drivers
AltSoftSerial
examples
ReceiveTest
ReceiveTest.ino
// AltSoftSerial Receive Test
// Transmit data with Serial1 and try to receive
// it with AltSoftSerial. You must connect a wire
// from Serial1 TX to AltSoftSerial RX.
#include <AltSoftSerial.h>
AltSoftSerial
altser;
const
int
mybaud = 9600;
// Board Serial1 TX AltSoftSerial RX
// Teensy 3.x 1 20
// Teensy 2.0 8 (D3) 10 (C7)
// Teensy++ 2.0 3 (D3) 4 (D4)
// Arduino Leonardo 1 13
// Arduino Mega 18 48
// Serial1 on AVR @ 16 MHz minimum baud is 245
// Serial1 on Teensy 3.2 @ 96 MHz minimum baud is 733
// This example code is in the public domain.
byte
sentbyte;
unsigned
long
prevmillis;
byte
testbyte=0xF0;
void
delay(200);
Serial.
begin
(9600);
while
(!Serial) ;
// wait for Arduino Serial Monitor
Serial1.begin(mybaud);
// connect a wire from TX1
altser.
begin
(mybaud);
// to AltSoftSerial RX
Serial.println(
"AltSoftSerial Receive Test"
prevmillis = millis();
void
// transmit a test byte on Serial 1
if
(millis() - prevmillis > 250) {
sentbyte = testbyte++;
Serial1.write(sentbyte);
// attempt to receive it by AltSoftSerial
if
(altser.
available
() > 0) {
byte
b = altser.
read
Serial.println(b);
if
(b != sentbyte) {
Serial.println(
"***** ERROR *****"
AltSoftSerial::read
int read()
read
Definition:
ReceiveTest.ino:40
StdInOutStream::begin
void begin(int baud)
This function does nothing.
AltSoftSerial
Definition:
AltSoftSerial.h:43
AltSoftSerial::available
int available()
available
Definition:
ReceiveTest.ino:29
AltSoftSerial::begin
static void begin(uint32_t baud)
Definition:
AltSoftSerial.h:51
