SPIFlash provides access to a SPI Flash IC for OTA update or storing data.
IMPORTANT: NAND FLASH memory requires erase before write, because it can only transition from 1s to 0s and only the erase command can reset all 0s to 1s See http://en.wikipedia.org/wiki/Flash_memory The smallest range that can be erased is a sector (4K, 32K, 64K); there is also a chip erase command
Standard SPI flash commands
Assuming the WP pin is pulled up (to disable hardware write protection).
To use any write commands the WEL bit in the status register must be set to 1.
This is accomplished by sending a 0x06 command before any such write/erase command.
The WEL bit in the status register resets to the logical ?0? state after a device power-up or reset. In addition, the WEL bit will be reset to the logical ?0? state automatically under the following conditions:
Definition in file SPIFlash.h.
#include <wiring.h>
#include "pins_arduino.h"
Classes | |
class | SPIFlash |
#define | SPIFLASH_WRITEENABLE 0x06 |
write enable | |
#define | SPIFLASH_WRITEDISABLE 0x04 |
write disable | |
#define | SPIFLASH_BLOCKERASE_4K 0x20 |
erase one 4K block of flash memory | |
#define | SPIFLASH_BLOCKERASE_32K 0x52 |
erase one 32K block of flash memory | |
#define | SPIFLASH_BLOCKERASE_64K 0xD8 |
erase one 64K block of flash memory | |
#define | SPIFLASH_CHIPERASE 0x60 |
chip erase (may take several seconds depending on size) More... | |
#define | SPIFLASH_STATUSREAD 0x05 |
read status register | |
#define | SPIFLASH_STATUSWRITE 0x01 |
write status register | |
#define | SPIFLASH_ARRAYREAD 0x0B |
read array (fast, need to add 1 dummy byte after 3 address bytes) | |
#define | SPIFLASH_ARRAYREADLOWFREQ 0x03 |
read array (low frequency) | |
#define | SPIFLASH_SLEEP 0xB9 |
deep power down | |
#define | SPIFLASH_WAKE 0xAB |
deep power wake up | |
#define | SPIFLASH_BYTEPAGEPROGRAM 0x02 |
write (1 to 256bytes). Writing more than one Byte is not supported on all devices (e.g. SST25 Series) | |
#define | SPIFLASH_AAIWORDPROGRAM 0xAD |
Auto Address Increment Programming on Microchip SST Family Devices which do not support page program. More... | |
#define | SPIFLASH_IDREAD 0x9F |
read JEDEC manufacturer and device ID (2 bytes, specific bytes for each manufacturer and device) More... | |
#define | SPIFLASH_MACREAD 0x4B |
read unique ID number (MAC) | |
#define | MY_SPIFLASH_SST25TYPE |
If set AAI Word Programming is used to support SST25 Family SPI Flash. More... | |
#define MY_SPIFLASH_SST25TYPE |
SST25 Family Flash does not support programming multiple Bytes with opcode 0x02 SPIFLASH_BYTEPAGEPROGRAM.
If SPIFLASH_SST25TYPE is set and writeBytes is called, it will use opcode 0xAD SPIFLASH_AAIWORDPROGRAM and care for Byte alignment.
Note: AAI Wordprogramming is independent of Pages, so pagebreaking is not an issue when using AAI Wordprogramming.
Definition at line 157 of file SPIFlash.h.
#define SPIFLASH_AAIWORDPROGRAM 0xAD |
Use define MY_SPIFLASH_SST25TYPE to use AAI prog instead of Bytepageprogram which does not work on SST Family Chips tested with SST25PF020B80 http://ww1.microchip.com/downloads/en/DeviceDoc/20005135B.pdf
Definition at line 133 of file SPIFlash.h.
#define SPIFLASH_CHIPERASE 0x60 |
Chip is erased but not actually waited for completion (instead need to check the status register BUSY bit)
Definition at line 100 of file SPIFlash.h.
#define SPIFLASH_IDREAD 0x9F |
Example for Atmel-Adesto 4Mbit AT25DF041A: 0x1F44 (page 27: http://www.adestotech.com/sites/default/files/datasheets/doc3668.pdf) Example for Winbond 4Mbit W25X40CL: 0xEF30 (page 14: http://www.winbond.com/NR/rdonlyres/6E25084C-0BFE-4B25-903D-AE10221A0929/0/W25X40CL.pdf)
Definition at line 139 of file SPIFlash.h.
