SecurityPersonalizer.ino
This sketch will personalize either none-volatile memory or ATSHA204A for security functions available in the MySensors library.
Details on personalization procedure is given in personalization.
This sketch will when executed without modifications also print a guided workflow on the UART.
* Created by Henrik Ekblad <[email protected]>
#include "sha204_library.h"
#define MY_CORE_ONLY
/************************************ User defined key data ***************************************/
#define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
#define MY_AES_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
#define MY_SOFT_SERIAL 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
/***************************** Flags for guided personalization flow ******************************/
//#define GENERATE_KEYS_ATSHA204A
//#define GENERATE_KEYS_SOFT
//#define PERSONALIZE_ATSHA204A
//#define PERSONALIZE_SOFT
//#define PERSONALIZE_SOFT_RANDOM_SERIAL
/*************************** The settings below are for advanced users ****************************/
//#define USE_SOFT_SIGNING
//#define LOCK_ATSHA204A_CONFIGURATION
//#define SKIP_UART_CONFIRMATION
//#define GENERATE_HMAC_KEY
//#define STORE_HMAC_KEY
//#define GENERATE_AES_KEY
//#define STORE_AES_KEY
//#define GENERATE_SOFT_SERIAL
//#define STORE_SOFT_SERIAL
//#define PRINT_DETAILED_ATSHA204A_CONFIG
//#define RESET_EEPROM_PERSONALIZATION
/********************* Guided mode flag configurations (don't change these) ***********************/
#ifdef GENERATE_KEYS_ATSHA204A
#define LOCK_ATSHA204A_CONFIGURATION // We have to lock configuration to enable random number generation
#define GENERATE_HMAC_KEY // Generate random HMAC key
#define GENERATE_AES_KEY // Generate random AES key
#define SKIP_UART_CONFIRMATION // This is an automated mode
#ifdef GENERATE_KEYS_SOFT
#define USE_SOFT_SIGNING // Use software backend
#ifdef PERSONALIZE_ATSHA204A
#define STORE_HMAC_KEY // Store the HMAC key
#define STORE_AES_KEY // Store the AES key
#ifdef PERSONALIZE_SOFT_RANDOM_SERIAL
#define GENERATE_SOFT_SERIAL // Generate a soft serial number
#define PERSONALIZE_SOFT // Do the rest as PERSONALIZE_SOFT
#define STORE_SOFT_SERIAL // Store the soft serial number
#if defined(GENERATE_HMAC_KEY) || defined(GENERATE_AES_KEY) || defined(GENERATE_SOFT_SERIAL)
#define GENERATE_SOMETHING
#if defined(MY_LOCK_MCU)
#undefine MY_LOCK_MCU // The Sketch after SecurityPersonaliter should lock the MCU
/********************************** Preprocessor sanitychecks *************************************/
#if defined(GENERATE_SOFT_SERIAL) && !defined(USE_SOFT_SIGNING)
#error Cannot generate soft serial using ATSHA204A, use USE_SOFT_SINGING for this
#if defined(STORE_SOFT_SERIAL) && !defined(USE_SOFT_SIGNING)
#error Cannot store soft serial to ATSHA204A, use USE_SOFT_SINGING for this
#if defined(PRINT_DETAILED_ATSHA204A_CONFIG) && defined(USE_SOFT_SIGNING)
#error Cannot print ATSHA204A config using software signing flag, disable USE_SOFT_SINGING for this
#if defined(LOCK_ATSHA204A_CONFIGURATION) && defined(USE_SOFT_SIGNING)
#error Cannot lock ATSHA204A config using software signing flag, disable USE_SOFT_SINGING for this
#ifdef USE_SOFT_SIGNING
#error You cannot select soft signing if you want to generate keys using ATSHA204A
#ifdef STORE_HMAC_KEY
#error Disable STORE_SOFT_KEY, you should not store keys in this mode
#ifdef STORE_SOFT_SERIAL
#error Disable STORE_SOFT_SERIAL, you should not store serial in this mode
#ifdef STORE_AES_KEY
#error Disable STORE_AES_KEY, you should not store keys in this mode
#if defined(GENERATE_KEYS_SOFT) ||\
defined (PERSONALIZE_ATSHA204A) ||\
defined (PERSONALIZE_SOFT) ||\
defined (PERSONALIZE_SOFT_RANDOM_SERIAL)
#error You can not enable GENERATE_KEYS_ATSHA204A together with other guided modes
#endif // GENERATE_KEYS_ATSHA204A
#ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
#error You have to set MY_SIGNING_SOFT_RANDOMSEED_PIN to a suitable value in this mode
#if defined(GENERATE_KEYS_ATSHA204A) ||\
#error You can not enable GENERATE_KEYS_SOFT together with other guided modes
#endif // GENERATE_KEYS_SOFT
