+ Collaboration diagram for MyNodeLock:
API declaration for MyNodeLock.
void _nodeLock (const char *str)
 Lock a node and transmit provided message with 30m intervals. More...
void _checkNodeLock (void)
 Check node lock status and prevent node execution if locked.
◆ _nodeLock()
void _nodeLock ( const char *  str)
This function is called if suspicious activity has exceeded the threshold (see MY_NODE_LOCK_COUNTER_MAX). Unlocking with a normal Arduino bootloader require erasing the EEPROM while unlocking with a custom bootloader require holding MY_NODE_UNLOCK_PIN low during power on/reset.
strThe string to transmit.
