examples
GatewaySerialRS485
GatewaySerialRS485.ino
// Enable RS485 transport layer
#define MY_RS485
// Define this to enables DE-pin management on defined pin
#define MY_RS485_DE_PIN 2
// Set RS485 baud rate to use
#define MY_RS485_BAUD_RATE 9600
// Enable this if RS485 is connected to a hardware serial port
//#define MY_RS485_HWSERIAL Serial1
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Enable inclusion mode
#define MY_INCLUSION_MODE_BUTTON_PIN 3
// Set blinking period
// Flash leds on rx/tx/err
#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
#define MY_DEFAULT_RX_LED_PIN 5 // Receive led pin
#define MY_DEFAULT_TX_LED_PIN 6 // the PCB, on board LED
#include <
void
void
// Present locally attached sensors
void
// Send locally attached sensor data here
Definition:
GatewaySerialRS485.ino:101
Definition:
GatewaySerialRS485.ino:96
Definition:
GatewaySerialRS485.ino:91