#error You cannot select soft signing if you want to personalize an ATSHA204A
defined (GENERATE_KEYS_SOFT) ||\
#error You can not enable PERSONALIZE_ATSHA204A together with other guided modes
#ifdef RESET_EEPROM_PERSONALIZATION
#error You cannot reset EEPROM personalization when personalizing a device
#endif // PERSONALIZE_ATSHA204A
#error You can not enable PERSONALIZE_SOFT together with other guided modes
#endif // PERSONALIZE_SOFT
defined (GENERATE_KEYS_ATSHA204A)
#error You can only enable one of the guided modes at a time
#endif // PERSONALIZE_SOFT_RANDOM_SERIAL
#if !defined(GENERATE_KEYS_ATSHA204A) &&\
!defined(GENERATE_KEYS_SOFT) &&\
!defined(PERSONALIZE_ATSHA204A) &&\
!defined(PERSONALIZE_SOFT) &&\
!defined(PERSONALIZE_SOFT_RANDOM_SERIAL) &&\
!defined(USE_SOFT_SIGNING) &&\
!defined(LOCK_ATSHA204A_CONFIGURATION) &&\
!defined(SKIP_UART_CONFIRMATION) &&\
!defined(GENERATE_HMAC_KEY) &&\
!defined(STORE_HMAC_KEY) &&\
!defined(GENERATE_SOFT_SERIAL) &&\
!defined(STORE_SOFT_SERIAL) &&\
!defined(GENERATE_AES_KEY) &&\
!defined(STORE_AES_KEY) &&\
!defined(PRINT_DETAILED_ATSHA204A_CONFIG) &&\
!defined(RESET_EEPROM_PERSONALIZATION)
#define NO_SETTINGS_DEFINED
defined(PERSONALIZE_ATSHA204A) ||\
defined(PERSONALIZE_SOFT) ||\
#define GUIDED_MODE
/************************************* Function declarations ***************************************/
static void halt(bool success);
#ifdef GENERATE_SOMETHING
static bool generate_random_data(uint8_t* data, size_t sz);
static void generate_keys(void);
static void store_keys(void);
static void print_hex_buffer(uint8_t* data, size_t sz);
static void print_c_friendly_hex_buffer(uint8_t* data, size_t sz);
static bool store_hmac_key_data(uint8_t* data, size_t sz);
static bool store_aes_key_data(uint8_t* data, size_t sz);
static bool store_soft_serial_data(uint8_t* data, size_t sz);
#ifndef USE_SOFT_SIGNING
static void init_atsha204a_state(void);
#ifdef LOCK_ATSHA204A_CONFIGURATION
static void lock_atsha204a_config(void);
static uint16_t write_atsha204a_config_and_get_crc(void);
static bool get_atsha204a_serial(uint8_t* data);
static bool write_atsha204a_key(uint8_t* key);
#endif // not USE_SOFT_SIGNING
static void print_greeting(void);
static void print_ending(void);
static void probe_and_print_peripherals(void);
static void print_eeprom_data(void);
static void print_whitelisting_entry(void);
#ifdef PRINT_DETAILED_ATSHA204A_CONFIG
static void dump_detailed_atsha204a_configuration(void);
static void reset_eeprom(void);
static void write_eeprom_checksum(void);
/**************************************** File local data *****************************************/
#if defined(GENERATE_HMAC_KEY) || defined(STORE_HMAC_KEY)
static uint8_t user_hmac_key[32] = {MY_HMAC_KEY};
#if defined(GENERATE_SOFT_SERIAL) || defined(STORE_SOFT_SERIAL)
static uint8_t user_soft_serial[9] = {MY_SOFT_SERIAL};
#if defined(GENERATE_AES_KEY) || defined(STORE_AES_KEY)
/* @brief The data to store as AES key in EEPROM */
static uint8_t user_aes_key[16] = {MY_AES_KEY};
static uint8_t tx_buffer[SHA204_CMD_SIZE_MAX];
static uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
static uint8_t ret_code;
static uint8_t lockConfig = 0;
static uint8_t lockValue = 0;
static bool has_device_unique_id = false;
static const uint8_t reset_buffer[32] = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
/******************************************* Functions ********************************************/
// Delay startup a bit for serial consoles to catch up
uint32_t enter = hwMillis();
while (hwMillis() - enter < (uint32_t)500);
// initialize pseudo-RNG
hwRandomNumberInit();
while(!Serial); // For USB enabled devices, wait for USB enumeration before continuing
print_greeting();
init_atsha204a_state();
// Lock configuration now if requested to enable RNG in ATSHA
lock_atsha204a_config();
// Generate the requested keys (if any)
generate_keys();
// If requested, reset EEPROM before storing keys
reset_eeprom();
// Store the keys (if configured to do so)
store_keys();
// Write a checksum on the EEPROM data
write_eeprom_checksum();
// Print current EEPROM
print_eeprom_data();
print_whitelisting_entry();
Serial.println();
