#define SWBB_BIT_WIDTH 34
123
#define SWBB_BIT_SPACER 86
#define SWBB_ACCEPTANCE 58
#define SWBB_READ_DELAY 10
126
/* ATtiny45/85 ------------------------------------------------------------ */
#if defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
131
#if SWBB_MODE == 1
133
/* Working on pin: 1, 2
134
Fallback to default */
138
139
#if SWBB_MODE == 2
143
144
145
146
147
148
149
/* ATtiny44/84/44A/84A ---------------------------------------------------- */
154
#if defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__) || \
155
defined(__AVR_ATtiny84A__) || defined(__AVR_ATtiny84A__)
156
#if SWBB_MODE == 1
157
158
/* Working on pin: 0, 1, 2, 3, 4
159
160
161
162
163
164
#if SWBB_MODE == 2
167
168
169
170
171
172
173
174
178
/* Arduino Zero ----------------------------------------------------------- */
179
#if defined(ARDUINO_SAMD_ZERO)
180
#if SWBB_MODE == 1
/* Added by Esben Soeltoft - 03/09/2016
182
Updated by Giovanni Blu Mitolo - 31/05/2019
183
Working on pin: D0, D1, D3, A0, A1 */
184
#define SWBB_BIT_WIDTH 43
185
#define SWBB_BIT_SPACER 115
186
#define SWBB_ACCEPTANCE 40
187
#define SWBB_READ_DELAY -4
188
191
/* NodeMCU, generic ESP8266 ----------------------------------------------- */
192
#if defined(ESP8266)
193
#if SWBB_MODE == 1
194
/* Added by github user 240974a - 09/03/2016
195
Added full support to MODE 1 (80 and 160MHz) - 12/06/2018 */
196
#if (F_CPU == 80000000L) || (F_CPU == 160000000L)
197
/* Working on pin: D1 or GPIO 5 */
198
#define SWBB_BIT_WIDTH 44
199
200
201
#define SWBB_READ_DELAY -6
202
206
/* Heltech WiFi LoRa ESP32, generic ESP32 --------------------------------- */
207
#if defined(ESP32)
208
#if SWBB_MODE == 1
209
/* Added full support to MODE 1 - 28/06/2018
210
Working on pin: 12 and 25 */
211
212
213
214
#define SWBB_READ_DELAY -2
215
218
/* MK20DX256 - Teensy ----------------------------------------------------- */
219
#if defined(__MK20DX256__)
220
#if SWBB_MODE == 1
221
/* Added by github user SticilFace - 25/04/2016 */
222
#if F_CPU == 96000000L
223
#define SWBB_BIT_WIDTH 46
224
225
226
#define SWBB_READ_DELAY -10
227
231
232
/* STM32F1 ---------------------------------------------------------------- */
233
/* @jcallano 09-jul-2020 tested with pin PB15, PB14, PB13, PB12, PB11, PB10,
234
PB9, PB8, PB7, PB6, PB4, PB3, PA15, PA10. 5v tolerant pins on bluepill */
235
236
#if defined(__STM32F1__)
237
#if SWBB_MODE == 1
238
#if F_CPU == 72000000L
239
240
241
#define SWBB_ACCEPTANCE 60
242
#define SWBB_READ_DELAY 3
243
#if SWBB_MODE == 2
246
247
#define SWBB_BIT_WIDTH 39
248
#define SWBB_BIT_SPACER 91
249
#define SWBB_ACCEPTANCE 47
250
251
#if SWBB_MODE == 3
254
255
#define SWBB_BIT_WIDTH 27.5
256
#define SWBB_BIT_SPACER 69.5
257
#define SWBB_ACCEPTANCE 33
258
#define SWBB_READ_DELAY -5
259
#if SWBB_MODE == 4
262
263
#define SWBB_BIT_WIDTH 25
264
#define SWBB_BIT_SPACER 59
265
#define SWBB_ACCEPTANCE 30 //
266
267
271
/* Avoid error if any previous defined ------------------------------------ */
272
#if SWBB_MODE == 1
273
#ifndef SWBB_BIT_WIDTH
274
275
#ifndef SWBB_BIT_SPACER
277
278
#ifndef SWBB_ACCEPTANCE
280
281
#ifndef SWBB_READ_DELAY
283
284
#ifndef SWBB_LATENCY
286
#define SWBB_LATENCY 13
287
#if SWBB_MODE == 2
290
291
292
294
295
297
298
300
301
303
#define SWBB_LATENCY 10
304
#if SWBB_MODE == 3
307
308
309
311
312
314
315
317
318
320
#define SWBB_LATENCY 8
321
#if SWBB_MODE == 4
324
325
326
328
329
331
332
334
335
337
#define SWBB_LATENCY 5
338
341
342
/* Frame preamble length (by default set to 1 x SWBB_BIT_SPACER)
343
Maximum allowed value is 100 or a preamble of 100 x SWBB_BIT_SPACER
344
When devices execute other tasks frames may be lost unheard. The preamble
345
can be used to avoid transmission failure. To avoid retransmissions the
346
preamble length should be slightly longer than the task's duration. */
347
348
#ifndef SWBB_PREAMBLE
349
#define SWBB_PREAMBLE 1
350
352
/* Maximum frame preamble length (by default set to 1 x SWBB_BIT_SPACER)
353
354
To have full interoperability set SWBB_MAX_PREAMBLE = 100 */
355
356
#ifndef SWBB_MAX_PREAMBLE
357
#define SWBB_MAX_PREAMBLE 1
358
360
/* Synchronous acknowledgement response offset.
361
If (latency + CRC computation) > (SWBB_RESPONSE_OFFSET * length)
362
synchronous acknowledgement reliability could be affected or disrupted
363
set a higher SWBB_RESPONSE_OFFSET if necessary. */
364
365
#ifndef SWBB_RESPONSE_OFFSET
366
#define SWBB_RESPONSE_OFFSET 20
367
369
/* Maximum initial delay in milliseconds: */
370
371
#ifndef SWBB_INITIAL_DELAY
372
#define SWBB_INITIAL_DELAY 1000
373
375
/* Maximum delay in case of collision in microseconds: */
376
377
#ifndef SWBB_COLLISION_DELAY
378
#define SWBB_COLLISION_DELAY 16
379
381
/* Maximum transmission attempts */
382
383
#ifndef SWBB_MAX_ATTEMPTS
384
#define SWBB_MAX_ATTEMPTS 20
385
387
/* Back-off exponential degree */
388
389
#ifndef SWBB_BACK_OFF_DEGREE
390
#define SWBB_BACK_OFF_DEGREE 4
391
