This is the complete list of members for PJONInteractiveRouter< RouterClass >, including all inherited members.
begin() (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
bus_count (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
buses (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
connect(uint8_t bus_count_in, PJON< Any > *const buses_in[], uint8_t default_gateway_in, void *custom_pointer, PJON_Receiver receiver, PJON_Error error) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
connect_buses(uint8_t bus_count_in, PJON< Any > *const buses_in[], uint8_t default_gateway_in=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
current_bus (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
custom_pointer (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | protected |
default_gateway (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | protected |
dynamic_error_function(uint8_t code, uint16_t data) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inlineprotectedvirtual |
dynamic_receiver_function(uint8_t *payload, uint16_t length, const PJON_Packet_Info &packet_info) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inlineprotectedvirtual |
error (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | protected |
error_function(uint8_t code, uint16_t data, void *custom_pointer) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlinestatic |
find_attached_bus_with_id(const uint8_t *bus_id, const uint8_t, uint8_t &start_bus) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
find_bus_with_id(const uint8_t bus_id[], const uint8_t device_id, uint8_t &start_bus) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
forward_packet(const uint8_t *payload, const uint16_t length, const uint8_t receiver_bus, const uint8_t sender_bus, bool &ack_sent, const PJON_Packet_Info &packet_info) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlineprotected |
get_bus(const uint8_t ix) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
get_callback_bus() const (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
loop() (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONInteractiveRouter() (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
PJONInteractiveRouter(uint8_t bus_count, PJONAny *const buses[], uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
PJONSimpleSwitch() (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSimpleSwitch(uint8_t bus_count, PJON< Any > *const buses[], uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSimpleSwitch(PJON< Any > &bus0, PJON< Any > &bus1, uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSimpleSwitch(PJON< Any > &bus0, PJON< Any > &bus1, PJON< Any > &bus2, uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inline |
PJONSwitch() (defined in PJONSwitch) | PJONSwitch | inline |
PJONSwitch(uint8_t bus_count, PJONAny *const bus_list[], uint8_t default_gateway=PJON_NOT_ASSIGNED) (defined in PJONSwitch) | PJONSwitch | inline |
receiver (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | protected |
receiver_function(uint8_t *payload, uint16_t length, const PJON_Packet_Info &packet_info) (defined in PJONSimpleSwitch< Any >) | PJONSimpleSwitch< Any > | inlinestatic |
router (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | protected |
send_notification (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | protected |
send_packet(const uint8_t *payload, const uint16_t length, const uint8_t receiver_bus, const uint8_t sender_bus, bool &ack_sent, const PJON_Packet_Info &packet_info) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inlineprotectedvirtual |
send_packet(const uint8_t *payload, uint16_t length, const PJON_Packet_Info &packet_info) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
set_custom_ptr(void *custom_ptr) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
set_error(PJON_Error e) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
set_receiver(PJON_Receiver r) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
set_router(bool on) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
set_send_notification(PJON_Send_Notification s) (defined in PJONInteractiveRouter< RouterClass >) | PJONInteractiveRouter< RouterClass > | inline |
