MyEepromAddresses.h
18  */
31 #ifndef MyEepromAddresses_h
32 #define MyEepromAddresses_h
34 // EEPROM variable sizes, in bytes
35 #define SIZE_NODE_ID (1u)
36 #define SIZE_PARENT_NODE_ID (1u)
37 #define SIZE_DISTANCE (1u)
38 #ifdef MY_ROUTES_SIZE
39 #define SIZE_ROUTES (MY_ROUTES_SIZE)
40 #else
41 #define SIZE_ROUTES (256u)
42 #endif
43 #define SIZE_CONTROLLER_CONFIG (23u)
44 #define SIZE_PERSONALIZATION_CHECKSUM (1u)
45 #define SIZE_FIRMWARE_TYPE (2u)
46 #define SIZE_FIRMWARE_VERSION (2u)
47 #define SIZE_FIRMWARE_BLOCKS (2u)
48 #define SIZE_FIRMWARE_CRC (2u)
49 #define SIZE_SIGNING_REQUIREMENT_TABLE (32u)
50 #define SIZE_WHITELIST_REQUIREMENT_TABLE (32u)
51 #define SIZE_SIGNING_SOFT_HMAC_KEY (32u)
52 #define SIZE_SIGNING_SOFT_SERIAL (9u)
53 #define SIZE_RF_ENCRYPTION_AES_KEY (16u)
54 #define SIZE_NODE_LOCK_COUNTER (1u)
58 #define EEPROM_START (0u)
60 #define EEPROM_NODE_ID_ADDRESS EEPROM_START
62 #define EEPROM_PARENT_NODE_ID_ADDRESS (EEPROM_NODE_ID_ADDRESS + SIZE_NODE_ID)
64 #define EEPROM_DISTANCE_ADDRESS (EEPROM_PARENT_NODE_ID_ADDRESS + SIZE_PARENT_NODE_ID)
66 #define EEPROM_ROUTES_ADDRESS (EEPROM_DISTANCE_ADDRESS + SIZE_DISTANCE)
68 #define EEPROM_CONTROLLER_CONFIG_ADDRESS (EEPROM_ROUTES_ADDRESS + SIZE_ROUTES)
70 #define EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS (EEPROM_CONTROLLER_CONFIG_ADDRESS + SIZE_CONTROLLER_CONFIG)
72 #define EEPROM_FIRMWARE_TYPE_ADDRESS (EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS + SIZE_PERSONALIZATION_CHECKSUM)
74 #define EEPROM_FIRMWARE_VERSION_ADDRESS (EEPROM_FIRMWARE_TYPE_ADDRESS + SIZE_FIRMWARE_TYPE)
76 #define EEPROM_FIRMWARE_BLOCKS_ADDRESS (EEPROM_FIRMWARE_VERSION_ADDRESS + SIZE_FIRMWARE_VERSION)
78 #define EEPROM_FIRMWARE_CRC_ADDRESS (EEPROM_FIRMWARE_BLOCKS_ADDRESS + SIZE_FIRMWARE_BLOCKS)
80 #define EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS (EEPROM_FIRMWARE_CRC_ADDRESS + SIZE_FIRMWARE_CRC)
82 #define EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS (EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS + SIZE_SIGNING_REQUIREMENT_TABLE)
84 #define EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS (EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS + SIZE_WHITELIST_REQUIREMENT_TABLE)
86 #define EEPROM_SIGNING_SOFT_SERIAL_ADDRESS (EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS + SIZE_SIGNING_SOFT_HMAC_KEY)
88 #define EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS (EEPROM_SIGNING_SOFT_SERIAL_ADDRESS + SIZE_SIGNING_SOFT_SERIAL)
90 #define EEPROM_NODE_LOCK_COUNTER_ADDRESS (EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS + SIZE_RF_ENCRYPTION_AES_KEY)
92 #define EEPROM_LOCAL_CONFIG_ADDRESS (EEPROM_NODE_LOCK_COUNTER_ADDRESS + SIZE_NODE_LOCK_COUNTER)
94 #endif // MyEepromAddresses_h