print_ending();
halt(true);
Serial.println();
Serial.println(
F("+------------------------------------------------------------------------------------+"));
Serial.println(
F("| Execution result |"));
Serial.println(
if (success) {
Serial.println(F(
"| SUCCESS |"));
} else {
Serial.print(F(
"| FAILURE "));
Serial.println(F(" |"));
#else
if (ret_code != SHA204_SUCCESS) {
Serial.print(F("(last ATSHA204A return code: 0x"));
if (ret_code < 0x10) {
Serial.print('0'); // Because Serial.print does not 0-pad HEX
Serial.print(ret_code, HEX);
Serial.println(F(") |"));
} else {
Serial.println(
while(1) {
#if defined(USE_SOFT_SIGNING) && ! defined(MY_HW_HAS_GETENTROPY)
for (size_t i = 0; i < sz; i++) {
data[i] = random(256) ^ micros();
while (hwMillis() - enter < (uint32_t)2);
return true;
#elif defined(USE_SOFT_SIGNING) && defined(MY_HW_HAS_GETENTROPY)
hwGetentropy(&data, sz);
#else
ret_code = sha204.sha204m_random(tx_buffer, rx_buffer, RANDOM_SEED_UPDATE);
if ((ret_code != SHA204_SUCCESS) || (lockConfig != 0x00)) {
return false;
} else {
memcpy(data, rx_buffer+SHA204_BUFFER_POS_DATA, sz);
return true;
#endif // GENERATE_SOMETHING
Serial.println(
Serial.println(
F("| Key generation |"));
Serial.println(
F("+--------+--------+------------------------------------------------------------------+"));
Serial.println(
F("| Key ID | Status | Key |"));
Serial.println(
#ifdef GENERATE_HMAC_KEY
Serial.print(F("| HMAC | "));
if (!generate_random_data(user_hmac_key, 32)) {
memset(user_hmac_key, 0xFF, 32);
Serial.print(F("FAILED | "));
} else {
Serial.print(F("OK | "));
print_hex_buffer(user_hmac_key, 32);
#ifdef GENERATE_AES_KEY
Serial.print(F("| AES | "));
if (!generate_random_data(user_aes_key, 16)) {
memset(user_aes_key, 0xFF, 16);
} else {
print_hex_buffer(user_aes_key, 16);
#ifdef GENERATE_SOFT_SERIAL
Serial.print(F("| SERIAL | "));
if (has_device_unique_id) {
Serial.println(F("N/A | MCU has a unique serial which will be used instead. |"));
} else {
if (!generate_random_data(user_soft_serial, 9)) {
memset(user_soft_serial, 0xFF, 9);
} else {
print_hex_buffer(user_soft_serial, 9);
#if defined(GENERATE_SOMETHING) && !defined(PERSONALIZE_SOFT_RANDOM_SERIAL)
Serial.println(
Serial.println();
Serial.println(
Serial.println(
F("| Key copy section |"));
Serial.println(
Serial.print(F("#define MY_HMAC_KEY "));
print_c_friendly_hex_buffer(user_hmac_key, 32);
Serial.println();
Serial.print(F("#define MY_AES_KEY "));
print_c_friendly_hex_buffer(user_aes_key, 16);
Serial.println();
Serial.print(F("#define MY_SOFT_SERIAL "));
print_c_friendly_hex_buffer(user_soft_serial, 9);
Serial.println();
Serial.println(
Serial.println();
#elif defined(PERSONALIZE_SOFT_RANDOM_SERIAL)
Serial.println(
Serial.println();
uint8_t validation_buffer[32];
Serial.println(
Serial.println(
F("| EEPROM reset |"));
Serial.println(
F("+--------+---------------------------------------------------------------------------+"));
Serial.println(
F("| Key ID | Status |"));
Serial.println(
hwWriteConfigBlock((void*)reset_buffer, (void*)EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS, 32);
// Validate data written
hwReadConfigBlock((void*)validation_buffer, (void*)EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS, 32);
if (memcmp(validation_buffer, reset_buffer, 32) != 0) {
Serial.println(F("FAILED |"));
} else {
Serial.println(F("OK |"));
hwWriteConfigBlock((void*)reset_buffer, (void*)EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS, 16);
hwReadConfigBlock((void*)validation_buffer, (void*)EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS, 16);
if (memcmp(validation_buffer, reset_buffer, 16) != 0) {
} else {
hwWriteConfigBlock((void*)reset_buffer, (void*)EEPROM_SIGNING_SOFT_SERIAL_ADDRESS, 9);
hwReadConfigBlock((void*)validation_buffer, (void*)EEPROM_SIGNING_SOFT_SERIAL_ADDRESS, 9);
if (memcmp(validation_buffer, reset_buffer, 9) != 0) {
} else {
Serial.println(
#endif // RESET_EEPROM_PERSONALIZATION
uint8_t hash[32];
uint8_t checksum;
hwReadConfigBlock((void*)buffer, (void*)EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS,
hwReadConfigBlock((void*)&buffer[SIZE_SIGNING_SOFT_HMAC_KEY],
