This is the complete list of members for TinyGsm, including all inherited members.
audioMuteMic(bool mute) (defined in TinyGsm) | TinyGsm | inline |
audioSetHeadphones() (defined in TinyGsm) | TinyGsm | inline |
audioSetSpeaker() (defined in TinyGsm) | TinyGsm | inline |
beeType (defined in TinyGsm) | TinyGsm | protected |
begin() (defined in TinyGsm) | TinyGsm | inline |
callAnswer() (defined in TinyGsm) | TinyGsm | inline |
callAnswer() TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
callHangup() (defined in TinyGsm) | TinyGsm | inline |
callHangup() TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
callNumber(const String &number) (defined in TinyGsm) | TinyGsm | inline |
callNumber(const String &number) TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
commandMode(void) (defined in TinyGsm) | TinyGsm | inline |
dnsIpQuery(const char *host) (defined in TinyGsm) | TinyGsm | inlineprotected |
dtmfSend(char cmd, unsigned duration_ms=100) (defined in TinyGsm) | TinyGsm | inline |
exitCommand(void) (defined in TinyGsm) | TinyGsm | inline |
factoryDefault() (defined in TinyGsm) | TinyGsm | inline |
getBattPercent() (defined in TinyGsm) | TinyGsm | inline |
getBattPercent() TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
getBattVoltage() TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
getGsmLocation() TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
getIMEI() (defined in TinyGsm) | TinyGsm | inline |
getLocalIP() (defined in TinyGsm) | TinyGsm | inline |
getModemInfo() (defined in TinyGsm) | TinyGsm | inline |
getOperator() (defined in TinyGsm) | TinyGsm | inline |
getRegistrationStatus() (defined in TinyGsm) | TinyGsm | inline |
getSignalQuality() (defined in TinyGsm) | TinyGsm | inline |
getSimCCID() (defined in TinyGsm) | TinyGsm | inline |
getSimStatus(unsigned long timeout=10000L) (defined in TinyGsm) | TinyGsm | inline |
gprsConnect(const char *apn, const char *user=NULL, const char *pwd=NULL) (defined in TinyGsm) | TinyGsm | inline |
gprsDisconnect() (defined in TinyGsm) | TinyGsm | inline |
guardTime (defined in TinyGsm) | TinyGsm | protected |
hasSSL() (defined in TinyGsm) | TinyGsm | inline |
init() (defined in TinyGsm) | TinyGsm | inline |
isGprsConnected() (defined in TinyGsm) | TinyGsm | inline |
isNetworkConnected() (defined in TinyGsm) | TinyGsm | inline |
localIP() (defined in TinyGsm) | TinyGsm | inline |
maintain() (defined in TinyGsm) | TinyGsm | inline |
modemConnect(const char *host, uint16_t port, uint8_t *mux) (defined in TinyGsm) | TinyGsm | inlineprotected |
modemConnect(const char *host, uint16_t port, uint8_t mux, bool ssl=false) (defined in TinyGsm) | TinyGsm | inlineprotected |
modemConnect(const char *host, uint16_t port, uint8_t mux) (defined in TinyGsm) | TinyGsm | inlineprotected |
modemGetConnected(uint8_t mux) (defined in TinyGsm) | TinyGsm | inlineprotected |
modemSend(const void *buff, size_t len, uint8_t mux) (defined in TinyGsm) | TinyGsm | inlineprotected |
networkConnect(const char *ssid, const char *pwd) (defined in TinyGsm) | TinyGsm | inline |
networkDisconnect() (defined in TinyGsm) | TinyGsm | inline |
poweroff() (defined in TinyGsm) | TinyGsm | inline |
radioOff() TINY_GSM_ATTR_NOT_IMPLEMENTED (defined in TinyGsm) | TinyGsm | |
restart() (defined in TinyGsm) | TinyGsm | inline |
sendAT(Args... cmd) (defined in TinyGsm) | TinyGsm | inline |
sendSMS(const String &number, const String &text) (defined in TinyGsm) | TinyGsm | inline |
sendSMS_UTF16(const String &number, const void *text, size_t len) TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
sendUSSD(const String &code) (defined in TinyGsm) | TinyGsm | inline |
sendUSSD(const String &code) TINY_GSM_ATTR_NOT_IMPLEMENTED (defined in TinyGsm) | TinyGsm | |
setBaud(unsigned long baud) (defined in TinyGsm) | TinyGsm | inline |
setGsmBusy(bool busy=true) TINY_GSM_ATTR_NOT_AVAILABLE (defined in TinyGsm) | TinyGsm | |
setupPinSleep() (defined in TinyGsm) | TinyGsm | inline |
simUnlock(const char *pin) (defined in TinyGsm) | TinyGsm | inline |
sleepEnable(bool enable=true) TINY_GSM_ATTR_NOT_IMPLEMENTED (defined in TinyGsm) | TinyGsm | |
sleepEnable(bool enable=true) (defined in TinyGsm) | TinyGsm | inline |
sockets (defined in TinyGsm) | TinyGsm | protected |
stream (defined in TinyGsm) | TinyGsm | |
streamClear(void) (defined in TinyGsm) | TinyGsm | inline |
streamRead() (defined in TinyGsm) | TinyGsm | inline |
streamReadUntil(char c) (defined in TinyGsm) | TinyGsm | inline |
streamSkipUntil(char c) (defined in TinyGsm) | TinyGsm | inline |
streamWrite(T last) (defined in TinyGsm) | TinyGsm | inline |
streamWrite(T head, Args... tail) (defined in TinyGsm) | TinyGsm | inline |
testAT(unsigned long timeout=10000L) (defined in TinyGsm) | TinyGsm | inline |
TinyGsm(Stream &stream) (defined in TinyGsm) | TinyGsm | inlineexplicit |
waitForNetwork(unsigned long timeout=60000L) (defined in TinyGsm) | TinyGsm | inline |
waitResponse(uint32_t timeout, String &data, GsmConstStr r1=GFP(GSM_OK), GsmConstStr r2=GFP(GSM_ERROR), GsmConstStr r3=NULL, GsmConstStr r4=NULL, GsmConstStr r5=NULL) (defined in TinyGsm) | TinyGsm | inline |
waitResponse(uint32_t timeout, GsmConstStr r1=GFP(GSM_OK), GsmConstStr r2=GFP(GSM_ERROR), GsmConstStr r3=NULL, GsmConstStr r4=NULL, GsmConstStr r5=NULL) (defined in TinyGsm) | TinyGsm | inline |
waitResponse(GsmConstStr r1=GFP(GSM_OK), GsmConstStr r2=GFP(GSM_ERROR), GsmConstStr r3=NULL, GsmConstStr r4=NULL, GsmConstStr r5=NULL) (defined in TinyGsm) | TinyGsm | inline |
writeChanges(void) (defined in TinyGsm) | TinyGsm | inline |
