#define | SIZE_NODE_ID (1u) |
| Size node ID.
#define | SIZE_PARENT_NODE_ID (1u) |
| Size parent node ID.
#define | SIZE_DISTANCE (1u) |
| Size GW distance.
#define | SIZE_ROUTES (256u) |
| Size routing table.
#define | SIZE_CONTROLLER_CONFIG (23u) |
| Size controller config.
#define | SIZE_PERSONALIZATION_CHECKSUM (1u) |
| Size personalization checksum.
#define | SIZE_FIRMWARE_TYPE (2u) |
| Size firmware type.
#define | SIZE_FIRMWARE_VERSION (2u) |
| Size firmware version.
#define | SIZE_FIRMWARE_BLOCKS (2u) |
| Size firmware blocks.
#define | SIZE_FIRMWARE_CRC (2u) |
| Size firmware CRC.
#define | SIZE_SIGNING_REQUIREMENT_TABLE (32u) |
| Size signing requirement table.
#define | SIZE_WHITELIST_REQUIREMENT_TABLE (32u) |
| Size whitelist requirement table.
#define | SIZE_SIGNING_SOFT_HMAC_KEY (32u) |
| Size soft signing HMAC key.
#define | SIZE_SIGNING_SOFT_SERIAL (9u) |
| Size soft signing serial.
#define | SIZE_RF_ENCRYPTION_AES_KEY (16u) |
| Size RF AES encryption key.
#define | SIZE_NODE_LOCK_COUNTER (1u) |
| Size node lock counter.
#define | EEPROM_START (0u) |
| EEPROM start address.
#define | EEPROM_NODE_ID_ADDRESS EEPROM_START |
| Address node ID.
#define | EEPROM_PARENT_NODE_ID_ADDRESS (EEPROM_NODE_ID_ADDRESS + SIZE_NODE_ID) |
| Address parent node ID.
#define | EEPROM_DISTANCE_ADDRESS (EEPROM_PARENT_NODE_ID_ADDRESS + SIZE_PARENT_NODE_ID) |
| Address distance to GW.
#define | EEPROM_ROUTES_ADDRESS (EEPROM_DISTANCE_ADDRESS + SIZE_DISTANCE) |
| Address routing table.
#define | EEPROM_CONTROLLER_CONFIG_ADDRESS (EEPROM_ROUTES_ADDRESS + SIZE_ROUTES) |
| Address configuration bytes sent by controller.
#define | EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS (EEPROM_CONTROLLER_CONFIG_ADDRESS + SIZE_CONTROLLER_CONFIG) |
| Personalization checksum (set by SecurityPersonalizer.ino)
#define | EEPROM_FIRMWARE_TYPE_ADDRESS (EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS + SIZE_PERSONALIZATION_CHECKSUM) |
| Address firmware type.
#define | EEPROM_FIRMWARE_VERSION_ADDRESS (EEPROM_FIRMWARE_TYPE_ADDRESS + SIZE_FIRMWARE_TYPE) |
| Address firmware version.
#define | EEPROM_FIRMWARE_BLOCKS_ADDRESS (EEPROM_FIRMWARE_VERSION_ADDRESS + SIZE_FIRMWARE_VERSION) |
| Address firmware blocks.
#define | EEPROM_FIRMWARE_CRC_ADDRESS (EEPROM_FIRMWARE_BLOCKS_ADDRESS + SIZE_FIRMWARE_BLOCKS) |
| Address firmware CRC.
#define | EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS (EEPROM_FIRMWARE_CRC_ADDRESS + SIZE_FIRMWARE_CRC) |
| Address signing requirement table.
#define | EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS (EEPROM_SIGNING_REQUIREMENT_TABLE_ADDRESS + SIZE_SIGNING_REQUIREMENT_TABLE) |
| Address whitelist requirement table.
#define | EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS (EEPROM_WHITELIST_REQUIREMENT_TABLE_ADDRESS + SIZE_WHITELIST_REQUIREMENT_TABLE) |
| Address soft signing HMAC key. This is set with SecurityPersonalizer.ino.
#define | EEPROM_SIGNING_SOFT_SERIAL_ADDRESS (EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS + SIZE_SIGNING_SOFT_HMAC_KEY) |
| Address soft signing serial key. This is set with SecurityPersonalizer.ino.
#define | EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS (EEPROM_SIGNING_SOFT_SERIAL_ADDRESS + SIZE_SIGNING_SOFT_SERIAL) |
| Address RF AES encryption key. This is set with SecurityPersonalizer.ino.
#define | EEPROM_NODE_LOCK_COUNTER_ADDRESS (EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS + SIZE_RF_ENCRYPTION_AES_KEY) |
| Address node lock counter. This is set with SecurityPersonalizer.ino.
#define | EEPROM_LOCAL_CONFIG_ADDRESS (EEPROM_NODE_LOCK_COUNTER_ADDRESS + SIZE_NODE_LOCK_COUNTER) |
| First free address for sketch static configuration.
