11 #include "IPAddress.h"
   15 #define MQTT_VERSION_3_1      3
   16 #define MQTT_VERSION_3_1_1    4
   21 #define MQTT_VERSION MQTT_VERSION_3_1_1
   25 #ifndef MQTT_MAX_PACKET_SIZE
   26 #define MQTT_MAX_PACKET_SIZE 128
   30 #ifndef MQTT_KEEPALIVE
   31 #define MQTT_KEEPALIVE 15
   35 #ifndef MQTT_SOCKET_TIMEOUT
   36 #define MQTT_SOCKET_TIMEOUT 15
   45 #define MQTT_CONNECTION_TIMEOUT     -4
   46 #define MQTT_CONNECTION_LOST        -3
   47 #define MQTT_CONNECT_FAILED         -2
   48 #define MQTT_DISCONNECTED           -1
   49 #define MQTT_CONNECTED               0
   50 #define MQTT_CONNECT_BAD_PROTOCOL    1
   51 #define MQTT_CONNECT_BAD_CLIENT_ID   2
   52 #define MQTT_CONNECT_UNAVAILABLE     3
   53 #define MQTT_CONNECT_BAD_CREDENTIALS 4
   54 #define MQTT_CONNECT_UNAUTHORIZED    5
   56 #define MQTTCONNECT     1 << 4  // Client request to connect to Server
   57 #define MQTTCONNACK     2 << 4  // Connect Acknowledgment
   58 #define MQTTPUBLISH     3 << 4  // Publish message
   59 #define MQTTPUBACK      4 << 4  // Publish Acknowledgment
   60 #define MQTTPUBREC      5 << 4  // Publish Received (assured delivery part 1)
   61 #define MQTTPUBREL      6 << 4  // Publish Release (assured delivery part 2)
   62 #define MQTTPUBCOMP     7 << 4  // Publish Complete (assured delivery part 3)
   63 #define MQTTSUBSCRIBE   8 << 4  // Client Subscribe request
   64 #define MQTTSUBACK      9 << 4  // Subscribe Acknowledgment
   65 #define MQTTUNSUBSCRIBE 10 << 4 // Client Unsubscribe request
   66 #define MQTTUNSUBACK    11 << 4 // Unsubscribe Acknowledgment
   67 #define MQTTPINGREQ     12 << 4 // PING Request
   68 #define MQTTPINGRESP    13 << 4 // PING Response
   69 #define MQTTDISCONNECT  14 << 4 // Client is Disconnecting
   70 #define MQTTReserved    15 << 4 // Reserved
   72 #define MQTTQOS0        (0 << 1)
   73 #define MQTTQOS1        (1 << 1)
   74 #define MQTTQOS2        (2 << 1)
   77 #define MQTT_MAX_HEADER_SIZE 5
   79 #if defined(ESP8266) || defined(ESP32)
   81 #define MQTT_CALLBACK_SIGNATURE std::function<void(char*, uint8_t*, unsigned int)> callback
   83 #define MQTT_CALLBACK_SIGNATURE void (*callback)(char*, uint8_t*, unsigned int)
   86 #define CHECK_STRING_LENGTH(l,s) if (l+2+strlen(s) > MQTT_MAX_PACKET_SIZE) {_client->stop();return false;}
   93     uint8_t buffer[MQTT_MAX_PACKET_SIZE];
   95     unsigned long lastOutActivity;
   96     unsigned long lastInActivity;
   98     MQTT_CALLBACK_SIGNATURE;
   99     uint16_t readPacket(uint8_t*);
  100     bool readByte(uint8_t * result);
  101     bool readByte(uint8_t * result, uint16_t * index);
  102     bool write(uint8_t header, uint8_t* buf, uint16_t length);
  103     uint16_t writeString(
const char*
string, uint8_t* buf, uint16_t pos);
  108     size_t buildHeader(uint8_t header, uint8_t* buf, uint16_t length);
  123     PubSubClient(uint8_t *, uint16_t, Client& client, Stream&);
  124     PubSubClient(uint8_t *, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
  125     PubSubClient(uint8_t *, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client,
  128     PubSubClient(
const char*, uint16_t, Client& client, Stream&);
  129     PubSubClient(
const char*, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
  130     PubSubClient(
const char*, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client,
  141     bool connect(
const char*
id,
const char* user,
const char* pass);
  142     bool connect(
const char*
id,
const char* willTopic, uint8_t willQos,
bool willRetain,
  143                  const char* willMessage);
  144     bool connect(
const char*
id,
const char* user,
const char* pass,
  145                  uint8_t willQos,
bool willRetain,
  146     bool connect(
const char*
id,
const char* user,
const char* pass,
  147                  uint8_t willQos,
bool willRetain,
const char* willMessage,
bool cleanSession);
  149     bool publish(
const char* topic,
const char* payload);
  150     bool publish(
const char* topic,
const char* payload,
bool retained);
  151     bool publish(
const char* topic,
const uint8_t * payload,
unsigned int plength);
  152     bool publish(
const char* topic,
unsigned int plength,
  154     bool publish_P(
const char* topic,
bool retained);
  155     bool publish_P(
const char* topic,
  165     bool beginPublish(
const char* topic,
bool retained);
  170     virtual size_t write(uint8_t);
  173     virtual size_t write(
const uint8_t *buffer,
size_t size);
  175     bool subscribe(
const char* topic, uint8_t qos);
