This library is AESigned to be...
This is an AES library for the Arduino, based on tzikis's AES library, which you can find here:.
Tzikis library was based on scottmac`s library, which you can find here:
Create a folder named AES in the libraries folder inside your Arduino sketch folder. If the libraries folder doesn't exist, create it. Then copy everything inside. (re)launch the Arduino IDE.
You're done. Time for a mojito
install
sudo make install
cd examples_Rpi
make
What to do after changes to the library
sudo make clean
sudo make install
cd examples_Rpi
make clean
make
What to do after changes to a sketch
cd examples_Rpi
make <sketch>
or
make clean
make
How to start a sketch
cd examples_Rpi
sudo ./<sketch>
If issues are discovered with the documentation, please report them here
Please refer to:
Most standard Arduino based boards are supported:
