Collaboration diagram for Signing related debug messages:Explanation of the abstract signing related debug messages.
MySigning-related log messages, format: [!]SYSTEM:SUB SYSTEM:MESSAGE
MySigning debug log messages:
| E | SYS | SUB | Message | Comment |
| SGN | INI | BND OK | Backend has initialized ok | |
| ! | SGN | INI | BND FAIL | Backend has not initialized ok |
| SGN | PER | OK | Personalization data is ok | |
| ! | SGN | PER | TAMPERED | Personalization data has been tampered |
| SGN | PRE | SGN REQ | Signing required | |
| SGN | PRE | SGN REQ,TO='node' | Tell 'node' that we require signing | |
| SGN | PRE | SGN REQ,FROM='node' | Node 'node' require signing | |
| SGN | PRE | SGN NREQ | Signing not required | |
| SGN | PRE | SGN REQ,TO='node' | Tell 'node' that we do not require signing | |
| SGN | PRE | SGN NREQ,FROM='node' | Node 'node' does not require signing | |
| ! | SGN | PRE | SGN NREQ,FROM='node' REJ | Node 'node' does not require signing but used to (requirement remain unchanged) |
| SGN | PRE | WHI REQ | Whitelisting required | |
| SGN | PRE | WHI REQ,TO='node' | Tell 'node' that we require whitelisting | |
| SGN | PRE | WHI REQ,FROM='node' | Node 'node' require whitelisting | |
| SGN | PRE | WHI NREQ | Whitelisting not required | |
| SGN | PRE | WHI NREQ,TO='node' | Tell 'node' that we do not require whitelisting | |
| SGN | PRE | WHI NREQ,FROM='node' | Node 'node' does not require whitelisting | |
| ! | SGN | PRE | WHI NREQ,FROM='node' REJ | Node 'node' does not require whitelisting but used to (requirement remain unchanged) |
| SGN | PRE | XMT,TO='node' | Presentation data transmitted to 'node' | |
| ! | SGN | PRE | XMT,TO='node' FAIL | Presentation data not properly transmitted to 'node' |
| SGN | PRE | WAIT GW | Waiting for gateway presentation data | |
| ! | SGN | PRE | VER='version' | Presentation version 'version' is not supported |
| SGN | PRE | NSUP | Received signing presentation but signing is not supported | |
| SGN | PRE | NSUP,TO='node' | Informing 'node' that we do not support signing | |
| SGN | SGN | NCE REQ,TO='node' | Nonce request transmitted to 'node' | |
| ! | SGN | SGN | NCE REQ,TO='node' FAIL | Nonce request not properly transmitted to 'node' |
| ! | SGN | SGN | NCE TMO | Timeout waiting for nonce |
| SGN | SGN | SGN | Message signed | |
| ! | SGN | SGN | SGN FAIL | Message failed to be signed |
| SGN | SGN | NREQ='node' | 'node' does not require signed messages | |
| SGN | SGN | 'sender'!='us' NUS | Will not sign because 'sender' is not 'us' (repeater) | |
| ! | SGN | SGN | STATE | Security system in a invalid state (personalization data tampered) |
| ! | SGN | VER | NSG | Message was not signed, but it should have been |
| ! | SGN | VER | FAIL | Verification failed |
| SGN | VER | OK | Verification succeeded | |
| SGN | VER | LEFT='number' | 'number' of failed verifications left in a row before node is locked | |
| ! | SGN | VER | STATE | Security system in a invalid state (personalization data tampered) |
| SGN | SKP | MSG CMD='cmd',TYPE='type' | Message with command 'cmd' and type 'type' does not need to be signed | |
| SGN | SKP | ECHO CMD='cmd',TYPE='type' | ECHO messages does not need to be signed | |
| SGN | NCE | LEFT='number' | 'number' of nonce requests between successful verifications left before node is locked | |
| SGN | NCE | XMT,TO='node' | Nonce data transmitted to 'node' | |
| ! | SGN | NCE | XMT,TO='node' FAIL | Nonce data not properly transmitted to 'node' |
| ! | SGN | NCE | GEN | Failed to generate nonce |
| SGN | NCE | NSUP (DROPPED) | Ignored nonce/request for nonce (signing not supported) | |
| SGN | NCE | FROM='node' | Received nonce from 'node' | |
| SGN | NCE | 'sender'!='dst' (DROPPED) | Ignoring nonce as it did not come from the designation of the message to sign | |
| ! | SGN | BND | INIT FAIL | Failed to initialize signing backend |
| ! | SGN | BND | PWD<8 | Signing password too short |
| ! | SGN | BND | PER | Backend not personalized |
| ! | SGN | BND | SER | Could not get device unique serial from backend |
| ! | SGN | BND | TMR | Backend timed out |
| ! | SGN | BND | SIG,SIZE,'message'>'max' | Refusing to sign 'message' because it is bigger than 'max' allowed size |
| SGN | BND | SIG WHI,ID='id' | Salting message with our 'id' | |
| SGN | BND | SIG WHI,SERIAL='serial' | Salting message with our 'serial' | |
| ! | SGN | BND | VER ONGOING | Verification failed, no ongoing session |
| ! | SGN | BND | VER,IDENT='identifier' | Verification failed, 'identifier' is unknown |
| SGN | BND | VER WHI,ID='sender' | 'sender' found in whitelist | |
| SGN | BND | VER WHI,SERIAL='serial' | Expecting 'serial' for this sender | |
| ! | SGN | BND | VER WHI,ID='id' MISSING | 'id' not found in whitelist |
| SGN | BND | NONCE='nonce' | Calculating signature using 'nonce' | |
| SGN | BND | HMAC='hmac' | Calculated signature is 'hmac' |