hwReadConfigBlock((void*)&buffer[SIZE_SIGNING_SOFT_HMAC_KEY + SIZE_RF_ENCRYPTION_AES_KEY],
hwReadConfigBlock((void*)&checksum, (void*)EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS,
SHA256(hash, buffer, sizeof(buffer));
hwWriteConfigBlock((void*)&hash[0], (void*)EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS,
#if defined(STORE_HMAC_KEY) || defined(STORE_AES_KEY) || defined(STORE_SOFT_SERIAL)
Serial.println(
Serial.println(
F("| Key storage |"));
Serial.println(
Serial.println(
Serial.println(
if (!store_hmac_key_data(user_hmac_key)) {
} else {
if (!store_aes_key_data(user_aes_key)) {
} else {
if (!store_soft_serial_data(user_soft_serial)) {
} else {
Serial.println(F("EEPROM reset. MCU has a unique serial which will be used instead.|"));
} else {
Serial.println(
Serial.println();
for (size_t i=0; i<sz; i++) {
if (data[i] < 0x10) {
Serial.print(data[i], HEX);
Serial.print("0x");
if (i < sz-1) {
Serial.print(',');
static bool store_hmac_key_data(uint8_t* data)
static uint8_t validation_buffer[32];
hwWriteConfigBlock((void*)data, (void*)EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS, 32);
if (memcmp(validation_buffer, data, 32) != 0) {
return false;
} else {
return true;
#else
// It will not be possible to write the key if the configuration zone is unlocked
if (lockConfig == 0x00) {
// Write the key to the appropriate slot in the data zone
if (!write_atsha204a_key(data)) {
return false;
} else {
return true;
} else {
return false;
static bool store_aes_key_data(uint8_t* data)
static uint8_t validation_buffer[16];
hwWriteConfigBlock((void*)data, (void*)EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS, 16);
if (memcmp(validation_buffer, data, 16) != 0) {
return false;
} else {
return true;
#endif // STORE_AES_KEY
static bool store_soft_serial_data(uint8_t* data)
static uint8_t validation_buffer[9];
hwWriteConfigBlock((void*)data, (void*)EEPROM_SIGNING_SOFT_SERIAL_ADDRESS, 9);
if (memcmp(validation_buffer, data, 9) != 0) {
return false;
} else {
return true;
#endif // STORE_SOFT_SERIAL
// Read out lock config bits to determine if locking is possible
ret_code = sha204.sha204m_read(tx_buffer, rx_buffer, SHA204_ZONE_CONFIG, 0x15<<2);
halt(false);
} else {
lockConfig = rx_buffer[SHA204_BUFFER_POS_DATA+3];
lockValue = rx_buffer[SHA204_BUFFER_POS_DATA+2];
Serial.println(
Serial.println(
F("| ATSHA204A configuration locking |"));
Serial.println(
if (lockConfig != 0x00) {
uint16_t crc;
(void)crc;
// Write config and get CRC for the updated config
crc = write_atsha204a_config_and_get_crc();
// List current configuration before attempting to lock
Serial.println(
F("| New ATSHA204A Configuration |"));
dump_detailed_atsha204a_configuration();
#endif // PRINT_DETAILED_ATSHA204A_CONFIG
#ifndef SKIP_UART_CONFIRMATION
// Purge serial input buffer
while (Serial.available()) {
Serial.read();
Serial.println(
F("| * Send SPACE character now to lock the configuration... |"));
while (Serial.available() == 0);
if (Serial.read() == ' ')
#endif //not SKIP_UART_CONFIRMATION
Serial.print(F("| * Locking configuration..."));
// Correct sequence, resync chip
ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
Serial.println(
halt(false);
// Lock configuration zone
ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
crc, 0, NULL, 0, NULL, 0, NULL,
LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
Serial.println(F("Failed |"));
Serial.println(
halt(false);
} else {
Serial.println(F("Done |"));
// Update lock flags after locking
Serial.println(
halt(false);
} else {
else {
Serial.println(
F("| * Unexpected answer. Skipping locking. |"));
Serial.println(
} else {
Serial.println(
F("| * Skipping configuration write and lock (configuration already locked). |"));
Serial.println(
Serial.println();
uint16_t crc = 0;
uint8_t config_word[4];
// We will set default settings from datasheet on all slots. This means that we can use slot 0 for the key
// as that slot will not be readable (key will therefore be secure) and slot 8 for the payload digest
// calculationon as that slot can be written in clear text even when the datazone is locked.
// Other settings which are not relevant are kept as is.
