config.h
18  */
20 #ifndef CONFIG_H
21 #define CONFIG_H
23 #ifdef __cplusplus
24 extern "C" {
25 #endif
30 struct config {
31  int verbose;
32  int log_file;
33  char *log_filepath;
34  int log_pipe;
35  char *log_pipe_file;
36  int syslog;
37  char *eeprom_file;
38  int eeprom_size;
39  char *soft_hmac_key;
40  char *soft_serial_key;
41  char *aes_key;
42 };
44 extern struct config conf;
46 int config_parse(const char *config_file);
47 void config_cleanup(void);
49 #ifdef __cplusplus
50 }
51 #endif
53 #endif
config
Config file.
Definition: config.h:30
