This is the complete list of members for PJONDynamicRouter2< A, B >, including all inherited members.
add(const uint8_t bus_id[], uint8_t via_attached_bus) (defined in PJONRouter) | PJONRouter | inline |
add_sender_to_routing_table(const PJON_Packet_Info &packet_info, uint8_t sender_bus) (defined in PJONDynamicRouter) | PJONDynamicRouter | inlineprotected |
begin() (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
bus_count (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
buses (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
connect(uint8_t bus_count_in, PJON< Any > *const buses_in[], uint8_t default_gateway_in, void *custom_pointer, PJON_Receiver receiver, PJON_Error error) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
connect_buses(uint8_t bus_count_in, PJON< Any > *const buses_in[], uint8_t default_gateway_in=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
current_bus (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
default_gateway (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
dynamic_error_function(uint8_t code, uint16_t data) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
dynamic_receiver_function(uint8_t *payload, uint16_t length, const PJON_Packet_Info &packet_info) (defined in PJONDynamicRouter) | PJONDynamicRouter | inlineprotectedvirtual |
error_function(uint8_t code, uint16_t data, void *custom_pointer) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlinestatic |
find_attached_bus_with_id(const uint8_t *bus_id, const uint8_t, uint8_t &start_bus) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
find_bus_in_table(const uint8_t *bus_id, const uint8_t, uint8_t &start_bus) (defined in PJONRouter) | PJONRouter | inlineprotected |
find_bus_with_id(const uint8_t *bus_id, const uint8_t device_id, uint8_t &start_bus) (defined in PJONRouter) | PJONRouter | inlineprotectedvirtual |
find_bus_with_id(const uint8_t bus_id[], const uint8_t device_id, uint8_t &start_bus) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
forward_packet(const uint8_t *payload, const uint16_t length, const uint8_t receiver_bus, const uint8_t sender_bus, bool &ack_sent, const PJON_Packet_Info &packet_info) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
get_bus(const uint8_t ix) (defined in PJONDynamicRouter2< A, B >) | PJONDynamicRouter2< A, B > | inline |
get_callback_bus() const (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
get_strategy_0() (defined in PJONDynamicRouter2< A, B >) | PJONDynamicRouter2< A, B > | inline |
get_strategy_1() (defined in PJONDynamicRouter2< A, B >) | PJONDynamicRouter2< A, B > | inline |
loop() (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONDynamicRouter() (defined in PJONDynamicRouter) | PJONDynamicRouter | inline |
PJONDynamicRouter(uint8_t bus_count, PJONAny *const buses[], uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONDynamicRouter) | PJONDynamicRouter | inline |
PJONDynamicRouter2(uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONDynamicRouter2< A, B >) | PJONDynamicRouter2< A, B > | inline |
PJONRouter() (defined in PJONRouter) | PJONRouter | inline |
PJONRouter(uint8_t bus_count, PJONAny *const buses[], uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONRouter) | PJONRouter | inline |
PJONSimpleSwitch() (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSimpleSwitch(uint8_t bus_count, PJON< Any > *const buses[], uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSimpleSwitch(PJON< Any > &bus0, PJON< Any > &bus1, uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSimpleSwitch(PJON< Any > &bus0, PJON< Any > &bus1, PJON< Any > &bus2, uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSwitch() (defined in PJONSwitch) | PJONSwitch | inline |
PJONSwitch(uint8_t bus_count, PJONAny *const bus_list[], uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSwitch) | PJONSwitch | inline |
receiver_function(uint8_t *payload, uint16_t length, const PJON_Packet_Info &packet_info) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlinestatic |
remote_bus_ids (defined in PJONRouter) | PJONRouter | protected |
remote_bus_via_attached_bus (defined in PJONRouter) | PJONRouter | protected |
send_packet(const uint8_t *payload, const uint16_t length, const uint8_t receiver_bus, const uint8_t sender_bus, bool &ack_sent, const PJON_Packet_Info &packet_info) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
table_size (defined in PJONRouter) | PJONRouter | protected |
