API declaration for MySensorsCore.
MySensorsCore-related log messages, format: [!]SYSTEM:[SUB SYSTEM:]MESSAGE
MySensorsCore debug log messages:
E | SYS | SUB | Message | Comment |
! | MCO | BGN | HW ERR | Error HW initialization (e.g. ext. EEPROM) |
MCO | BGN | INIT %s,CP=%s,FQ=%d,REL=%d,VER=%s | Core initialization, capabilities (CP), CPU frequency [Mhz] (FQ), release number (REL), library version (VER) | |
MCO | BGN | BFR | Callback before() | |
MCO | BGN | STP | Callback setup() | |
MCO | BGN | INIT OK,TSP=%d | Core initialised, transport status (TSP): 0=not initialised, 1=initialised, NA=not available | |
MCO | BGN | NODE UNLOCKED | Node successfully unlocked (see signing chapter) | |
! | MCO | BGN | TSP FAIL | Transport initialization failed |
MCO | REG | REQ | Registration request | |
MCO | REG | NOT NEEDED | No registration needed (i.e. GW) | |
! | MCO | SND | NODE NOT REG | Node is not registered, cannot send message |
MCO | PIM | NODE REG=%d | Registration response received, registration status (REG) | |
! | MCO | WAI | RC=%d | Recursive call detected in wait(), level (RC) |
MCO | SLP | MS=%lu,SMS=%d,I1=%d,M1=%d,I2=%d,M2=%d | Sleep node, time (MS), smartSleep (SMS), Int1 (I1), Mode1 (M1), Int2 (I2), Mode2 (M2) | |
MCO | SLP | WUP=%d | Node woke-up, reason/IRQ (WUP) | |
! | MCO | SLP | NTL | Sleeping not possible, no time left |
! | MCO | SLP | FWUPD | Sleeping not possible, FW update ongoing |
! | MCO | SLP | REP | Sleeping not possible, repeater feature enabled |
! | MCO | SLP | TNR | Transport not ready, attempt to reconnect until timeout (MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS) |
MCO | NLK | NODE LOCKED. UNLOCK: GND PIN %d AND RESET | Node locked during booting, see signing chapter for additional information | |
MCO | NLK | TSL | Set transport to sleep |
Modules | |
MyNodeLock | |
API declaration for MyNodeLock. | |
Classes | |
struct | controllerConfig_t |
Controller configuration. More... | |
struct | coreConfig_t |
Node core configuration. More... | |
#define | GATEWAY_ADDRESS ((uint8_t)0) |
Node ID for GW sketch. | |
#define | NODE_SENSOR_ID ((uint8_t)255) |
Node child is always created/presented when a node is started. | |
#define | MY_CORE_VERSION ((uint8_t)2) |
core version | |
#define | MY_CORE_MIN_VERSION ((uint8_t)2) |
min core version required for compatibility | |
#define | MY_WAKE_UP_BY_TIMER ((int8_t)-1) |
Sleeping wake up by timer. | |
#define | MY_SLEEP_NOT_POSSIBLE ((int8_t)-2) |
Sleeping not possible. | |
#define | INTERRUPT_NOT_DEFINED ((uint8_t)255) |
_sleep() param: no interrupt defined | |
#define | MODE_NOT_DEFINED ((uint8_t)255) |
_sleep() param: no mode defined | |
#define | VALUE_NOT_DEFINED ((uint8_t)255) |
Value not defined. | |
#define | FUNCTION_NOT_SUPPORTED ((uint16_t)0) |
Function not supported. | |
Functions | |
uint8_t | getNodeId (void) |
uint8_t | getParentNodeId (void) |
void | presentNode (void) |
bool | present (const uint8_t sensorId, const mysensors_sensor_t sensorType, const char *description="", const bool requestEcho=false) |
bool | sendSketchInfo (const char *name, const char *version, const bool requestEcho=false) |
bool | send (MyMessage &msg, const bool requestEcho=false) |
bool | sendBatteryLevel (const uint8_t level, const bool requestEcho=false) |
bool | sendHeartbeat (const bool requestEcho=false) |
bool | sendSignalStrength (const int16_t level, const bool requestEcho=false) |
bool | sendTXPowerLevel (const uint8_t level, const bool requestEcho=false) |
bool | request (const uint8_t childSensorId, const uint8_t variableType, const uint8_t destination=GATEWAY_ADDRESS) |
bool | requestTime (const bool requestEcho=false) |
controllerConfig_t | getControllerConfig (void) |
void | saveState (const uint8_t pos, const uint8_t value) |
uint8_t | loadState (const uint8_t pos) |
void | wait (const uint32_t waitingMS) |
bool | wait (const uint32_t waitingMS, const mysensors_command_t cmd) |
bool | wait (const uint32_t waitingMS, const mysensors_command_t cmd, const uint8_t msgtype) |
void | doYield (void) |
void | sleepHandler (bool sleep) |
int8_t | sleep (const uint32_t sleepingMS, const bool smartSleep=false) |
int8_t | sleep (const uint8_t interrupt, const uint8_t mode, const uint32_t sleepingMS=0, const bool smartSleep=false) |
int8_t | sleep (const uint8_t interrupt1, const uint8_t mode1, const uint8_t interrupt2, const uint8_t mode2, const uint32_t sleepingMS=0, const bool smartSleep=false) |
