* Created by Henrik Ekblad <
[email protected]
#ifndef MySensors_h
#define MySensors_h
#ifdef __cplusplus
#include <Arduino.h>
#include <stdint.h>
#include "
MyConfig.h
#include "core/MyHelperFunctions.cpp"
#include "core/MySplashScreen.h"
#include "
core/MySensorsCore.h
// OTA Debug, has to be defined before HAL
#if defined(MY_OTA_LOG_SENDER_FEATURE) || defined(MY_OTA_LOG_RECEIVER_FEATURE)
#include "
core/MyOTALogging.h
// HARDWARE
#include "
hal/architecture/MyHwHAL.h
#include "hal/crypto/MyCryptoHAL.h"
#if defined(ARDUINO_ARCH_ESP8266)
#include "hal/architecture/ESP8266/MyHwESP8266.cpp"
#include "hal/crypto/generic/MyCryptoGeneric.cpp"
#elif defined(ARDUINO_ARCH_ESP32)
#include "hal/architecture/ESP32/MyHwESP32.cpp"
#include "hal/crypto/ESP32/MyCryptoESP32.cpp"
#elif defined(ARDUINO_ARCH_AVR)
#include "hal/architecture/AVR/MyHwAVR.cpp"
#include "hal/crypto/AVR/MyCryptoAVR.cpp"
#elif defined(ARDUINO_ARCH_SAMD)
#include "drivers/extEEPROM/extEEPROM.cpp"
#include "hal/architecture/SAMD/MyHwSAMD.cpp"
#elif defined(ARDUINO_ARCH_STM32F1)
#include "hal/architecture/STM32F1/MyHwSTM32F1.cpp"
#elif defined(ARDUINO_ARCH_NRF5) || defined(ARDUINO_ARCH_NRF52)
#include "hal/architecture/NRF5/MyHwNRF5.cpp"
#elif defined(__arm__) && defined(TEENSYDUINO)
#include "hal/architecture/Teensy3/MyHwTeensy3.cpp"
#elif defined(__linux__)
#include "hal/architecture/Linux/MyHwLinuxGeneric.cpp"
#else
#error Hardware abstraction not defined (unsupported platform)
#include "hal/architecture/MyHwHAL.cpp"
// commonly used macros, sometimes missing in arch definitions
#if !defined(_BV)
#define _BV(x) (1<<(x))
#if !defined(min) && !defined(__linux__)
#define min(a,b) ((a)<(b)?(a):(b))
#if !defined(max) && !defined(__linux__)
#define max(a,b) ((a)>(b)?(a):(b))
#if !defined(MIN)
#define MIN min
#if !defined(MAX)
#define MAX max
// OTA Debug second part, depends on HAL
#include "core/MyOTALogging.cpp"
#if defined(MY_LEDS_BLINKING_FEATURE)
#error MY_LEDS_BLINKING_FEATURE is now removed from MySensors core,\
define MY_DEFAULT_ERR_LED_PIN, MY_DEFAULT_TX_LED_PIN or\
MY_DEFAULT_RX_LED_PIN in your sketch instead to enable LEDs
#if defined(MY_DEFAULT_RX_LED_PIN) || defined(MY_DEFAULT_TX_LED_PIN) || defined(MY_DEFAULT_ERR_LED_PIN)
#include "core/MyLeds.cpp"
#else
123
#include "core/MyLeds.h"
126
#include "core/MyIndication.cpp"
128
// INCLUSION MODE
#if defined(MY_INCLUSION_MODE_FEATURE)
131
#include "core/MyInclusionMode.cpp"
134
// SIGNING
#include "core/MySigning.cpp"
#if defined(MY_SIGNING_FEATURE)
138
// SIGNING COMMON FUNCTIONS
139
#if defined(MY_SIGNING_ATSHA204) && defined(MY_SIGNING_SOFT)
140
#error Only one signing engine can be activated
141
#if defined(MY_SIGNING_ATSHA204) && defined(__linux__)
143
#error No support for ATSHA204 on this platform
144
146
147
#include "core/MySigningAtsha204.cpp"
148
#include "drivers/ATSHA204/ATSHA204.cpp"
149
#elif defined(MY_SIGNING_SOFT)
150
#include "core/MySigningAtsha204Soft.cpp"
