AirQualitySensor.ino
21  * DESCRIPTION
22  *
23  * Connect the MQ2 sensor as follows :
24  *
25  * A H A >>> 5V
26  * B >>> A0
27  * H >>> GND
28  * B >>> 10K ohm >>> GND
29  *
30  * Contribution: epierre
31  * Based on http://sandboxelectronics.com/?p=165
32  * License: Attribution-NonCommercial-ShareAlike 3.0 Unported (CC BY-NC-SA 3.0)
33  * Modified by HEK to work in 1.4
34  *
35  */
37 // Enable debug prints to serial monitor
38 #define MY_DEBUG
40 // Enable and select radio type attached
41 #define MY_RADIO_RF24
42 //#define MY_RADIO_NRF5_ESB
43 //#define MY_RADIO_RFM69
44 //#define MY_RADIO_RFM95
45 //#define MY_PJON
47 #include <MySensors.h>
49 #define CHILD_ID_MQ 0
50 /************************Hardware Related Macros************************************/
51 #define MQ_SENSOR_ANALOG_PIN (0) //define which analog input channel you are going to use
52 #define RL_VALUE (5) //define the load resistance on the board, in kilo ohms
53 #define RO_CLEAN_AIR_FACTOR (9.83) //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
54 //which is derived from the chart in datasheet
55 /***********************Software Related Macros************************************/
56 #define CALIBARAION_SAMPLE_TIMES (50) //define how many samples you are going to take in the calibration phase
57 #define CALIBRATION_SAMPLE_INTERVAL (500) //define the time interval(in milliseconds) between each samples in the
58 //calibration phase
59 #define READ_SAMPLE_INTERVAL (50) //define how many samples you are going to take in normal operation
60 #define READ_SAMPLE_TIMES (5) //define the time interval(in milliseconds) between each samples in
61 //normal operation
62 /**********************Application Related Macros**********************************/
63 #define GAS_LPG (0)
64 #define GAS_CO (1)
65 #define GAS_SMOKE (2)
66 /*****************************Globals***********************************************/
67 uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
68 //VARIABLES
69 float Ro = 10000.0; // this has to be tuned 10K Ohm
70 int val = 0; // variable to store the value coming from the sensor
71 uint16_t lastMQ = 0;
72 float LPGCurve[3] = {2.3,0.21,-0.47}; //two points are taken from the curve.
73 //with these two points, a line is formed which is "approximately equivalent"
74 //to the original curve.
75 //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
76 float COCurve[3] = {2.3,0.72,-0.34}; //two points are taken from the curve.
77 //with these two points, a line is formed which is "approximately equivalent"
78 //to the original curve.
79 //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000, 0.15)
80 float SmokeCurve[3] = {2.3,0.53,-0.44}; //two points are taken from the curve.
81 //with these two points, a line is formed which is "approximately equivalent"
82 //to the original curve.
83 //data format:{ x, y, slope}; point1: (lg200, 0.53), point2:(lg10000,-0.22)
86 MyMessage msg(CHILD_ID_MQ, V_LEVEL);
88 void setup()
89 {
90  Ro = MQCalibration(
91  MQ_SENSOR_ANALOG_PIN); //Calibrating the sensor. Please make sure the sensor is in clean air
92 }
95 {
96  // Send the sketch version information to the gateway and Controller
97  sendSketchInfo("Air Quality Sensor", "1.0");
99  // Register all sensors to gateway (they will be created as child devices)
100  present(CHILD_ID_MQ, S_AIR_QUALITY);
101 }
103 void loop()
104 {
105  uint16_t valMQ = MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO);
106  Serial.println(val);
108  Serial.print("LPG:");
109  Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_LPG) );
110  Serial.print( "ppm" );
111  Serial.print(" ");
112  Serial.print("CO:");
113  Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO) );
114  Serial.print( "ppm" );
115  Serial.print(" ");
116  Serial.print("SMOKE:");
117  Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_SMOKE) );
118  Serial.print( "ppm" );
119  Serial.print("\n");
121  if (valMQ != lastMQ) {
122  send(msg.set((int16_t)ceil(valMQ)));
123  lastMQ = ceil(valMQ);
124  }
126  sleep(SLEEP_TIME); //sleep for: sleepTime
127 }
128
129 /****************** MQResistanceCalculation ****************************************
130 Input: raw_adc - raw value read from adc, which represents the voltage
131 Output: the calculated sensor resistance
132 Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
133  across the load resistor and its resistance, the resistance of the sensor
134  could be derived.
