drivers
AltSoftSerial
examples
Echo
Echo.ino
#include <AltSoftSerial.h>
// AltSoftSerial always uses these pins:
// Board Transmit Receive PWM Unusable
// Teensy 3.0 & 3.1 21 20 22
// Teensy 2.0 9 10 (none)
// Teensy++ 2.0 25 4 26, 27
// Arduino Uno 9 8 10
// Arduino Leonardo 5 13 (none)
// Arduino Mega 46 48 44, 45
// Wiring-S 5 6 4
// Sanguino 13 14 12
// This example code is in the public domain.
AltSoftSerial
altSerial;
void
Serial.
begin
(9600);
while
(!Serial) ;
// wait for Arduino Serial Monitor to open
Serial.println(
"AltSoftSerial Test Begin"
altSerial.
begin
(9600);
altSerial.println(
"Hello World"
void
char
c;
if
(Serial.
available
c = Serial.
read
altSerial.print(c);
if
(altSerial.
available
c = altSerial.
read
Serial.print(c);
AltSoftSerial::read
int read()
read
Definition:
Echo.ino:28
StdInOutStream::begin
void begin(int baud)
This function does nothing.
AltSoftSerial
Definition:
AltSoftSerial.h:43
AltSoftSerial::available
int available()
available
Definition:
Echo.ino:20
AltSoftSerial::begin
static void begin(uint32_t baud)
Definition:
AltSoftSerial.h:51
StdInOutStream::available
int available()
StdInOutStream::read
int read()
Reads 1 key pressed from the keyboard.
