core
MyEepromAddresses.h
* Created by Henrik Ekblad <
[email protected]
#ifndef MyEepromAddresses_h
#define MyEepromAddresses_h
// EEPROM variable sizes, in bytes
#define SIZE_NODE_ID (1u)
#define SIZE_PARENT_NODE_ID (1u)
#define SIZE_DISTANCE (1u)
#define SIZE_ROUTES (256u)
#define SIZE_CONTROLLER_CONFIG (23u)
#define SIZE_PERSONALIZATION_CHECKSUM (1u)
#define SIZE_FIRMWARE_TYPE (2u)
#define SIZE_FIRMWARE_VERSION (2u)
#define SIZE_FIRMWARE_BLOCKS (2u)
#define SIZE_FIRMWARE_CRC (2u)
#define SIZE_SIGNING_REQUIREMENT_TABLE (32u)
#define SIZE_WHITELIST_REQUIREMENT_TABLE (32u)
#define SIZE_SIGNING_SOFT_HMAC_KEY (32u)
#define SIZE_SIGNING_SOFT_SERIAL (9u)
#define SIZE_RF_ENCRYPTION_AES_KEY (16u)
#define SIZE_NODE_LOCK_COUNTER (1u)
#define EEPROM_START (0u)
#define EEPROM_NODE_ID_ADDRESS EEPROM_START
#define EEPROM_PARENT_NODE_ID_ADDRESS (EEPROM_NODE_ID_ADDRESS + SIZE_NODE_ID)
#define EEPROM_DISTANCE_ADDRESS (EEPROM_PARENT_NODE_ID_ADDRESS + SIZE_PARENT_NODE_ID)
#define EEPROM_ROUTES_ADDRESS (EEPROM_DISTANCE_ADDRESS + SIZE_DISTANCE)
#define EEPROM_CONTROLLER_CONFIG_ADDRESS (EEPROM_ROUTES_ADDRESS + SIZE_ROUTES)
#define EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS (EEPROM_CONTROLLER_CONFIG_ADDRESS + SIZE_CONTROLLER_CONFIG)
#define EEPROM_FIRMWARE_TYPE_ADDRESS (EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS + SIZE_PERSONALIZATION_CHECKSUM)
#define EEPROM_FIRMWARE_VERSION_ADDRESS (EEPROM_FIRMWARE_TYPE_ADDRESS + SIZE_FIRMWARE_TYPE)
#define EEPROM_FIRMWARE_BLOCKS_ADDRESS (EEPROM_FIRMWARE_VERSION_ADDRESS + SIZE_FIRMWARE_VERSION)
#define EEPROM_FIRMWARE_CRC_ADDRESS (EEPROM_FIRMWARE_BLOCKS_ADDRESS + SIZE_FIRMWARE_BLOCKS)
#define EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS (EEPROM_FIRMWARE_CRC_ADDRESS + SIZE_FIRMWARE_CRC)
#define EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS (EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS + SIZE_SIGNING_REQUIREMENT_TABLE)
#define EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS (EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS + SIZE_WHITELIST_REQUIREMENT_TABLE)
#define EEPROM_SIGNING_SOFT_SERIAL_ADDRESS (EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS + SIZE_SIGNING_SOFT_HMAC_KEY)
#define EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS (EEPROM_SIGNING_SOFT_SERIAL_ADDRESS + SIZE_SIGNING_SOFT_SERIAL)
#define EEPROM_NODE_LOCK_COUNTER_ADDRESS (EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS + SIZE_RF_ENCRYPTION_AES_KEY)
#define EEPROM_LOCAL_CONFIG_ADDRESS (EEPROM_NODE_LOCK_COUNTER_ADDRESS + SIZE_NODE_LOCK_COUNTER)
#endif // MyEepromAddresses_h
