void | stInitTransition (void) |
| Initialize SM variables and transport HW.
void | stInitUpdate (void) |
| Initialize transport.
void | stParentTransition (void) |
| Find parent.
void | stParentUpdate (void) |
| Verify find parent responses.
void | stIDTransition (void) |
| Send ID request.
void | stIDUpdate (void) |
| Verify ID response and GW link.
void | stUplinkTransition (void) |
| Send uplink ping request.
void | stUplinkUpdate (void) |
| Verify uplink response.
void | stReadyTransition (void) |
| Set transport OK.
void | stReadyUpdate (void) |
| Monitor transport link.
void | stFailureTransition (void) |
| Transport failure and power down radio.
void | stFailureUpdate (void) |
| Re-initialize transport after timeout.
void | transportSwitchSM (transportState_t &newState) |
| Switch SM state. More...
void | transportUpdateSM (void) |
| Update SM state.
uint32_t | transportTimeInState (void) |
| Request time in current SM state. More...
void | transportInvokeSanityCheck (void) |
| Call transport driver sanity check.
void | transportProcessFIFO (void) |
| Process all pending messages in RX FIFO.
void | transportProcessMessage (void) |
| Receive message from RX FIFO and process.
bool | transportAssignNodeID (const uint8_t newNodeId) |
| Assign node ID. More...
bool | transportWait (const uint32_t waitingMS, const uint8_t cmd, const uint8_t msgType) |
| Wait and process messages for a defined amount of time until specified message received. More...
uint8_t | transportPingNode (const uint8_t targetId) |
| Ping node. More...
bool | transportRouteMessage (MyMessage &message) |
| Send and route message according to destination. More...
bool | transportSendRoute (MyMessage &message) |
| Send and route message according to destination with transport state check. More...
bool | transportSendWrite (const uint8_t to, MyMessage &message) |
| Send message to recipient. More...
bool | transportCheckUplink (const bool force=false) |
| Check uplink to GW, includes flooding control. More...
bool | transportWaitUntilReady (const uint32_t waitingMS=0) |
| Wait until transport is ready. More...
void | transportInitialise (void) |
| Initialize transport and SM.
void | transportProcess (void) |
| Process FIFO msg and update SM.
bool | isTransportReady (void) |
| Flag transport ready. More...
bool | isTransportSearchingParent (void) |
| Flag searching parent ongoing. More...
bool | isTransportExtendedFailure (void) |
| Flag TSM extended failure. More...
bool | isMessageReceived (void) |
| Flag valid message received. More...
void | resetMessageReceived (void) |
| Reset message received flag.
void | transportClearRoutingTable (void) |
| Clear routing table.
uint32_t | transportGetHeartbeat (void) |
| Return heart beat. More...
void | transportLoadRoutingTable (void) |
| Load routing table from EEPROM to RAM. Only for GW devices with enough RAM, i.e. ESP8266, RPI Sensebender GW, etc. Atmega328 has only limited amount of RAM.
void | transportSaveRoutingTable (void) |
| Save routing table to EEPROM.
void | transportSetRoute (const uint8_t node, const uint8_t route) |
| Update routing table. More...
uint8_t | transportGetRoute (const uint8_t node) |
| Load route to node. More...
void | transportReportRoutingTable (void) |
| Reports content of routing table.
uint8_t | transportGetNodeId (void) |
| Get node ID. More...
uint8_t | transportGetParentNodeId (void) |
| Get parent node ID. More...
uint8_t | transportGetDistanceGW (void) |
| Get distance to GW. More...
void | transportTogglePassiveMode (const bool OnOff) |
| Toggle passive mode, i.e. transport does not wait for ACK. More...
void | transportDisable (void) |
| Disable transport, if xxx_POWER_PIN is defined, transport is powered down, else send to sleep.
void | transportReInitialise (void) |
| Reinitialise transport. Put transport to standby - If xxx_POWER_PIN set, power up and go to standby.
int16_t | transportSignalReport (const char command) __attribute__((unused)) |
| Get transport signal report. More...
int16_t | transportGetSignalReport (const signalReport_t signalReport) __attribute__((unused)) |
