hal
architecture
Linux
drivers
core
Arduino.h
* Created by Henrik Ekblad <
[email protected]
#ifndef Arduino_h
#define Arduino_h
#include <stdlib.h>
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdarg.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <string>
#include <algorithm>
#include "stdlib_noniso.h"
#ifdef LINUX_ARCH_RASPBERRYPI
#include "RPi.h"
#define pinMode(pin, direction) RPi.pinMode(pin, direction)
#define digitalWrite(pin, value) RPi.digitalWrite(pin, value)
#define digitalRead(pin) RPi.digitalRead(pin)
#define digitalPinToInterrupt(pin) RPi.digitalPinToInterrupt(pin)
#else
#include "GPIO.h"
#define pinMode(pin, direction) GPIO.pinMode(pin, direction)
#define digitalWrite(pin, value) GPIO.digitalWrite(pin, value)
#define digitalRead(pin) GPIO.digitalRead(pin)
#define digitalPinToInterrupt(pin) GPIO.digitalPinToInterrupt(pin)
#include "interrupt.h"
#undef PSTR
#define PSTR(x) (x)
#undef F
#define F(x) (x)
#define PROGMEM __attribute__(( section(".progmem.data") ))
#define vsnprintf_P(...) vsnprintf( __VA_ARGS__ )
#define snprintf_P(...) snprintf( __VA_ARGS__ )
#define memcpy_P memcpy
#define pgm_read_byte(p) (*(p))
#define pgm_read_dword(p) (*(p))
#define pgm_read_byte_near(p) (*(p))
#define PI 3.1415926535897932384626433832795
#define HALF_PI 1.5707963267948966192313216916398
#define TWO_PI 6.283185307179586476925286766559
#define DEG_TO_RAD 0.017453292519943295769236907684886
#define RAD_TO_DEG 57.295779513082320876798154814105
#define EULER 2.718281828459045235360287471352
#define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
#define radians(deg) ((deg)*DEG_TO_RAD)
#define degrees(rad) ((rad)*RAD_TO_DEG)
#define sq(x) ((x)*(x))
#define round(x) ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
#define lowByte(w) ((uint8_t) ((w) & 0xff))
#define highByte(w) ((uint8_t) ((w) >> 8))
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
#define bitSet(value, bit) ((value) |= (1UL << (bit)))
#define bitClear(value, bit) ((value) &= ~(1UL << (bit)))
#define bitWrite(value, bit, bitvalue) (bitvalue ? bitSet(value, bit) : bitClear(value, bit))
#define bit(b) (1UL << (b))
#define GET_MACRO(_0, _1, _2, NAME, ...) NAME
#define random(...) GET_MACRO(_0, ##__VA_ARGS__, randMinMax, randMax, rand)(__VA_ARGS__)
#ifndef delay
#define delay _delay_milliseconds
#ifndef delayMicroseconds
#define delayMicroseconds _delay_microseconds
using
std::string;
using
std::min
using
std::max
using
std::abs;
typedef
uint8_t byte;
typedef
string
String;
typedef
char
__FlashStringHelper;
void
yield(
void
unsigned
long
millis(
void
unsigned
long
micros(
void
void
_delay_milliseconds(
unsigned
int
millis);
void
_delay_microseconds(
unsigned
int
micro);
void
randomSeed(
unsigned
long
seed);
long
randMax(
long
howbig);
long
randMinMax(
long
howsmall,
long
howbig);
min
#define min(a, b)
min
Definition:
MySensors.h:94
max
#define max(a, b)
max
Definition:
MySensors.h:98
