Definition at line 46 of file SoftwareBitBang.h.
uint32_t | back_off (uint8_t attempts) |
bool | begin (uint8_t did=0) |
bool | can_start () |
void | handle_collision () |
uint8_t | read_byte () |
uint16_t | receive_byte () |
uint16_t | receive_response () |
uint16_t | receive_frame (uint8_t *data, uint16_t max_length) |
void | send_byte (uint8_t b) |
void | send_response (uint8_t response) |
void | send_frame (uint8_t *data, uint16_t length) |
bool | sync (uint32_t spacer) |
bool | sync () |
bool | sync_preamble () |
void | pulse (uint8_t n) |
void | set_pin (uint8_t pin) |
void | set_pins (uint8_t input_pin=SWBB_NOT_ASSIGNED, uint8_t output_pin=SWBB_NOT_ASSIGNED) |
static uint8_t | get_max_attempts () |
static uint16_t | get_receive_time () |
