Classes | Macros | Enumerations | Functions | Variables
MyMessage.h File Reference
API and type declarations for MySensors messages.
Definition in file MyMessage.h.
Classes
class  MyMessage
 MyMessage is used to create, manipulate, send and read MySensors messages. More...
#define V2_MYS_HEADER_PROTOCOL_VERSION   (2u)
 Protocol version.
#define V2_MYS_HEADER_SIZE   (7u)
 Header size.
#define V2_MYS_HEADER_MAX_MESSAGE_SIZE   (32u)
 Max payload size.
#define V2_MYS_HEADER_VSL_VERSION_POS   (0)
 bitfield position version
#define V2_MYS_HEADER_VSL_VERSION_SIZE   (2u)
 size version field
#define V2_MYS_HEADER_VSL_SIGNED_POS   (2u)
 bitfield position signed field
#define V2_MYS_HEADER_VSL_SIGNED_SIZE   (1u)
 size signed field
#define V2_MYS_HEADER_VSL_LENGTH_POS   (3u)
 bitfield position length field
#define V2_MYS_HEADER_VSL_LENGTH_SIZE   (5u)
 size length field
#define V2_MYS_HEADER_CEP_COMMAND_POS   (0)
 bitfield position command field
#define V2_MYS_HEADER_CEP_COMMAND_SIZE   (3u)
 size command field
#define V2_MYS_HEADER_CEP_ECHOREQUEST_POS   (3u)
 bitfield position echo request field
#define V2_MYS_HEADER_CEP_ECHOREQUEST_SIZE   (1u)
 size echo request field
#define V2_MYS_HEADER_CEP_ECHO_POS   (4u)
 bitfield position echo field
#define V2_MYS_HEADER_CEP_ECHO_SIZE   (1u)
 size echo field
#define V2_MYS_HEADER_CEP_PAYLOADTYPE_POS   (5u)
 bitfield position payload type field
#define V2_MYS_HEADER_CEP_PAYLOADTYPE_SIZE   (3u)
 size payload type field
#define MAX_MESSAGE_SIZE   V2_MYS_HEADER_MAX_MESSAGE_SIZE
 The maximum size of a message (including header)
#define HEADER_SIZE   V2_MYS_HEADER_SIZE
 The size of the header.
#define MAX_PAYLOAD_SIZE   (MAX_MESSAGE_SIZE - HEADER_SIZE)
 The maximum size of a payload depends on MAX_MESSAGE_SIZE and HEADER_SIZE.
#define MAX_PAYLOAD   MAX_PAYLOAD_SIZE
#define BIT(n)   ( 1<<(n) )
 Bit indexing macro.
#define BIT_MASK(len)   ( BIT(len)-1 )
 Create a bitmask of length 'len'.
#define BF_MASK(start, len)   ( BIT_MASK(len)<<(start) )
 Create a bitfield mask of length starting at bit 'start'.
#define BF_PREP(x, start, len)   ( ((x)&BIT_MASK(len)) << (start) )
 Prepare a bitmask for insertion or combining.
#define BF_GET(y, start, len)   ( ((y)>>(start)) & BIT_MASK(len) )
 Extract a bitfield of length 'len' starting at bit 'start' from 'y'.
#define BF_SET(y, x, start, len)   ( y= ((y) &~ BF_MASK(start, len)) | BF_PREP(x, start, len) )
 Insert a new bitfield value 'x' into 'y'.
#define mSetVersion(_message, _version)   _message.setVersion(_version)
#define mGetVersion(_message)   _message.getVersion()
#define mSetSigned(_message, _signed)   _message.setSigned(_signed)
#define mGetSigned(_message)   _message.getSigned()
#define mSetLength(_message, _length)   _message.setLength(_length)
#define mGetLength(_message)   _message.getLength()
#define mSetCommand(_message, _command)   _message.setCommand(_command)
#define mGetCommand(_message)   _message.getCommand()
#define mSetRequestEcho(_message, _requestEcho)   _message.setRequestEcho(_requestEcho)
#define mGetRequestEcho(_message)   _message.getRequestEcho()
#define mSetEcho(_message, _echo)   _message.setEcho(_echo)
#define mGetEcho(_message)   _message.getEcho()
#define mSetPayloadType(_message, _payloadType)   _message.setPayloadType(_payloadType)
#define mGetPayloadType(_message)   _message.getPayloadType()
Enumerations
enum  mysensors_command_t {
  C_PRESENTATION = 0, C_SET = 1, C_REQ = 2, C_INTERNAL = 3,
  C_STREAM = 4, C_RESERVED_5 = 5, C_RESERVED_6 = 6, C_INVALID_7 = 7
 The command field (message-type) defines the overall properties of a message. More...
enum  mysensors_internal_t {
  I_BATTERY_LEVEL = 0, I_TIME = 1, I_VERSION = 2, I_ID_REQUEST = 3,
  I_ID_RESPONSE = 4, I_INCLUSION_MODE = 5, I_CONFIG = 6, I_FIND_PARENT_REQUEST = 7,
  I_FIND_PARENT_RESPONSE = 8, I_LOG_MESSAGE = 9, I_CHILDREN = 10, I_SKETCH_NAME = 11,
  I_SKETCH_VERSION = 12, I_REBOOT = 13, I_GATEWAY_READY = 14, I_SIGNING_PRESENTATION = 15,
  I_NONCE_REQUEST = 16, I_NONCE_RESPONSE = 17, I_HEARTBEAT_REQUEST = 18, I_PRESENTATION = 19,
  I_DISCOVER_REQUEST = 20, I_DISCOVER_RESPONSE = 21, I_HEARTBEAT_RESPONSE = 22, I_LOCKED = 23,
  I_PING = 24, I_PONG = 25, I_REGISTRATION_REQUEST = 26, I_REGISTRATION_RESPONSE = 27,
  I_DEBUG = 28, I_SIGNAL_REPORT_REQUEST = 29, I_SIGNAL_REPORT_REVERSE = 30, I_SIGNAL_REPORT_RESPONSE = 31,
  I_PRE_SLEEP_NOTIFICATION = 32, I_POST_SLEEP_NOTIFICATION = 33
 Type of internal messages (for internal messages) More...
enum  mysensors_stream_t {
  ST_FIRMWARE_CONFIG_REQUEST = 0, ST_FIRMWARE_CONFIG_RESPONSE = 1, ST_FIRMWARE_REQUEST = 2, ST_FIRMWARE_RESPONSE = 3,
  ST_SOUND = 4, ST_IMAGE = 5, ST_FIRMWARE_CONFIRM = 6, ST_FIRMWARE_RESPONSE_RLE = 7
 Type of data stream (for streamed message) More...
enum  mysensors_payload_t {
  P_STRING = 0, P_BYTE = 1, P_INT16 = 2, P_UINT16 = 3,
  P_LONG32 = 4, P_ULONG32 = 5, P_CUSTOM = 6, P_FLOAT32 = 7
 Type of payload. More...
class MyMessage __attribute__ ((packed))
 MyMessage (void)
 MyMessage (const uint8_t sensorId, const mysensors_data_t dataType)
void clear (void)
 Clear message contents.
char * getStream (char *buffer) const
char * getString (char *buffer) const
 Copy the payload into the supplied buffer.
const char * getString (void) const
 Get payload as string. More...
void * getCustom (void) const
 Get custom payload. More...
bool getBool (void) const
 Get bool payload. More...
uint8_t getByte (void) const
 Get unsigned 8-bit integer payload. More...
float getFloat (void) const
 Get float payload. More...
int16_t getInt (void) const
 Get signed 16-bit integer payload. More...
uint16_t getUInt (void) const
 Get unsigned 16-bit integer payload. More...
int32_t getLong (void) const
 Get signed 32-bit integer payload. More...
uint32_t getULong (void) const
 Get unsigned 32-bit integer payload. More...
uint8_t getHeaderSize (void) const
 getHeaderSize More...
uint8_t getMaxPayloadSize (void) const
 getMaxPayloadSize More...
uint8_t getExpectedMessageSize (void) const
 getExpectedMessageSize More...
bool isProtocolVersionValid (void) const
 isProtocolVersionValid More...
bool getRequestEcho (void) const
 Getter for echo request. More...
MyMessagesetRequestEcho (const bool requestEcho)
 Setter for echo request. More...
uint8_t getVersion (void) const
 Getter for version. More...
MyMessagesetVersion (void)
 Setter for version.
uint8_t getLength (void) const
 Getter for length. More...
MyMessagesetLength (const uint8_t length)
 Setter for length. More...
mysensors_command_t getCommand (void) const
 Getter for command type. More...
MyMessagesetCommand (const mysensors_command_t command)
 Setter for command type. More...
mysensors_payload_t getPayloadType (void) const
 Getter for payload type. More...
MyMessagesetPayloadType (const mysensors_payload_t payloadType)
 Setter for payload type. More...
bool getSigned (void) const
 Getter for sign field. More...
