MyHwHAL.h
18  */
26 #ifndef MyHwHAL_h
27 #define MyHwHAL_h
33 #define INVALID_INTERRUPT_NUM (0xFFu)
39 #define MY_HWID_PADDING_BYTE (0xAAu)
45 #if defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32)
46 #if defined(ARDUINO_ARCH_ESP8266) && ARDUINO_ESP8266_MAJOR == 3
47 #define IRQ_HANDLER_ATTR IRAM_ATTR
48 #else
49 #define IRQ_HANDLER_ATTR ICACHE_RAM_ATTR
50 #endif
51 #else
52 #define IRQ_HANDLER_ATTR
53 #endif
55 // Implement these as functions or macros
56 /*
57 #define hwInit() MY_SERIALDEVICE.begin(BAUD_RATE)
58 #define hwWatchdogReset() wdt_reset()
59 #define hwReboot() wdt_enable(WDTO_15MS); while (1)
60 #define hwMillis() millis()
62 #define hwDigitalWrite(__pin, __value)
63 #define hwDigitalRead(__pin)
64 #define hwPinMode(__pin, __value)
66 void hwReadConfigBlock(void *buf, void *addr, size_t length);
67 void hwWriteConfigBlock(void *buf, void *addr, size_t length);
68 void hwWriteConfig(const int addr, uint8_t value);
69 uint8_t hwReadConfig(const int addr);
70 */
78 //#define MY_HW_HAS_GETENTROPY
81 typedef uint8_t unique_id_t[16];
88 int8_t hwSleep(uint32_t ms);
97 int8_t hwSleep(const uint8_t interrupt, const uint8_t mode, uint32_t ms);
108 int8_t hwSleep(const uint8_t interrupt1, const uint8_t mode1, const uint8_t interrupt2,
109  const uint8_t mode2,
110  uint32_t ms);
117 bool hwUniqueID(unique_id_t *uniqueID);
123 uint16_t hwCPUVoltage(void);
129 uint16_t hwCPUFrequency(void);
136 int8_t hwCPUTemperature(void);
142 uint16_t hwFreeMem(void);
143
144 #if defined(DEBUG_OUTPUT_ENABLED)
145
149 void hwDebugPrint(const char *fmt, ...);
155 static void hwDebugBuf2Str(const uint8_t *buf, size_t sz) __attribute__((unused));
156 #endif
157
186 #ifdef DOXYGEN
187 #define MY_CRITICAL_SECTION
188 #define MY_HW_HAS_GETENTROPY
189 #endif /* DOXYGEN */
190
191 #endif // #ifdef MyHw_h
hwFreeMem
hwUniqueID
hwCPUTemperature
__attribute__
struct @4::@5 __attribute__
Definition: DigitalPin.h:65
unique_id_t
unique ID
Definition: MyHwHAL.h:81
hwSleep
hwCPUVoltage
hwCPUFrequency
