This is the complete list of members for PJONAny, including all inherited members.
begin() (defined in PJON< Any >) | PJON< Any > | inline |
compose_packet(PJON_Packet_Info info, uint8_t *destination, const void *source, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
config (defined in PJON< Any >) | PJON< Any > | |
data (defined in PJON< Any >) | PJON< Any > | |
device_id() const (defined in PJON< Any >) | PJON< Any > | inline |
dispatch(const PJON_Packet_Info &info, const void *packet, uint16_t length, uint32_t timing=0, uint16_t packet_index=PJON_FAIL) (defined in PJON< Any >) | PJON< Any > | inline |
fill_info(uint8_t rx_id, uint8_t header, uint16_t packet_id, uint16_t rx_port) (defined in PJON< Any >) | PJON< Any > | inline |
forward(PJON_Packet_Info info, const void *payload, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
forward_blocking(PJON_Packet_Info info, const void *payload, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
get_bus_id() const (defined in PJON< Any >) | PJON< Any > | inline |
get_packets_count(uint8_t device_id=PJON_NOT_ASSIGNED) const (defined in PJON< Any >) | PJON< Any > | inline |
include_mac(bool state) (defined in PJON< Any >) | PJON< Any > | inline |
include_sender_info(bool state) (defined in PJON< Any >) | PJON< Any > | inline |
last_packet_info (defined in PJON< Any >) | PJON< Any > | |
packet_overhead(uint8_t header=PJON_NO_HEADER) const (defined in PJON< Any >) | PJON< Any > | inline |
packets (defined in PJON< Any >) | PJON< Any > | |
parse(const uint8_t *packet, PJON_Packet_Info &packet_info) const (defined in PJON< Any >) | PJON< Any > | inline |
PJON() (defined in PJON< Any >) | PJON< Any > | inline |
PJON(uint8_t device_id) (defined in PJON< Any >) | PJON< Any > | inline |
PJON(const uint8_t *b_id, uint8_t device_id) (defined in PJON< Any >) | PJON< Any > | inline |
PJONAny(const uint8_t id=PJON_NOT_ASSIGNED) (defined in PJONAny) | PJONAny | inline |
PJONAny(StrategyLinkBase *link, const uint8_t id=PJON_NOT_ASSIGNED) (defined in PJONAny) | PJONAny | inline |
PJONAny(StrategyLinkBase *link, const uint8_t bus_id[], const uint8_t id=PJON_NOT_ASSIGNED) (defined in PJONAny) | PJONAny | inline |
receive() (defined in PJON< Any >) | PJON< Any > | inline |
receive(uint32_t duration) (defined in PJON< Any >) | PJON< Any > | inline |
remove(uint16_t index) (defined in PJON< Any >) | PJON< Any > | inline |
remove_all_packets(uint8_t device_id=0) (defined in PJON< Any >) | PJON< Any > | inline |
reply(const void *payload, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
reply_blocking(const void *payload, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
reset_packet(uint16_t id) (defined in PJON< Any >) | PJON< Any > | inline |
send(uint8_t rx_id, const void *payload, uint16_t length, uint8_t header=PJON_NO_HEADER, uint16_t packet_id=0, uint16_t rx_port=PJON_BROADCAST) (defined in PJON< Any >) | PJON< Any > | inline |
send(const PJON_Packet_Info &info, const void *payload, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
send_acknowledge() (defined in PJON< Any >) | PJON< Any > | inline |
send_packet(const uint8_t *payload, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
send_packet(uint8_t rx_id, const void *payload, uint16_t length, uint8_t header=PJON_NO_HEADER, uint16_t packet_id=0, uint16_t rx_port=PJON_BROADCAST) (defined in PJON< Any >) | PJON< Any > | inline |
send_packet(const PJON_Packet_Info &info, const void *payload, uint16_t length) (defined in PJON< Any >) | PJON< Any > | inline |
send_packet_blocking(const PJON_Packet_Info &packet_info, const void *payload, uint16_t length, uint32_t timeout=3500000) (defined in PJON< Any >) | PJON< Any > | inline |
send_packet_blocking(uint8_t rx_id, const void *payload, uint16_t length, uint8_t header=PJON_NO_HEADER, uint16_t packet_id=0, uint16_t rx_port=PJON_BROADCAST, uint32_t timeout=3500000) (defined in PJON< Any >) | PJON< Any > | inline |
send_repeatedly(uint8_t rx_id, const void *payload, uint16_t length, uint32_t timing, uint8_t header=PJON_NO_HEADER, uint16_t packet_id=0, uint16_t rx_port=PJON_BROADCAST) (defined in PJON< Any >) | PJON< Any > | inline |
send_repeatedly(const PJON_Packet_Info &info, const void *payload, uint16_t length, uint32_t timing) (defined in PJON< Any >) | PJON< Any > | inline |
set_acknowledge(bool state) (defined in PJON< Any >) | PJON< Any > | inline |
set_bus_id(const uint8_t *b_id) (defined in PJON< Any >) | PJON< Any > | inline |
set_communication_mode(bool mode) (defined in PJON< Any >) | PJON< Any > | inline |
set_config_bit(bool new_state, uint8_t bit) (defined in PJON< Any >) | PJON< Any > | inline |
set_crc_32(bool state) (defined in PJON< Any >) | PJON< Any > | inline |
set_custom_pointer(void *pointer) (defined in PJON< Any >) | PJON< Any > | inline |
set_default() (defined in PJON< Any >) | PJON< Any > | inline |
set_error(PJON_Error e) (defined in PJON< Any >) | PJON< Any > | inline |
set_id(uint8_t id) (defined in PJON< Any >) | PJON< Any > | inline |
set_link(StrategyLinkBase *link) (defined in PJONAny) | PJONAny | inline |
set_packet_auto_deletion(bool state) (defined in PJON< Any >) | PJON< Any > | inline |
set_random_seed(uint8_t seed) (defined in PJON< Any >) | PJON< Any > | inline |
set_receiver(PJON_Receiver r) (defined in PJON< Any >) | PJON< Any > | inline |
set_router(bool state) (defined in PJON< Any >) | PJON< Any > | inline |
set_shared_network(bool state) (defined in PJON< Any >) | PJON< Any > | inline |
strategy (defined in PJON< Any >) | PJON< Any > | |
tx (defined in PJON< Any >) | PJON< Any > | |
update() (defined in PJON< Any >) | PJON< Any > | inline |
