examples
GatewayESP8266MQTTClient
GatewayESP8266MQTTClient.ino
* Created by Henrik Ekblad <
[email protected]
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
* The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
* LED purposes:
* - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
* See https://www.mysensors.org/build/connect_radio for wiring instructions.
* If you are using a "barebone" ESP8266, see
* https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
* Inclusion mode button:
* - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
#define MY_GATEWAY_ESP8266
// Set this node's subscribe and publish topic prefix
// Set MQTT client id
// Enable these if your MQTT broker requires username/password
//#define MY_MQTT_PASSWORD "password"
// Set WIFI SSID and password
#define MY_WIFI_SSID "MySSID"
// passed to the DHCP server if not static.
#define MY_HOSTNAME "ESP8266_MQTT_GW"
// MQTT broker ip address.
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
//MQTT broker if using URL instead of ip address.
// #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
// The MQTT broker port to to open
#define MY_PORT 1883
// Enable inclusion mode
//#define MY_INCLUSION_MODE_DURATION 60
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
// Set blinking period
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
#include <
void
void
123
void
126
128
Definition:
GatewayESP8266MQTTClient.ino:125
Definition:
GatewayESP8266MQTTClient.ino:120
Definition:
GatewayESP8266MQTTClient.ino:115