151
154
// FLASH
155
#if defined(MY_OTA_FIRMWARE_FEATURE)
156
#ifndef MCUBOOT_PRESENT
157
#if defined(MY_OTA_USE_I2C_EEPROM)
158
#include "drivers/I2CEeprom/I2CEeprom.cpp"
159
#else
160
#include "drivers/SPIFlash/SPIFlash.cpp"
161
#include "core/MyOTAFirmwareUpdate.cpp"
164
166
// GATEWAY - TRANSPORT
167
#if defined(MY_CONTROLLER_IP_ADDRESS) || defined(MY_CONTROLLER_URL_ADDRESS)
168
#define MY_GATEWAY_CLIENT_MODE
169
171
#if defined(MY_USE_UDP) && !defined(MY_GATEWAY_CLIENT_MODE)
172
#error You must specify MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS for UDP
173
175
176
177
// Set MQTT defaults if not set
178
179
#if !defined(MY_MQTT_PUBLISH_TOPIC_PREFIX)
180
183
#if !defined(MY_MQTT_SUBSCRIBE_TOPIC_PREFIX)
184
185
187
#if !defined(MY_MQTT_CLIENT_ID)
188
189
191
#if defined(MY_GATEWAY_MQTT_CLIENT)
192
#if defined(MY_SENSOR_NETWORK)
193
// We assume that a gateway having a radio also should act as repeater
194
#define MY_REPEATER_FEATURE
195
197
// GATEWAY - COMMON FUNCTIONS
198
// We support MQTT Client using W5100, ESP8266, GSM modems supported by TinyGSM library and Linux
199
#if !defined(MY_GATEWAY_CLIENT_MODE) && !defined(MY_GATEWAY_TINYGSM)
200
201
203
#if defined(MY_GATEWAY_TINYGSM) && !defined(MY_GATEWAY_MQTT_CLIENT)
204
// TinyGSM currently only supports MQTTClient mode.
205
#error MY_GATEWAY_TINYGSM only works with MY_GATEWAY_MQTT_CLIENT
206
208
#include "core/MyGatewayTransport.cpp"
209
#include "core/MyProtocol.cpp"
210
211
212
#include "drivers/TinyGSM/TinyGsmClient.h"
213
215
#if defined(MY_GATEWAY_LINUX)
216
#include "hal/architecture/Linux/drivers/core/EthernetClient.h"
217
#include "hal/architecture/Linux/drivers/core/EthernetServer.h"
218
#include "hal/architecture/Linux/drivers/core/IPAddress.h"
219
#include "drivers/PubSubClient/PubSubClient.cpp"
221
#include "core/MyGatewayTransportMQTTClient.cpp"
222
#elif defined(MY_GATEWAY_FEATURE)
223
224
225
226
227
// GATEWAY - CONFIGURATION
228
229
230
231
233
#if defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)
234
// GATEWAY - ESP8266 / ESP32
235
#include "core/MyGatewayTransportEthernet.cpp"
236
#elif defined(MY_GATEWAY_LINUX)
237
// GATEWAY - Generic Linux
238
239
#error UDP mode is not available for Linux
240
242
243
244
245
#elif defined(MY_GATEWAY_W5100)
246
// GATEWAY - W5100
247
248
#elif defined(MY_GATEWAY_ENC28J60)
249
// GATEWAY - ENC28J60
250
251
#error UDP mode is not available for ENC28J60
252
254
#elif defined(MY_GATEWAY_SERIAL)
255
// GATEWAY - SERIAL
256
#include "core/MyGatewayTransportSerial.cpp"
257
260
// TRANSPORT
261
#ifndef DOXYGEN
262
// count enabled transports
263
#if defined(MY_RADIO_RF24)
264
#define __RF24CNT 1
265
#else
266
#define __RF24CNT 0
267
#if defined(MY_RADIO_NRF5_ESB)
269
#define __NRF5ESBCNT 1
270
#else
271
#define __NRF5ESBCNT 0
272
#if defined(MY_RADIO_RFM69)
274
#define __RFM69CNT 1
275
#else
276
#define __RFM69CNT 0
277