for (int i=0; i < 88; i += 4) {
bool do_write = true;
if (i == 20) {
config_word[0] = 0x8F;
config_word[1] = 0x80;
config_word[2] = 0x80;
config_word[3] = 0xA1;
} else if (i == 24) {
config_word[0] = 0x82;
config_word[1] = 0xE0;
config_word[2] = 0xA3;
config_word[3] = 0x60;
} else if (i == 28) {
config_word[0] = 0x94;
config_word[1] = 0x40;
config_word[2] = 0xA0;
config_word[3] = 0x85;
} else if (i == 32) {
config_word[0] = 0x86;
config_word[2] = 0x87;
config_word[3] = 0x07;
} else if (i == 36) {
config_word[0] = 0x0F;
config_word[1] = 0x00;
config_word[2] = 0x89;
config_word[3] = 0xF2;
} else if (i == 40) {
config_word[0] = 0x8A;
config_word[1] = 0x7A;
config_word[2] = 0x0B;
config_word[3] = 0x8B;
} else if (i == 44) {
config_word[0] = 0x0C;
config_word[1] = 0x4C;
config_word[2] = 0xDD;
config_word[3] = 0x4D;
} else if (i == 48) {
config_word[0] = 0xC2;
config_word[1] = 0x42;
config_word[2] = 0xAF;
config_word[3] = 0x8F;
} else if (i == 52 || i == 56 || i == 60 || i == 64) {
config_word[0] = 0xFF;
config_word[2] = 0xFF;
config_word[3] = 0x00;
} else if (i == 68 || i == 72 || i == 76 || i == 80) {
config_word[1] = 0xFF;
config_word[3] = 0xFF;
} else {
// All other configs are untouched
ret_code = sha204.sha204m_read(tx_buffer, rx_buffer, SHA204_ZONE_CONFIG, i);
Serial.println(
halt(false);
// Set config_word to the read data
config_word[0] = rx_buffer[SHA204_BUFFER_POS_DATA+0];
config_word[1] = rx_buffer[SHA204_BUFFER_POS_DATA+1];
config_word[2] = rx_buffer[SHA204_BUFFER_POS_DATA+2];
config_word[3] = rx_buffer[SHA204_BUFFER_POS_DATA+3];
do_write = false;
// Update crc with CRC for the current word
crc = sha204.calculateAndUpdateCrc(4, config_word, crc);
// Write config word
if (do_write) {
ret_code = sha204.sha204m_execute(SHA204_WRITE, SHA204_ZONE_CONFIG,
i >> 2, 4, config_word, 0, NULL, 0, NULL,
WRITE_COUNT_SHORT, tx_buffer, WRITE_RSP_SIZE, rx_buffer);
Serial.println(
halt(false);
return crc;
ret_code = sha204.getSerialNumber(rx_buffer);
return false;
} else {
memcpy(data, rx_buffer, 9);
return true;
// Write key to slot 0
ret_code = sha204.sha204m_execute(SHA204_WRITE, SHA204_ZONE_DATA | SHA204_ZONE_COUNT_FLAG,
0, SHA204_ZONE_ACCESS_32, key, 0, NULL, 0, NULL,
WRITE_COUNT_LONG, tx_buffer, WRITE_RSP_SIZE, rx_buffer);
return false;
} else {
return true;
#endif // STORE_HMAC_KEY
Serial.println(
Serial.println(
F("| MySensors security personalizer |"));
Serial.println(
Serial.println();
#ifdef NO_SETTINGS_DEFINED
Serial.println(
Serial.println(
F("| You are running without any configuration flags set. |"));
Serial.println(
F("| No changes will be made to ATSHA204A or EEPROM except for the EEPROM checksum |"));
Serial.println(
F("| which will be updated. |"));
Serial.println(
F("| |"));
Serial.println(
F("| If you want to personalize your device, you have two options. |"));
Serial.println(
F("| |"));
Serial.println(
F("| 1. a. Enable either GENERATE_KEYS_ATSHA204A or GENERATE_KEYS_SOFT |"));
Serial.println(
F("| This will generate keys for ATSHA204A or software signing. |"));
Serial.println(
F("| b. Execute the sketch. You will be guided through the steps below under |"));
Serial.println(
F("| WHAT TO DO NEXT? |"));
Serial.println(
F("| c. Copy the generated keys and replace the topmost definitions in this file. |"));
Serial.println(
F("| d. Save the sketch and then disable the flag you just enabled. |"));
Serial.println(
F("| e. Enable PERSONALIZE_ATSHA204A to personalize the ATSHA204A device. |"));
Serial.println(
F("| or |"));
Serial.println(
F("| Enable PERSONALIZE_SOFT to personalize the EEPROM for software signing. |"));
Serial.println(
F("| If you want to use whitelisting you need to pick a unique serial number |"));
Serial.println(
F("| for each device you run the sketch on and fill in MY_SOFT_SERIAL. |"));
Serial.println(
F("| or |"));
Serial.println(
F("| Enable PERSONALIZE_SOFT_RANDOM_SERIAL to personalzie the EEPROM and |"));
Serial.println(
F("| include a new random serial number every time the sketch is executed. |"));
Serial.println(
F("| Take note of each saved serial number if you plan to use whitelisting. |"));
Serial.println(
F("| f. Execute the sketch on each device you want to personalize that is supposed |"));
Serial.println(
F("| to communicate securely. |"));
Serial.println(
F("| |"));
Serial.println(
F("| 2. Enable any configuration flag as you see fit. |"));
Serial.println(
F("| It is assumed that you know what you are doing. |"));
Serial.println(
Serial.println();
#else
Serial.println(
Serial.println(
F("| Configuration settings |"));
Serial.println(
Serial.println(
F("| * Guided key generation for ATSHA204A using ATSHA024A |"));
Serial.println(
F("| * Guided key generation for EEPROM using software |"));
#if defined(PERSONALIZE_ATSHA204A)
Serial.println(
F("| * Guided personalization/storage of keys in ATSHA204A |"));
#if defined(PERSONALIZE_SOFT)
Serial.println(
F("| * Guided personalization/storage of keys in EEPROM |"));
#if defined(PERSONALIZE_SOFT_RANDOM_SERIAL)
Serial.println(
F("| * Guided storage and generation of random serial in EEPROM |"));
Serial.println(
F("| * Software based personalization (no ATSHA204A usage whatsoever) |"));
#else
Serial.println(
F("| * ATSHA204A based personalization |"));
Serial.println(
F("| * Will lock ATSHA204A configuration |"));
#if defined(SKIP_UART_CONFIRMATION)
Serial.println(
F("| * Will not require any UART confirmations |"));
Serial.print(
F("| * Will generate HMAC key using "));
Serial.println(
F("software |"));
#else
Serial.println(
F("ATSHA204A |"));
Serial.print(F("| * Will store HMAC key to "));
Serial.println(
F("EEPROM |"));
#else
Serial.println(
F("ATSHA204A |"));
Serial.print(
F("| * Will generate AES key using "));
Serial.println(
F("software |"));
#else
Serial.println(
F("ATSHA204A |"));
#if defined(STORE_AES_KEY)
Serial.println(
F("| * Will store AES key to EEPROM |"));
Serial.println(
F("| * Will generate soft serial using software |"));
Serial.println(
F("| * Will store soft serial to EEPROM |"));
Serial.println(
F("| * Will print detailed ATSHA204A configuration |"));
#if defined(RESET_EEPROM_PERSONALIZATION)
Serial.println(
F("| * Will reset EEPROM personalization data |"));
Serial.println(
Serial.println();
#endif // not NO_SETTINGS_DEFINED
probe_and_print_peripherals();
#if defined(GUIDED_MODE) || defined(NO_SETTINGS_DEFINED)
Serial.println(
Serial.println(
Serial.println(
Serial.println(
F("| To proceed with the personalization, enable GENERATE_KEYS_ATSHA204A or |"));
Serial.println(
F("| GENERATE_KEYS_SOFT depending on what type of signing backend you plan to use. |"));
Serial.println(
F("| Both options will generate an AES key for encryption if you plan to use that. |"));
Serial.println(
F("| Recompile, upload and run the sketch again for further instructions. |"));
Serial.println(
Serial.println(
F("| To proceed with the personalization, copy the keys shown in the Key copy section, |"));
Serial.println(
F("| and replace the corresponding definitions in the top of the sketch, then disable |"));
Serial.println(
F("| GENERATE_KEYS_ATSHA204A and enable PERSONALIZE_ATSHA204A. |"));
Serial.println(
Serial.println(
Serial.println(
Serial.println(
F("| GENERATE_KEYS_SOFT and enable PERSONALIZE_SOFT or PERSONALIZE_SOFT_RANDOM_SERIAL. |"));
Serial.println(
#if defined(PERSONALIZE_ATSHA204A) ||\
Serial.println(
F("| This device has now been personalized. Run this sketch with its current settings |"));
Serial.println(
F("| on all the devices in your network that have security enabled. |"));
Serial.println(
#endif // GUIDED_MODE or NO_SETTINGS_DEFINED
unique_id_t uniqueID;
Serial.println(
Serial.println(
F("| Hardware security peripherals |"));
Serial.println(
F("+--------------+--------------+--------------+------------------------------+--------+"));
Serial.println(
F("| Device | Status | Revision | Serial number | Locked |"));
Serial.println(
#if defined(ARDUINO_ARCH_AVR)
Serial.print(F("| AVR | DETECTED | N/A | "));
#elif defined(ARDUINO_ARCH_ESP8266)
Serial.print(F("| ESP8266 | DETECTED | N/A | "));
#elif defined(ARDUINO_ARCH_SAMD)
Serial.print(F("| SAMD | DETECTED | N/A | "));
#elif defined(ARDUINO_ARCH_STM32F1)
Serial.print(F("| STM32F1 | DETECTED | N/A | "));
#elif defined(__linux__)
Serial.print(F("| Linux | DETECTED | N/A | "));
#else
Serial.print(F("| Unknown | DETECTED | N/A | "));
if (hwUniqueID(&uniqueID)) {
has_device_unique_id = true;
print_hex_buffer(uniqueID, 9);
Serial.println(F(" | N/A |"));
} else {
Serial.println(F("N/A (generation required) | N/A |"));
Serial.println(
Serial.print(F("| ATSHA204A | "));
ret_code = sha204.sha204c_wakeup(rx_buffer);
ret_code = SHA204_SUCCESS; // Reset retcode to avoid false negative execution result
Serial.println(F("NOT DETECTED | N/A | N/A | N/A |"));
} else {
uint8_t buffer[9];
Serial.print(F("DETECTED | "));
ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
} else {
print_hex_buffer(&rx_buffer[SHA204_BUFFER_POS_DATA], 4);
Serial.print(F(" | "));
if (!get_atsha204a_serial(buffer)) {
memset(buffer, 0xFF, 9);
} else {
print_hex_buffer(buffer, 9);
Serial.println("FAILED |");
} else {
if (rx_buffer[SHA204_BUFFER_POS_DATA+3] == 0x00) {
Serial.println("YES |");
} else {
Serial.println("NO |");
Serial.println(
Serial.println(
Serial.println(
F("| Current ATSHA204A Configuration |"));
Serial.println();
uint8_t buffer[32];
Serial.println(
Serial.println(
F("| EEPROM |"));
Serial.println(
Serial.println(
Serial.println(
hwReadConfigBlock((void*)buffer, (void*)EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS, 32);
if (!memcmp(buffer, reset_buffer, 32)) {
Serial.print(F("RESET | "));
} else {
print_hex_buffer(buffer, 32);
hwReadConfigBlock((void*)buffer, (void*)EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS, 16);
if (!memcmp(buffer, reset_buffer, 16)) {
} else {
print_hex_buffer(buffer, 16);
hwReadConfigBlock((void*)buffer, (void*)EEPROM_SIGNING_SOFT_SERIAL_ADDRESS, 9);
if (!memcmp(buffer, reset_buffer, 9)) {
Serial.println(F("N/A | Device unique serial, not stored in EEPROM |"));
} else {
} else {
Serial.println(
Serial.println();
uint8_t buffer[9];
// Serial reset in EEPROM, check for unique ID
memcpy(buffer, uniqueID, 9);
#else
// If ATSHA204A is used, use that serial here
Serial.println(
Serial.println(
F("| This nodes whitelist entry on other nodes |"));
Serial.println(
Serial.print(F("{.nodeId = <ID of this node>,.serial = {"));
print_c_friendly_hex_buffer(buffer, 9);
Serial.println(F("}}"));
Serial.println(
Serial.println(
F("+---------------------------------------------------------------++-------------------+"));
Serial.println(
F("| Fieldname || Data |"));
Serial.println(
F("+-------------------------------+-------------------------------++---------+---------+"));
Serial.println(
halt(false);
if (i == 0x00) {
Serial.print(F("| SN[0:1] | SN[2:3] || "));
for (int j=0; j<4; j++) {
if (rx_buffer[SHA204_BUFFER_POS_DATA+j] < 0x10) {
Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+j], HEX);
if (j == 1) {
} else if (j < 3) {
Serial.print(F(" "));
Serial.println(
} else if (i == 0x04) {
Serial.print(F("| Revnum || "));
if (j < 3) {
Serial.println(
} else if (i == 0x08) {
Serial.print(F("| SN[4:7] || "));
if (j < 3) {
Serial.println(
F("+---------------+---------------+---------------+---------------++----+----+----+----+"));
} else if (i == 0x0C) {
Serial.print(F("| SN[8] | Reserved13 | I2CEnable | Reserved15 || "));
if (j < 3) {
} else {
Serial.println(
} else if (i == 0x10) {
Serial.print(F("| I2CAddress | TempOffset | OTPmode | SelectorMode || "));
if (j < 3) {
} else {
Serial.println(
} else if (i == 0x14) {
Serial.print(F("| SlotConfig00 | SlotConfig01 || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x18) {
Serial.print(F("| SlotConfig02 | SlotConfig03 || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x1C) {
Serial.print(F("| SlotConfig04 | SlotConfig05 || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x20) {
Serial.print(F("| SlotConfig06 | SlotConfig07 || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x24) {
Serial.print(F("| SlotConfig08 | SlotConfig09 || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x28) {
Serial.print(F("| SlotConfig0A | SlotConfig0B || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x2C) {
Serial.print(F("| SlotConfig0C | SlotConfig0D || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x30) {
Serial.print(F("| SlotConfig0E | SlotConfig0F || "));
if (j == 1) {
} else if (j < 3) {
Serial.println(
} else if (i == 0x34) {
Serial.print(F("| UseFlag00 | UpdateCount00 | UseFlag01 | UpdateCount01 || "));
if (j < 3) {
} else {
Serial.println(
} else if (i == 0x38) {
Serial.print(F("| UseFlag02 | UpdateCount02 | UseFlag03 | UpdateCount03 || "));
if (j < 3) {
} else {
Serial.println(
} else if (i == 0x3C) {
Serial.print(F("| UseFlag04 | UpdateCount04 | UseFlag05 | UpdateCount05 || "));
if (j < 3) {
} else {
Serial.println(
} else if (i == 0x40) {
Serial.print(F("| UseFlag06 | UpdateCount06 | UseFlag07 | UpdateCount07 || "));
if (j < 3) {
} else {
Serial.println(
} else if (i == 0x44) {
Serial.print(F("| LastKeyUse[0:3] || "));
if (j < 3) {
Serial.println(
} else if (i == 0x48) {
Serial.print(F("| LastKeyUse[4:7] || "));
if (j < 3) {
Serial.println(
} else if (i == 0x4C) {
Serial.print(F("| LastKeyUse[8:B] || "));
if (j < 3) {
Serial.println(
} else if (i == 0x50) {
Serial.print(F("| LastKeyUse[C:F] || "));
if (j < 3) {
Serial.println(
} else if (i == 0x54) {
Serial.print(F("| UserExtra | Selector | LockValue | LockConfig || "));
if (j < 3) {
} else {
Serial.println(
// Doxygen specific constructs, not included when built normally
// This is used to enable disabled macros/definitions to be included in the documentation as well.
#if DOXYGEN
Definition: MyMessage.h:653
SHA204_SUCCESS
#define SHA204_SUCCESS
Function succeeded.
Definition: sha204_lib_return_codes.h:27
sha204Pin
const int sha204Pin
The IO pin to use for ATSHA204A.
Definition: SecurityPersonalizer.ino:416
atsha204Class::sha204c_wakeup
uint8_t sha204c_wakeup(uint8_t *response)
Wake up device.
#define EEPROM_PERSONALIZATION_CHECKSUM_ADDRESS
Personalization checksum (set by SecurityPersonalizer.ino)
Definition: MyEepromAddresses.h:66
SIZE_PERSONALIZATION_CHECKSUM
#define SIZE_PERSONALIZATION_CHECKSUM
Size personalization checksum.
Definition: MyEepromAddresses.h:40
#define SIZE_SIGNING_SOFT_HMAC_KEY
Size soft signing HMAC key.
Definition: MyEepromAddresses.h:47
atsha204Class::sha204m_read
uint8_t sha204m_read(uint8_t *tx_buffer, uint8_t *rx_buffer, uint8_t zone, uint16_t address)
Read from device.
Sketch execution code (unused)
Definition: SecurityPersonalizer.ino:480
atsha204Class::calculateAndUpdateCrc
uint16_t calculateAndUpdateCrc(uint8_t length, uint8_t *data, uint16_t current_crc)
Calculates and update crc.
#define SIZE_RF_ENCRYPTION_AES_KEY
Size RF AES encryption key.
Definition: MyEepromAddresses.h:49
MY_SOFT_SERIAL
The user-defined soft serial to use for soft signing unless GENERATE_SOFT_SERIAL is set.
Definition: SecurityPersonalizer.ino:53
hwUniqueID
bool hwUniqueID(unique_id_t *uniqueID)
doYield
void doYield(void)
#define EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS
Address RF AES encryption key. This is set with SecurityPersonalizer.ino.
Definition: MyEepromAddresses.h:84
atsha204Class::sha204c_resync
uint8_t sha204c_resync(uint8_t size, uint8_t *response)
Resyncronize the device.
sha204
atsha204Class sha204(sha204Pin)
atsha204Class
atsha204Class::sha204m_dev_rev
uint8_t sha204m_dev_rev(uint8_t *tx_buffer, uint8_t *rx_buffer)
Read device revision.
unique_id_t
uint8_t unique_id_t[16]
unique ID
Definition: MyHwHAL.h:77
SHA204 Library Return Code Definitions.
#define SHA204_RESYNC_WITH_WAKEUP
re-synchronization succeeded, but only after generating a Wake-up
Definition: sha204_lib_return_codes.h:40
MY_AES_KEY
#define MY_AES_KEY
The user-defined AES key to store in EEPROM unless GENERATE_AES_KEY is set.
Definition: SecurityPersonalizer.ino:50
atsha204Class::sha204m_random
uint8_t sha204m_random(uint8_t *tx_buffer, uint8_t *rx_buffer, uint8_t mode)
Generate random data.
SIZE_SIGNING_SOFT_SERIAL
#define SIZE_SIGNING_SOFT_SERIAL
Size soft signing serial.
Definition: MyEepromAddresses.h:48
Sketch setup code (all personalization is done here as it is a run-once sketch)
Definition: SecurityPersonalizer.ino:435
atsha204Class::sha204m_execute
uint8_t sha204m_execute(uint8_t op_code, uint8_t param1, uint16_t param2, uint8_t datalen1, uint8_t *data1, uint8_t datalen2, uint8_t *data2, uint8_t datalen3, uint8_t *data3, uint8_t tx_size, uint8_t *tx_buffer, uint8_t rx_size, uint8_t *rx_buffer)
Execute command.
atsha204Class::getSerialNumber
uint8_t getSerialNumber(uint8_t *response)
Gets the serial number.
StdInOutStream::available
int available()
This function does nothing.
atsha204Class
Definition: sha204_library.h:303
#define EEPROM_SIGNING_SOFT_SERIAL_ADDRESS
Address soft signing serial key. This is set with SecurityPersonalizer.ino.
Definition: MyEepromAddresses.h:82
StdInOutStream::read
int read()
Reads 1 key pressed from the keyboard.
#define EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS
Address soft signing HMAC key. This is set with SecurityPersonalizer.ino.
Definition: MyEepromAddresses.h:80
MY_SIGNING_ATSHA204_PIN
#define MY_SIGNING_ATSHA204_PIN
A3 - pin where ATSHA204 is attached.
Definition: SecureActuator.ino:69
MY_HMAC_KEY
#define MY_HMAC_KEY
The user-defined HMAC key to use unless GENERATE_HMAC_KEY is set.
Definition: SecurityPersonalizer.ino:47
