2.3.2-121-g2834d0f8
hal
transport
PJON
driver
strategies
ThroughSerial
Timing.h
/* ThroughSerial digital communication data link layer
used as a Strategy by the PJON framework (included in version v4.1)
Contributors:
- Fred Larsen, Development, testing and debugging
- Zbigniew Zasieczny, collision avoidance multi-drop RS485 (latency)
and SoftwareSerial compatibility
- Franketto (Arduino forum user) RS485 TX enable pin compatibility
____________________________________________________________________________
Based on ThroughSerial, developed by sticilface
copyright 2018 by Giovanni Blu Mitolo All rights reserved
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License. */
#pragma once
/* Maximum 1 second random initial delay */
#ifndef TS_INITIAL_DELAY
#define TS_INITIAL_DELAY 1000
/* Maximum 64 microseconds random delay in case of collision */
#ifndef TS_COLLISION_DELAY
#define TS_COLLISION_DELAY 64
/* Set 45 milliseconds as the maximum timeframe between transmission and
synchronous acknowledgement response. Its optimal configuration is
strictly related to the maximum time needed by receiver to receive, compute
and transmit back a response. Set TS_RESPONSE_TIME_OUT to 0 and do not use
the acknowledgement feature if the system operates in master-slave mode and
or applies the request-response scheme. */
#ifndef TS_RESPONSE_TIME_OUT
#define TS_RESPONSE_TIME_OUT 45000
/* Minum duration of channel free for use before transmission, used to avoid
disrupting an ongoing acknowledgement exchange. Set TS_TIME_IN to 0 and do
not use the acknowledgement feature if the system operates in master-slave
mode and or applies the request-response scheme. */
#ifndef TS_TIME_IN
#define TS_TIME_IN TS_RESPONSE_TIME_OUT + TS_COLLISION_DELAY
/* Set 100 microseconds as the interval between each byte read.
Depending on the latency, baud rate and computation time the
optimal TS_READ_INTERVAL value may variate.
Always set: TS_READ_INTERVAL > (byte transmission time + latency) */
#ifndef TS_READ_INTERVAL
#define TS_READ_INTERVAL 100
/* Byte reception timeout (Default 1 second) */
#ifndef TS_BYTE_TIME_OUT
#define TS_BYTE_TIME_OUT 1000000
/* Response length (the response is composed by the last TS_RESPONSE_LENGTH
bytes of the packet received). Setting TS_RESPONSE_LENGTH < 4 when using
ThroughSerial in multi-master mode reduces reliability and leads to higher
chances of detecting a false positive. */
#ifndef TS_RESPONSE_LENGTH
#define TS_RESPONSE_LENGTH 1
/* Maximum transmission attempts */
#ifndef TS_MAX_ATTEMPTS
#define TS_MAX_ATTEMPTS 20
/* Back-off exponential degree */
#ifndef TS_BACK_OFF_DEGREE
#define TS_BACK_OFF_DEGREE 4
/* Delay before enabling and disabling RS485 DE and or RE pin */
#ifndef TS_RS485_DELAY
#define TS_RS485_DELAY 1
/* Force blocking sending hack (adds a delay for each character sent). */
#ifndef TS_FLUSH_OFFSET
#define TS_FLUSH_OFFSET 152