int8_t | smartSleep (const uint32_t sleepingMS) |
int8_t | smartSleep (const uint8_t interrupt, const uint8_t mode, const uint32_t sleepingMS=0) |
int8_t | smartSleep (const uint8_t interrupt1, const uint8_t mode1, const uint8_t interrupt2, const uint8_t mode2, const uint32_t sleepingMS=0) |
int8_t | _sleep (const uint32_t sleepingMS, const bool smartSleep=false, const uint8_t interrupt1=INTERRUPT_NOT_DEFINED, const uint8_t mode1=MODE_NOT_DEFINED, const uint8_t interrupt2=INTERRUPT_NOT_DEFINED, const uint8_t mode2=MODE_NOT_DEFINED) |
uint32_t | getSleepRemaining (void) |
void | _begin (void) |
Node initialisation. | |
void | _process (void) |
Main framework process. | |
bool | _processInternalCoreMessage (void) |
Processes internal core message. More... | |
void | _infiniteLoop (void) |
Puts node to a infinite loop if unrecoverable situation detected. | |
void | _registerNode (void) |
Handles registration request. | |
bool | _sendRoute (MyMessage &message) |
Sends message according to routing table. More... | |
void | receive (const MyMessage &) __attribute__((weak)) |
Callback for incoming messages. More... | |
void | receiveTime (uint32_t) __attribute__((weak)) |
Callback for incoming time messages. | |
void | presentation (void) __attribute__((weak)) |
Node presentation. | |
void | before (void) __attribute__((weak)) |
Called before node initialises. | |
void | preHwInit (void) __attribute__((weak)) |
Called before any hardware initialisation is done. | |
void | setup (void) __attribute__((weak)) |
Called after node initialises but before main loop. More... | |
void | loop (void) __attribute__((weak)) |
Main loop. More... | |
bool _processInternalCoreMessage | ( | void | ) |
bool _sendRoute | ( | MyMessage & | message | ) |
message |
int8_t _sleep | ( | const uint32_t | sleepingMS, |
const bool | smartSleep = false , |
const uint8_t | interrupt1 = INTERRUPT_NOT_DEFINED , |
const uint8_t | mode1 = MODE_NOT_DEFINED , |
const uint8_t | interrupt2 = INTERRUPT_NOT_DEFINED , |
const uint8_t | mode2 = MODE_NOT_DEFINED |
Sleep (PowerDownMode) the MCU and radio. Wake up on timer or pin change for two separate interrupts. See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
sleepingMS | Number of milliseconds to sleep or 0 to sleep forever |
interrupt1 | (optional) First interrupt that should trigger the wakeup |
mode1 | (optional) Mode for first interrupt (RISING, FALLING, CHANGE) |
interrupt2 | (optional) Second interrupt that should trigger the wakeup |
mode2 | (optional) Mode for second interrupt (RISING, FALLING, CHANGE) |
smartSleep | (optional) Set True if sending heartbeat and process incoming messages before going to sleep. |
void doYield | ( | void | ) |
Function to allow scheduler to do some work.
controllerConfig_t getControllerConfig | ( | void | ) |
Returns the most recent node configuration received from controller
uint8_t getNodeId | ( | void | ) |
Return this nodes id.
uint8_t getParentNodeId | ( | void | ) |
Return the parent node id.
uint32_t getSleepRemaining | ( | void | ) |
Return the sleep time remaining after waking up from sleep. Depending on the CPU architecture, the remaining time can be seconds off (e.g. upto roughly 8 seconds on AVR).
uint8_t loadState | ( | const uint8_t | pos | ) |
Load a state (from local EEPROM).
pos | The position to fetch value from (0-255) |
bool present | ( | const uint8_t | sensorId, |
const mysensors_sensor_t | sensorType, | ||
const char * | description = "" , |
const bool | requestEcho = false |
Each node must present all attached sensors before any values can be handled correctly by the controller. It is usually good to present all attached sensors after power-up in setup().
sensorId | Select a unique sensor id for this sensor. Choose a number between 0-254. |
sensorType | The sensor type. See sensor typedef in MyMessage.h. |
description | A textual description of the sensor. |
requestEcho | Set this to true if you want destination node to echo the message back to this node. Default is not to request echo. If set to true, the final destination will echo back the contents of the message, triggering the receive() function on the original node with a copy of the message, with message.isEcho() set to true and sender/destination switched. |
void presentNode | ( | void | ) |
Sends node information to the gateway.
