MySensors Library & Examples  2.3.2-119-g6af75d19
EthernetServer.h
19  * Based on Arduino ethernet library, Copyright (c) 2010 Arduino LLC. All right reserved.
20  */
22 #ifndef EthernetServer_h
23 #define EthernetServer_h
25 #include <list>
26 #include <vector>
27 #include "Server.h"
28 #include "IPAddress.h"
30 #ifdef ETHERNETSERVER_MAX_CLIENTS
31 #define ETHERNETSERVER_BACKLOG ETHERNETSERVER_MAX_CLIENTS
32 #else
33 #define ETHERNETSERVER_MAX_CLIENTS 10
34 #define ETHERNETSERVER_BACKLOG 10
35 #endif
37 class EthernetClient;
42 class EthernetServer : public Server
43 {
45 public:
52  EthernetServer(uint16_t port, uint16_t max_clients = ETHERNETSERVER_MAX_CLIENTS);
57  virtual void begin();
63  void begin(IPAddress addr);
69  bool hasClient();
82  virtual size_t write(uint8_t b);
90  virtual size_t write(const uint8_t *buffer, size_t size);
97  size_t write(const char *str);
105  size_t write(const char *buffer, size_t size);
107 private:
108  uint16_t port;
109  std::list<int> new_clients;
110  std::vector<int> clients;
111  uint16_t max_clients;
112  int sockfd;
118  void _accept();
119 };
121 #endif
EthernetServer::EthernetServer
EthernetServer(uint16_t port, uint16_t max_clients=ETHERNETSERVER_MAX_CLIENTS)
EthernetServer constructor.
EthernetClient
Definition: EthernetClient.h:43
EthernetServer::accept
EthernetClient accept()
Get the new connected client.
EthernetServer
EthernetServer class.
Definition: EthernetServer.h:42
EthernetServer::hasClient
bool hasClient()
Verifies if a new client has connected.
EthernetServer::write
Write a byte to all clients.
IPAddress
Definition: IPAddress.h:32
EthernetServer::begin
Listen for inbound connection request.