MyMessagesetSigned (const bool signedFlag)
 Setter for sign field. More...
bool isAck (void) const
 Getter for echo-flag. More...
bool isEcho (void) const
MyMessagesetEcho (const bool echo)
 Setter for echo-flag. More...
uint8_t getType (void) const
 Get message type. More...
MyMessagesetType (const uint8_t messageType)
 Set message type. More...
uint8_t getLast (void) const
 Get last ID. More...
MyMessagesetLast (const uint8_t lastId)
 Set last ID. More...
uint8_t getSender (void) const
 Get sender ID. More...
MyMessagesetSender (const uint8_t senderId)
 Set sender ID. More...
uint8_t getSensor (void) const
 Get sensor ID of message. More...
MyMessagesetSensor (const uint8_t sensorId)
 Set which child sensor this message belongs to. More...
uint8_t getDestination (void) const
 Get destination. More...
MyMessagesetDestination (const uint8_t destinationId)
 Set final destination node id for this message. More...
MyMessageset (const void *payload, const size_t length)
 Set entire payload. More...
MyMessageset (const char *value)
 Set payload to character array. More...
MyMessageset (const float value, const uint8_t decimals)
 Set payload to decimal number. More...
MyMessageset (const bool value)
 Set payload to bool value. More...
MyMessageset (const uint8_t value)
 Set payload to unsigned 8-bit integer value. More...
MyMessageset (const uint32_t value)
 Set payload to unsigned 32-bit integer value. More...
MyMessageset (const int32_t value)
 Set payload to signed 32-bit integer value. More...
MyMessageset (const uint16_t value)
 Set payload to unsigned 16-bit integer value. More...
MyMessageset (const int16_t value)
 Set payload to signed 16-bit integer value. More...
Variables
uint8_t bValue
 unsigned byte value (8-bit)
uint16_t uiValue
 unsigned integer value (16-bit)
int16_t iValue
uint32_t ulValue
 unsigned long value (32-bit)
int32_t lValue
struct {
   float   fValue
 < Float messages
   uint8_t   fPrecision
 Number of decimals when serializing.
char data [MAX_PAYLOAD_SIZE+1]
uint8_t last
uint8_t sender
 8 bit - Id of sender node (origin)
uint8_t destination
uint8_t version_length
uint8_t command_echo_payload
uint8_t type
uint8_t sensor
struct {
   float   fValue
 < Float messages
   uint8_t   fPrecision
◆ getBool()
bool __attribute__::getBool ( void  ) const
Get bool payload.
Returns
a bool with the value of the payload (true/false)
◆ getByte()
uint8_t __attribute__::getByte ( void  ) const
Returns
the value of the payload, 0 to 255
◆ getCommand()
mysensors_command_t __attribute__::getCommand ( void  ) const
Returns
mysensors_command_t
◆ getCustom()
void* __attribute__::getCustom ( void  ) const
Get custom payload.
Returns
pointer to the raw payload
◆ getDestination()
uint8_t __attribute__::getDestination ( void  ) const
Get destination.
Returns
destinationId
◆ getExpectedMessageSize()
uint8_t __attribute__::getExpectedMessageSize ( void  ) const
Returns
the expected message size based on header information
◆ getFloat()
float __attribute__::getFloat ( void  ) const
Get float payload.
Returns
the floating-point value of the payload
◆ getHeaderSize()
uint8_t __attribute__::getHeaderSize ( void  ) const
getHeaderSize
Returns
the size of the header
◆ getInt()
int16_t __attribute__::getInt ( void  ) const
Returns
the value of the payload, –32768 to 32767
◆ getLast()
uint8_t __attribute__::getLast ( void  ) const
Get last ID.
Returns
lastId
◆ getLength()
uint8_t __attribute__::getLength ( void  ) const
Getter for length.
Returns
length
◆ getLong()
int32_t __attribute__::getLong ( void  ) const
Returns
the value of the payload, –2147483648 to 2147483647
◆ getMaxPayloadSize()
uint8_t __attribute__::getMaxPayloadSize ( void  ) const
getMaxPayloadSize
Returns
the max. size of the payload
◆ getPayloadType()
mysensors_payload_t __attribute__::getPayloadType ( void  ) const
Returns
payload type
◆ getRequestEcho()
bool __attribute__::getRequestEcho ( void  ) const
Returns
echo request
◆ getSender()
uint8_t __attribute__::getSender ( void  ) const
Get sender ID.
