+ Collaboration diagram for MyEepromAddresses:
#define SIZE_NODE_ID   (1u)
 Size node ID.
#define SIZE_PARENT_NODE_ID   (1u)
 Size parent node ID.
#define SIZE_DISTANCE   (1u)
 Size GW distance.
#define SIZE_ROUTES   (256u)
 Size routing table 148 is the.
#define SIZE_CONTROLLER_CONFIG   (23u)
 Size controller config.
#define SIZE_PERSONALIZATION_CHECKSUM   (1u)
 Size personalization checksum.
#define SIZE_FIRMWARE_TYPE   (2u)
 Size firmware type.
#define SIZE_FIRMWARE_VERSION   (2u)
 Size firmware version.
#define SIZE_FIRMWARE_BLOCKS   (2u)
 Size firmware blocks.
#define SIZE_FIRMWARE_CRC   (2u)
 Size firmware CRC.
#define SIZE_SIGNING_REQUIREMENT_TABLE   (32u)
 Size signing requirement table.
#define SIZE_WHITELIST_REQUIREMENT_TABLE   (32u)
 Size whitelist requirement table.
#define SIZE_SIGNING_SOFT_HMAC_KEY   (32u)
 Size soft signing HMAC key.
#define SIZE_SIGNING_SOFT_SERIAL   (9u)
 Size soft signing serial.
#define SIZE_RF_ENCRYPTION_AES_KEY   (16u)
 Size RF AES encryption key.
#define SIZE_NODE_LOCK_COUNTER   (1u)
 Size node lock counter.
#define EEPROM_START   (0u)
 EEPROM start address.
#define EEPROM_NODE_ID_ADDRESS   EEPROM_START
 Address node ID.
#define EEPROM_PARENT_NODE_ID_ADDRESS   (EEPROM_NODE_ID_ADDRESS + SIZE_NODE_ID)
 Address parent node ID.
#define EEPROM_DISTANCE_ADDRESS   (EEPROM_PARENT_NODE_ID_ADDRESS + SIZE_PARENT_NODE_ID)
 Address distance to GW.
#define EEPROM_ROUTES_ADDRESS   (EEPROM_DISTANCE_ADDRESS + SIZE_DISTANCE)
 Address routing table.
#define EEPROM_CONTROLLER_CONFIG_ADDRESS   (EEPROM_ROUTES_ADDRESS + SIZE_ROUTES)
 Address configuration bytes sent by controller.
#define EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS   (EEPROM_CONTROLLER_CONFIG_ADDRESS + SIZE_CONTROLLER_CONFIG)
 Personalization checksum (set by SecurityPersonalizer.ino)
#define EEPROM_FIRMWARE_TYPE_ADDRESS   (EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS + SIZE_PERSONALIZATION_CHECKSUM)
 Address firmware type.
#define EEPROM_FIRMWARE_VERSION_ADDRESS   (EEPROM_FIRMWARE_TYPE_ADDRESS + SIZE_FIRMWARE_TYPE)
 Address firmware version.
#define EEPROM_FIRMWARE_BLOCKS_ADDRESS   (EEPROM_FIRMWARE_VERSION_ADDRESS + SIZE_FIRMWARE_VERSION)
 Address firmware blocks.
#define EEPROM_FIRMWARE_CRC_ADDRESS   (EEPROM_FIRMWARE_BLOCKS_ADDRESS + SIZE_FIRMWARE_BLOCKS)
 Address firmware CRC.
#define EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS   (EEPROM_FIRMWARE_CRC_ADDRESS + SIZE_FIRMWARE_CRC)
 Address signing requirement table.
#define EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS   (EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS + SIZE_SIGNING_REQUIREMENT_TABLE)
 Address whitelist requirement table.
#define EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS   (EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS + SIZE_WHITELIST_REQUIREMENT_TABLE)
 Address soft signing HMAC key. This is set with SecurityPersonalizer.ino.
#define EEPROM_SIGNING_SOFT_SERIAL_ADDRESS   (EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS + SIZE_SIGNING_SOFT_HMAC_KEY)
 Address soft signing serial key. This is set with SecurityPersonalizer.ino.
#define EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS   (EEPROM_SIGNING_SOFT_SERIAL_ADDRESS + SIZE_SIGNING_SOFT_SERIAL)
 Address RF AES encryption key. This is set with SecurityPersonalizer.ino.
#define EEPROM_NODE_LOCK_COUNTER_ADDRESS   (EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS + SIZE_RF_ENCRYPTION_AES_KEY)
 Address node lock counter. This is set with SecurityPersonalizer.ino.
#define EEPROM_LOCAL_CONFIG_ADDRESS   (EEPROM_NODE_LOCK_COUNTER_ADDRESS + SIZE_NODE_LOCK_COUNTER)
 First free address for sketch static configuration.
