System Timer access
Allows access to and delays using the System Timer Counter.
uint64_t bcm2835_st_read (void)
void bcm2835_st_delay (uint64_t offset_micros, uint64_t micros)
◆ bcm2835_st_delay()
void bcm2835_st_delay ( uint64_t  offset_micros,
uint64_t  micros
Delays for the specified number of microseconds with offset.
[in]offset_microsOffset in microseconds
[in]microsDelay in microseconds
◆ bcm2835_st_read()
uint64_t bcm2835_st_read ( void  )
Read the System Timer Counter register.
Returns
the value read from the System Timer Counter Lower 32 bits register