Returns
sender
◆ getSensor()
uint8_t __attribute__::getSensor ( void  ) const
Returns
sensorId
◆ getSigned()
bool __attribute__::getSigned ( void  ) const
Returns
sign field
◆ getStream()
char* __attribute__::getStream ( char *  buffer) const
If payload is something else than P_STRING you can have the payload value converted into string representation by supplying a buffer with the minimum size of 2 * MAX_PAYLOAD_SIZE + 1. This is to be able to fit hex-conversion of a full binary payload.
bufferpointer to a buffer that's at least 2 * MAX_PAYLOAD_SIZE + 1 bytes large
◆ getString()
const char* __attribute__::getString ( void  ) const
Returns
pointer to a char array storing the string
◆ getType()
uint8_t __attribute__::getType ( void  ) const
Get message type.
Returns
messageType
◆ getUInt()
uint16_t __attribute__::getUInt ( void  ) const
Returns
the value of the payload, 0 to 65535
◆ getULong()
uint32_t __attribute__::getULong ( void  ) const
Returns
the value of the payload, 0 to 4294967295
◆ getVersion()
uint8_t __attribute__::getVersion ( void  ) const
Getter for version.
Returns
version
◆ isAck()
bool __attribute__::isAck ( void  ) const
Deprecated:
use isEcho()
Returns
true if this is an echoed message
◆ isEcho()
bool __attribute__::isEcho ( void  ) const
Returns
◆ isProtocolVersionValid()
bool __attribute__::isProtocolVersionValid ( void  ) const
Returns
true if the protocol version is valid
◆ MyMessage() [1/2]
__attribute__::MyMessage ( const uint8_t  sensorId,
Constructor
sensorIdid of the child sensor for this message
dataType
◆ MyMessage() [2/2]
__attribute__::MyMessage ( void  )
Default constructor
◆ set() [1/9]
MyMessage& __attribute__::set ( const bool  value)
valuetrue or false
◆ set() [2/9]
MyMessage & set ( const char *  value)
Set payload to character array from flash.
valuepointer to the character array. The array must be null-terminated.
◆ set() [3/9]
MyMessage& __attribute__::set ( const float  value,
valuefloat
decimalsnumber of decimals to include
◆ set() [4/9]
MyMessage& __attribute__::set ( const int16_t  value)
value(–32768 to 32767)
◆ set() [5/9]
MyMessage& __attribute__::set ( const int32_t  value)
value(–2147483648 to 2147483647)
◆ set() [6/9]
MyMessage& __attribute__::set ( const uint16_t  value)
value(0 to 65535)
◆ set() [7/9]
MyMessage& __attribute__::set ( const uint32_t  value)
value(0 to 4294967295)
◆ set() [8/9]
MyMessage& __attribute__::set ( const uint8_t  value)
value(0 to 255)
◆ set() [9/9]
MyMessage& __attribute__::set ( const void *  payload,
const size_t  length
payloadpointer to the buffer where the payload is stored
lengthof the payload
◆ setCommand()
MyMessage& __attribute__::setCommand ( const mysensors_command_t  command)
command
◆ setDestination()
MyMessage& __attribute__::setDestination ( const uint8_t  destinationId)
destinationId
◆ setEcho()
MyMessage& __attribute__::setEcho ( const bool  echo)
echotrue if this an echo message
◆ setLast()
MyMessage& __attribute__::setLast ( const uint8_t  lastId)
Set last ID.
lastId
◆ setLength()
MyMessage& __attribute__::setLength ( const uint8_t  length)
Setter for length.
length
◆ setPayloadType()
MyMessage& __attribute__::setPayloadType ( const mysensors_payload_t  payloadType)
payloadType
◆ setRequestEcho()
MyMessage& __attribute__::setRequestEcho ( const bool  requestEcho)
requestEcho
◆ setSender()
MyMessage& __attribute__::setSender ( const uint8_t  senderId)
Set sender ID.
senderId
◆ setSensor()
MyMessage& __attribute__::setSensor ( const uint8_t  sensorId)
sensorId
◆ setSigned()
MyMessage& __attribute__::setSigned ( const bool  signedFlag)
signedFlag
◆ setType()
MyMessage& __attribute__::setType ( const uint8_t  messageType)
Set message type.
messageType
Variable Documentation
◆ command_echo_payload
3 bit - Command type
1 bit - Request an echo - Indicator that receiver should echo the message back to the sender
1 bit - Is echo message - Indicator that this is the echoed message
3 bit - Payload data type
Definition at line 351 of file MyMessage.h.
◆ version_length
2 bit - Protocol version
1 bit - Signed flag
5 bit - Length of payload
Definition at line 343 of file MyMessage.h.
