examples
LogOTAGateway
LogOTAGateway.ino
// Enable OTA log display
#define MY_OTA_LOG_RECEIVER_FEATURE
//#define MY_RADIO_NRF5_ESB
// Set LOW transmit power level as default, if you have an amplified NRF-module and
// power your radio separately with a good regulator you can turn up PA level.
#define MY_RF24_PA_LEVEL RF24_PA_LOW
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
// Enable inclusion mode
// Inverses behavior of inclusion button (if using external pullup)
//#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
//#define MY_INCLUSION_MODE_BUTTON_PIN 3
// Set blinking period
// Inverses the behavior of leds
//#define MY_WITH_LEDS_BLINKING_INVERSE
// Flash leds on rx/tx/err
//#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
//#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
#include <
void
void
// Present locally attached sensors
void
// Send locally attached sensor data here
Definition:
LogOTAGateway.ino:104
Definition:
LogOTAGateway.ino:99
Definition:
LogOTAGateway.ino:94
