examples
GatewayESP32
GatewayESP32.ino
* Created by Henrik Ekblad <
[email protected]
* REVISION HISTORY
* Version 1.0 - tekka
* The ESP32 gateway sends data received from sensors to the WiFi link.
* The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
* Make sure to fill in your ssid and WiFi password below.
#define MY_GATEWAY_ESP32
#define MY_WIFI_SSID "MySSID"
// Enable UDP communication
//#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
// passed to the DHCP server if not static.
#define MY_HOSTNAME "ESP32_GW"
//#define MY_IP_ADDRESS 192,168,1,100
//#define MY_IP_GATEWAY_ADDRESS 192,168,1,1
// The port to keep open on node server mode
#define MY_PORT 5003
// How many clients should be able to connect to this gateway (default 1)
#define MY_GATEWAY_MAX_CLIENTS 2
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
//#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
#include <
void
void
void
Definition:
GatewayESP32.ino:81
Definition:
GatewayESP32.ino:76
Definition:
GatewayESP32.ino:71
