Security personalization sketch.
REVISION HISTORY
Definition in file SecurityPersonalizer.ino.
#define | MY_CORE_ONLY |
Make use of the MySensors framework without invoking the entire system. | |
#define | MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 |
The user-defined HMAC key to use unless GENERATE_HMAC_KEY is set. | |
#define | MY_AES_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 |
The user-defined AES key to store in EEPROM unless GENERATE_AES_KEY is set. | |
#define | MY_SOFT_SERIAL 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF |
The user-defined soft serial to use for soft signing unless GENERATE_SOFT_SERIAL is set. | |
#define | NO_SETTINGS_DEFINED |
Set when there are no config flags defined. | |
#define | GENERATE_KEYS_ATSHA204A |
Default settings for generating keys using ATSHA204A. More... | |
#define | GENERATE_KEYS_SOFT |
Default settings for generating keys using software. More... | |
#define | PERSONALIZE_ATSHA204A |
Default settings for personalizing an ATSHA204A. More... | |
#define | PERSONALIZE_SOFT |
Default settings for personalizing EEPROM for software signing. More... | |
#define | PERSONALIZE_SOFT_RANDOM_SERIAL |
This is an alternative to PERSONALIZE_SOFT which will also store a randomly generated serial to EEPROM in addition to the actions performed by PERSONALIZE_SOFT. Take note of the generated soft serial as it will be needed if you plan to use whitelisting. It should be unique for each node. More... | |
#define | USE_SOFT_SIGNING |
Uncomment this to generate keys by software and store them to EEPROM instead of ATSHA204A. | |
#define | LOCK_ATSHA204A_CONFIGURATION |
Uncomment this to enable locking the ATSHA204A configuration zone. More... | |
#define | SKIP_UART_CONFIRMATION |
Uncomment this for boards that lack UART. More... | |
#define | GENERATE_HMAC_KEY |
Uncomment this to generate a random HMAC key using ATSHA204A or software depending on USE_SOFT_SIGNING. More... | |
#define | STORE_HMAC_KEY |
Uncomment this to store HMAC key to ATSHA204A or EEPROM depending on USE_SOFT_SIGNING. | |
#define | GENERATE_AES_KEY |
Uncomment this to generate a random AES key using ATSHA204A or software depending on USE_SOFT_SIGNING. More... | |
#define | STORE_AES_KEY |
Uncomment this to store AES key to EEPROM. | |
#define | GENERATE_SOFT_SERIAL |
Uncomment this to generate a random serial number for software signing. More... | |
#define | STORE_SOFT_SERIAL |
Uncomment this to store the serial number to EEPROM. | |
#define | PRINT_DETAILED_ATSHA204A_CONFIG |
Uncomment to print the detailed ATSHA204A configuration. | |
#define | RESET_EEPROM_PERSONALIZATION |
Uncomment to reset the personalization data in EEPROM to 0xFF:es. | |
const int | sha204Pin = MY_SIGNING_ATSHA204_PIN |
The IO pin to use for ATSHA204A. | |
atsha204Class | sha204 (sha204Pin) |
atsha204Class | |
void | setup () |
Sketch setup code (all personalization is done here as it is a run-once sketch) More... | |
void | loop () |
Sketch execution code (unused) More... | |
#define GENERATE_AES_KEY |
Definition at line 1864 of file SecurityPersonalizer.ino.
#define GENERATE_HMAC_KEY |
Definition at line 1862 of file SecurityPersonalizer.ino.
#define GENERATE_KEYS_ATSHA204A |
Definition at line 1854 of file SecurityPersonalizer.ino.
#define GENERATE_KEYS_SOFT |
Important
You will need to ensure MY_SIGNING_SOFT_RANDOMSEED_PIN is set to an unconnected analog pin in order to provide entropy to the software RNG if your hardware has no HWRNG.
Definition at line 1855 of file SecurityPersonalizer.ino.
#define GENERATE_SOFT_SERIAL |
Definition at line 1866 of file SecurityPersonalizer.ino.
#define LOCK_ATSHA204A_CONFIGURATION |
It is still possible to change the key, and this also enable random key generation.
Definition at line 1860 of file SecurityPersonalizer.ino.
#define PERSONALIZE_ATSHA204A |
It is assumed that you have updated MY_HMAC_KEY and MY_AES_KEY with the keys displayed when executing this sketch with GENERATE_KEYS_ATSHA204A or GENERATE_KEYS_SOFT defined.
Definition at line 1856 of file SecurityPersonalizer.ino.
#define PERSONALIZE_SOFT |
Definition at line 1857 of file SecurityPersonalizer.ino.
#define PERSONALIZE_SOFT_RANDOM_SERIAL |
Definition at line 1858 of file SecurityPersonalizer.ino.
#define SKIP_UART_CONFIRMATION |
This will disable additional confirmation for actions that are non-reversible.
Important
For ATSHA204A, no confirmation will be required for locking any zones with this configuration! Also, if you generate keys on a board without UART, you have no way of determining what the key is unless it is stored in EEPROM.
Definition at line 1861 of file SecurityPersonalizer.ino.