135 ************************************************************************************/
136 float MQResistanceCalculation(int raw_adc)
137 {
138  return ( ((float)RL_VALUE*(1023-raw_adc)/raw_adc));
139 }
140
141 /***************************** MQCalibration ****************************************
142 Input: mq_pin - analog channel
143 Output: Ro of the sensor
144 Remarks: This function assumes that the sensor is in clean air. It use
145  MQResistanceCalculation to calculates the sensor resistance in clean air
146  and then divides it with RO_CLEAN_AIR_FACTOR. RO_CLEAN_AIR_FACTOR is about
147  10, which differs slightly between different sensors.
148 ************************************************************************************/
149 float MQCalibration(int mq_pin)
150 {
151  int i;
152  float inVal=0;
154  for (i=0; i<CALIBARAION_SAMPLE_TIMES; i++) { //take multiple samples
155  inVal += MQResistanceCalculation(analogRead(mq_pin));
156  delay(CALIBRATION_SAMPLE_INTERVAL);
157  }
158  inVal = inVal/CALIBARAION_SAMPLE_TIMES; //calculate the average value
159
160  inVal = inVal/RO_CLEAN_AIR_FACTOR; //divided by RO_CLEAN_AIR_FACTOR yields the Ro
161  //according to the chart in the datasheet
162
163  return inVal;
164 }
165 /***************************** MQRead *********************************************
166 Input: mq_pin - analog channel
167 Output: Rs of the sensor
168 Remarks: This function use MQResistanceCalculation to calculate the sensor resistance (Rs).
169  The Rs changes as the sensor is in the different concentration of the target
170  gas. The sample times and the time interval between samples could be configured
171  by changing the definition of the macros.
172 ************************************************************************************/
173 float MQRead(int mq_pin)
174 {
175  int i;
176  float rs=0;
177
178  for (i=0; i<READ_SAMPLE_TIMES; i++) {
179  rs += MQResistanceCalculation(analogRead(mq_pin));
180  delay(READ_SAMPLE_INTERVAL);
181  }
182
183  rs = rs/READ_SAMPLE_TIMES;
184
185  return rs;
186 }
187
188 /***************************** MQGetGasPercentage **********************************
189 Input: rs_ro_ratio - Rs divided by Ro
190  gas_id - target gas type
191 Output: ppm of the target gas
192 Remarks: This function passes different curves to the MQGetPercentage function which
193  calculates the ppm (parts per million) of the target gas.
194 ************************************************************************************/
195 int MQGetGasPercentage(float rs_ro_ratio, int gas_id)
196 {
197  if ( gas_id == GAS_LPG ) {
198  return MQGetPercentage(rs_ro_ratio,LPGCurve);
199  } else if ( gas_id == GAS_CO ) {
200  return MQGetPercentage(rs_ro_ratio,COCurve);
201  } else if ( gas_id == GAS_SMOKE ) {
202  return MQGetPercentage(rs_ro_ratio,SmokeCurve);
203  }
204
205  return 0;
206 }
207
208 /***************************** MQGetPercentage **********************************
209 Input: rs_ro_ratio - Rs divided by Ro
210  pcurve - pointer to the curve of the target gas
211 Output: ppm of the target gas
212 Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
213  of the line could be derived if y(rs_ro_ratio) is provided. As it is a
214  logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
215  value.
216 ************************************************************************************/
217 int MQGetPercentage(float rs_ro_ratio, float *pcurve)
218 {
219  return (pow(10,( ((log(rs_ro_ratio)-pcurve[1])/pcurve[2]) + pcurve[0])));
220 }
Definition: AirQualitySensor.ino:103
Definition: AirQualitySensor.ino:94
MyMessage::set
send
present
Definition: AirQualitySensor.ino:88
sleep
Definition: MyMessage.h:291
