examples
GatewayESP8266
GatewayESP8266.ino
* Created by Henrik Ekblad <
[email protected]
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* Contribution by a-lurker and Anticimex,
* Contribution by Norbert Truchsess <
[email protected]
* Contribution by Ivo Pullens (ESP8266 support)
* The EthernetGateway sends data received from sensors to the WiFi link.
* The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
* VERA CONFIGURATION:
* Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
* E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
* LED purposes:
* - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
* See https://www.mysensors.org/build/connect_radio for wiring instructions.
* If you are using a "barebone" ESP8266, see
* https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
* Inclusion mode button:
* - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
#define MY_GATEWAY_ESP8266
#define MY_WIFI_SSID "MySSID"
// Enable UDP communication
//#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
// it will pass to the DHCP server if not static.
#define MY_HOSTNAME "ESP8266_GW"
// The port to keep open on node server mode
#define MY_PORT 5003
// How many clients should be able to connect to this gateway (default 1)
#define MY_GATEWAY_MAX_CLIENTS 2
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
//#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
// Enable inclusion mode
//#define MY_INCLUSION_MODE_DURATION 60
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
// Set blinking period
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
// Led pins used if blinking feature is enabled above
#include <
void
void
123
126
void
128
Definition:
GatewayESP8266.ino:126
Definition:
GatewayESP8266.ino:121
Definition:
GatewayESP8266.ino:116
