MySensors Library & Examples  2.3.2-82-gc3fc0ff4
DustSensor.ino
9  * Copyright (C) 2013-2025 Sensnology AB
21  * REVISION HISTORY
22  * Version 1.0 - epierre
23  * Converted to 1.4 by Henrik Ekblad
24  *
25  * DESCRIPTION
26  * Arduino Dust Sensort
27  *
28  * connect the sensor as follows :
29  *
30  * VCC >>> 5V
31  * A >>> A0
32  * GND >>> GND
33  *
34  * Based on: http://www.dfrobot.com/wiki/index.php/Sharp_GP2Y1010AU
35  * Authors: Cyrille Médard de Chardon (serialC), Christophe Trefois (Trefex)
36  *
37  * http://www.mysensors.org/build/dust
38  *
39  */
41 // Enable debug prints
42 #define MY_DEBUG
44 // Enable and select radio type attached
45 #define MY_RADIO_RF24
46 //#define MY_RADIO_NRF5_ESB
47 //#define MY_RADIO_RFM69
48 //#define MY_RADIO_RFM95
49 //#define MY_PJON
51 #include <MySensors.h>
53 #define CHILD_ID_DUST 0
54 #define DUST_SENSOR_ANALOG_PIN 1
56 uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
57 //VARIABLES
58 int val = 0; // variable to store the value coming from the sensor
59 float valDUST =0.0;
60 float lastDUST =0.0;
61 int samplingTime = 280;
62 int deltaTime = 40;
63 int sleepTime = 9680;
64 float calcVoltage = 0;
65 float dustDensity = 0;
67 MyMessage dustMsg(CHILD_ID_DUST, V_LEVEL);
70 {
71  // Send the sketch version information to the gateway and Controller
72  sendSketchInfo("Dust Sensor", "1.1");
74  // Register all sensors to gateway (they will be created as child devices)
75  present(CHILD_ID_DUST, S_DUST);
76 }
78 void loop()
79 {
80  uint16_t voMeasured = analogRead(DUST_SENSOR_ANALOG_PIN);// Get DUST value
82  // 0 - 5V mapped to 0 - 1023 integer values
83  // recover voltage
84  calcVoltage = voMeasured * (5.0 / 1024.0);
86  // linear equation taken from http://www.howmuchsnow.com/arduino/airquality/
87  // Chris Nafis (c) 2012
88  dustDensity = (0.17 * calcVoltage - 0.1)*1000;
90  Serial.print("Raw Signal Value (0-1023): ");
91  Serial.print(voMeasured);
93  Serial.print(" - Voltage: ");
94  Serial.print(calcVoltage);
96  Serial.print(" - Dust Density: ");
97  Serial.println(dustDensity); // unit: ug/m3
99  if (ceil(dustDensity) != lastDUST) {
100  send(dustMsg.set((int16_t)ceil(dustDensity)));
101  lastDUST = ceil(dustDensity);
102  }
104  sleep(SLEEP_TIME);
105 }
Definition: DustSensor.ino:78
Definition: DustSensor.ino:69
MyMessage::set
send
present
sleep
Definition: MyMessage.h:291
