BCM.h
18  */
20 #ifndef BCM_h
21 #define BCM_h
23 #include <stdint.h>
24 #include "bcm2835.h"
26 #define INPUT BCM2835_GPIO_FSEL_INPT
27 #define OUTPUT BCM2835_GPIO_FSEL_OUTP
32 class BCMClass
33 {
35 public:
39  ~BCMClass();
45  uint8_t init();
52  void pinMode(uint8_t gpio, uint8_t mode);
59  void digitalWrite(uint8_t gpio, uint8_t value);
66  uint8_t digitalRead(uint8_t gpio);
73  inline uint8_t digitalPinToInterrupt(uint8_t gpio);
79  uint8_t isInitialized();
81 private:
82  static uint8_t initialized;
83 };
85 uint8_t BCMClass::digitalPinToInterrupt(uint8_t gpio)
86 {
87  return gpio;
88 }
90 extern BCMClass BCM;
92 #endif
BCMClass::isInitialized
Checks if SPI was initialized.
BCMClass::digitalRead
Reads the value from a specified pin.
BCMClass::~BCMClass
~BCMClass()
BCMClass destructor.
Returns the same GPIO, no conversion is required.
Definition: BCM.h:85
BCMClass
BCM class.
Definition: BCM.h:32
BCMClass::pinMode
Configures the specified pin to behave either as an input or an output.
BCMClass::digitalWrite
Write a high or a low value for the given pin.
BCMClass::init
uint8_t init()
Initializes BCM.