#if defined(MY_RADIO_RFM95)
279
#define __RFM95CNT 1
280
#else
281
#define __RFM95CNT 0
282
#if defined(MY_RS485)
284
#define __RS485CNT 1
285
#else
286
#define __RS485CNT 0
287
289
#if (__RF24CNT + __NRF5ESBCNT + __RFM69CNT + __RFM95CNT + __RS485CNT > 1)
290
#error Only one forward link driver can be activated
291
#endif //DOXYGEN
293
294
// SANITY CHECK
295
#if defined(MY_REPEATER_FEATURE) || defined(MY_GATEWAY_FEATURE)
296
#define MY_TRANSPORT_SANITY_CHECK
297
299
// TRANSPORT INCLUDES
300
#if defined(MY_RADIO_RF24) || defined(MY_RADIO_NRF5_ESB) || defined(MY_RADIO_RFM69) || defined(MY_RADIO_RFM95) || defined(MY_RS485)
301
#include "hal/transport/MyTransportHAL.h"
302
#include "
core/MyTransport.h
303
304
// PARENT CHECK
305
#if defined(MY_PARENT_NODE_IS_STATIC) && (MY_PARENT_NODE_ID == AUTO)
306
#error Parent is static but no parent ID defined, set MY_PARENT_NODE_ID.
307
309
#if defined(MY_TRANSPORT_DONT_CARE_MODE)
310
#error MY_TRANSPORT_DONT_CARE_MODE is deprecated, set MY_TRANSPORT_WAIT_READY_MS instead!
311
313
// RAM ROUTING TABLE
314
#if defined(MY_RAM_ROUTING_TABLE_FEATURE) && defined(MY_REPEATER_FEATURE)
315
// activate feature based on architecture
316
#if defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32) || defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_NRF5) || defined(ARDUINO_ARCH_STM32F1) || defined(TEENSYDUINO) || defined(__linux__)
317
#define MY_RAM_ROUTING_TABLE_ENABLED
318
319
#if defined(__avr_atmega1280__) || defined(__avr_atmega1284__) || defined(__avr_atmega2560__)
320
// >4kb, enable it
321
322
#else
323
// memory limited, enable with care
324
// #define MY_RAM_ROUTING_TABLE_ENABLED
325
#endif // __avr_atmega1280__, __avr_atmega1284__, __avr_atmega2560__
326
#endif // ARDUINO_ARCH_AVR
327
#ifdef DOXYGEN
329
335
336
338
// SOFTSERIAL
339
#if defined(MY_GSM_TX) != defined(MY_GSM_RX)
340
#error Both, MY_GSM_TX and MY_GSM_RX need to be defined when using SoftSerial
341
343
#if defined(MY_GATEWAY_TINYGSM) && !defined(SerialAT) && (!defined(MY_GSM_TX) || !defined(MY_GSM_RX))
344
#error You need to define either SerialAT or MY_GSM_RX and MY_GSM_TX pins
345
347
// POWER PIN
348
#ifndef DOXYGEN
349
#if defined(MY_RF24_POWER_PIN) || defined(MY_RFM69_POWER_PIN) || defined(MY_RFM95_POWER_PIN) || defined(MY_RADIO_NRF5_ESB)
350
#define RADIO_CAN_POWER_OFF (true)
351
#else
352
#define RADIO_CAN_POWER_OFF (false)
353
356
// Transport drivers
357
358
#include "hal/transport/RF24/driver/RF24.cpp"
359
#include "hal/transport/RF24/MyTransportRF24.cpp"
360
#elif defined(MY_RADIO_NRF5_ESB)
361
#if !defined(ARDUINO_ARCH_NRF5)
362
#error No support for nRF5 radio on this platform
363
#include "hal/transport/NRF5_ESB/driver/Radio.cpp"
365
#include "hal/transport/NRF5_ESB/driver/Radio_ESB.cpp"
366
#include "hal/transport/NRF5_ESB/MyTransportNRF5_ESB.cpp"
367
#elif defined(MY_RS485)
368
#if !defined(MY_RS485_HWSERIAL)
369
#if defined(__linux__)
370