void receive | ( | const MyMessage & | message | ) |
message | The message to handle. |
Definition at line 87 of file DimmableLEDActuator.ino.
bool request | ( | const uint8_t | childSensorId, |
const uint8_t | variableType, | ||
const uint8_t | destination = GATEWAY_ADDRESS |
Requests a value from gateway or some other sensor in the radio network. Make sure to add callback-method in begin-method to handle request responses.
childSensorId | The unique child id for the different sensors connected to this Arduino. 0-254. |
variableType | The variableType to fetch |
destination | The nodeId of other node in radio network. Default is gateway |
bool requestTime | ( | const bool | requestEcho = false | ) |
Requests time from controller. Answer will be delivered to receiveTime function in sketch.
void saveState | ( | const uint8_t | pos, |
const uint8_t | value | ||
Save a state (in local EEPROM). Good for actuators to "remember" state between power cycles.
You have 256 bytes to play with. Note that there is a limitation on the number of writes the EEPROM can handle (~100 000 cycles on ATMega328).
pos | The position to store value in (0-255) |
value | to store in position |
bool send | ( | MyMessage & | msg, |
Sends a message to gateway or one of the other nodes in the radio network
msg | Message to send |
bool sendBatteryLevel | ( | const uint8_t | level, |
Send this nodes battery level to gateway.
level | Level between 0-100(%) |
bool sendHeartbeat | ( | const bool | requestEcho = false | ) |
Send a heartbeat message (I'm alive!) to the gateway/controller. The payload will be an incremental 16 bit integer value starting at 1 when sensor is powered on.
bool sendSignalStrength | ( | const int16_t | level, |
Send this nodes signal strength to gateway.
level | Signal strength can be RSSI if the radio provide it, or another kind of calculation |
bool sendSketchInfo | ( | const char * | name, |
const char * | version, | ||
Sends sketch meta information to the gateway. Not mandatory but a nice thing to do.
name | String containing a short Sketch name or NULL if not applicable |
version | String containing a short Sketch version or NULL if not applicable |
bool sendTXPowerLevel | ( | const uint8_t | level, |
Send this nodes TX power level to gateway.
level | For instance, can be TX power level in dbm |
void setup | ( | ) |
int8_t sleep | ( | const uint32_t | sleepingMS, |
const bool | smartSleep = false |
Sleep (PowerDownMode) the MCU and radio. Wake up on timer.
sleepingMS | Number of milliseconds to sleep. |
smartSleep | Set True if sending heartbeat and process incoming messages before going to sleep. |
int8_t sleep | ( | const uint8_t | interrupt, |
const uint8_t | mode, | ||
const uint32_t | sleepingMS = 0 , |
Sleep (PowerDownMode) the MCU and radio. Wake up on timer or pin change. See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
interrupt | Interrupt that should trigger the wakeup |
mode | RISING, FALLING, CHANGE |
smartSleep | Set True if sending heartbeat and process incoming messages before going to sleep |
int8_t sleep | ( | const uint8_t | interrupt1, |
const uint8_t | mode1, | ||
const uint8_t | interrupt2, | ||
const uint8_t | mode2, | ||
interrupt1 | First interrupt that should trigger the wakeup |
mode1 | Mode for first interrupt (RISING, FALLING, CHANGE) |
interrupt2 | Second interrupt that should trigger the wakeup |
mode2 | Mode for second interrupt (RISING, FALLING, CHANGE) |
void sleepHandler | ( | bool | sleep | ) |
Sleep handler will be called right before and right after entering sleep mode. Applications can define own handler to optimize powering down peripherals before entering sleep.
sleep | true if entering sleep, false if exiting |
int8_t smartSleep | ( | const uint32_t | sleepingMS | ) |
int8_t smartSleep | ( | const uint8_t | interrupt, |
const uint32_t | sleepingMS = 0 |
int8_t smartSleep | ( | const uint8_t | interrupt1, |
void wait | ( | const uint32_t | waitingMS | ) |
Wait for a specified amount of time to pass. Keeps process()ing. This does not power-down the radio nor the Arduino. Because this calls process() in a loop, it is a good way to wait in your loop() on a repeater node or sensor that listens to messages.
waitingMS | Number of milliseconds to wait. |
bool wait | ( | const uint32_t | waitingMS, |
const mysensors_command_t | cmd | ||
Wait for a specified amount of time to pass or until specified message received. Keeps process()ing. This does not power-down the radio nor the Arduino. Because this calls process() in a loop, it is a good way to wait in your loop() on a repeater node or sensor that listens to messages.
cmd | Command of incoming message. |
const mysensors_command_t | cmd, | ||
const uint8_t | msgtype | ||
msgtype | Message type. |