#error You must specify MY_RS485_HWSERIAL for RS485 transport
371
#include "drivers/AltSoftSerial/AltSoftSerial.cpp"
373
#include "hal/transport/RS485/MyTransportRS485.cpp"
375
#elif defined(MY_RADIO_RFM69)
376
#if defined(MY_RFM69_NEW_DRIVER)
377
#include "hal/transport/RFM69/driver/new/RFM69_new.cpp"
378
#else
379
#include "hal/transport/RFM69/driver/old/RFM69_old.cpp"
380
#include "hal/transport/RFM69/MyTransportRFM69.cpp"
382
#elif defined(MY_RADIO_RFM95)
383
#include "hal/transport/RFM95/driver/RFM95.cpp"
384
#include "hal/transport/RFM95/MyTransportRFM95.cpp"
385
387
#if (defined(MY_RF24_ENABLE_ENCRYPTION) && defined(MY_RADIO_RF24)) || (defined(MY_NRF5_ESB_ENABLE_ENCRYPTION) && defined(MY_RADIO_NRF5_ESB)) || (defined(MY_RFM69_ENABLE_ENCRYPTION) && defined(MY_RADIO_RFM69)) || (defined(MY_RFM95_ENABLE_ENCRYPTION) && defined(MY_RADIO_RFM95))
388
#define MY_TRANSPORT_ENCRYPTION
389
391
#include "hal/transport/MyTransportHAL.cpp"
392
393
// PASSIVE MODE
394
#if defined(MY_PASSIVE_NODE) && !defined(DOXYGEN)
395
#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
396
#define MY_PARENT_NODE_IS_STATIC
397
#undef MY_REGISTRATION_FEATURE
398
#undef MY_SIGNING_FEATURE
399
#undef MY_OTA_FIRMWARE_FEATURE
400
#if defined(MY_GATEWAY_FEATURE) || defined(MY_REPEATER_FEATURE)
401
#error This node is configured as GW/repeater, MY_PASSIVE_NODE cannot be set simultaneously
402
#if (MY_NODE_ID == AUTO)
404
#error MY_PASSIVE_NODE configuration requires setting MY_NODE_ID
405
408
#include "core/MyTransport.cpp"
409
411
// Make sure to disable child features when parent feature is disabled
412
#if !defined(MY_SENSOR_NETWORK)
413
414
#undef MY_REPEATER_FEATURE
415
#undef MY_SIGNING_NODE_WHITELISTING
416
417
419
#if !defined(MY_GATEWAY_FEATURE)
420
#undef MY_INCLUSION_MODE_FEATURE
421
#undef MY_INCLUSION_BUTTON_FEATURE
422
424
#if !defined(MY_CORE_ONLY)
425
#if !defined(MY_GATEWAY_FEATURE) && !defined(MY_SENSOR_NETWORK)
426
#error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
427
430
#include "
core/MyCapabilities.h
431
#include "core/MyMessage.cpp"
432
#include "core/MySplashScreen.cpp"
433
#include "core/MySensorsCore.cpp"
434
435
// HW mains
436
#if defined(ARDUINO_ARCH_AVR)
437
#include "hal/architecture/AVR/MyMainAVR.cpp"
438
439
#include "hal/architecture/SAMD/MyMainSAMD.cpp"
440
#elif defined(ARDUINO_ARCH_ESP8266)
441
#include "hal/architecture/ESP8266/MyMainESP8266.cpp"
442
443
#include "hal/architecture/NRF5/MyMainNRF5.cpp"
444
445
#include "hal/architecture/ESP32/MyMainESP32.cpp"
446
447
#include "hal/architecture/Linux/MyMainLinuxGeneric.cpp"
448
449
#include "hal/architecture/STM32F1/MyMainSTM32F1.cpp"
450
451
#include "hal/architecture/Teensy3/MyMainTeensy3.cpp"
452
454
MyConfig.h
MySensors specific configuration flags.Set these in your sketch before including MySensors....
MyHwHAL.h
MyTransport.h
MySensorsCore.h
MyOTALogging.h
API declaration for MyOTALogging.
MyCapabilities.h
