MySensors Library & Examples  2.3.2-87-gb8f8b6e2
EthernetTCP.h
2 /* EthernetTCP is a Strategy for the PJON framework (included in version v5.2)
3  It supports delivering PJON packets over Ethernet TCP.
4  Compliant with the PJON protocol layer specification v0.3
5  _____________________________________________________________________________
7  EthernetTCP strategy and EthernetLink proposed and developed by Fred Larsen
8  02/10/2016
10  Licensed under the Apache License, Version 2.0 (the "License");
11  you may not use this file except in compliance with the License.
12  You may obtain a copy of the License at
14  http://www.apache.org/licenses/LICENSE-2.0
16  Unless required by applicable law or agreed to in writing, software
17  distributed under the License is distributed on an "AS IS" BASIS,
18  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
19  See the License for the specific language governing permissions and
20  limitations under the License. */
22 #pragma once
24 #include "EthernetLink.h"
25 #include <PJONDefines.h>
27 // Recommended receive time for this strategy, in microseconds
28 #ifndef ETCP_RECEIVE_TIME
29 #define ETCP_RECEIVE_TIME 0
30 #endif
33 {
34 public:
35  EthernetLink link;
36  uint16_t last_send_result = PJON_FAIL;
38  /* Caching incoming packet to enable byte for byte delivery */
40  uint8_t *incoming_packet_buf_ptr = NULL;
41  uint16_t current_buffer_size = 0;
42  uint16_t incoming_packet_size = 0;
44  static void static_receiver(
45  uint8_t id,
46  const uint8_t *payload,
47  uint16_t length,
48  void *callback_object
49  )
50  {
51  if(callback_object) {
52  ((EthernetTCP*)callback_object)->receiver(id, payload, length);
53  }
54  };
57  void receiver(uint8_t /*id*/, const uint8_t *payload, uint16_t length)
58  {
59  if(length <= current_buffer_size && incoming_packet_buf_ptr != NULL) {
60  memcpy(incoming_packet_buf_ptr, payload, length);
61  incoming_packet_size = length;
62  }
63  };
66  EthernetTCP()
67  {
68  link.set_receiver(static_receiver, this);
69 #ifdef _WIN32
70  // Initialize Winsock
71  WSAData wsaData;
72  WSAStartup(MAKEWORD(2, 2), &wsaData);
73 #endif
74  };
76 #ifdef _WIN32
77  ~EthernetTCP()
78  {
79  // Cleanup Winsock
80  WSACleanup();
81  };
82 #endif
85  /* Returns the suggested delay related to the attempts passed as parameter: */
87  uint32_t back_off(uint8_t attempts)
88  {
89  return 10000ul*attempts;
90  };
93  /* Begin method, to be called on initialization:
94  (returns always true) */
96  bool begin(uint8_t /*did*/ = 0)
97  {
98  return true;
99  };
102  /* Check if the channel is free for transmission */
104  bool can_start()
105  {
106  return link.device_id() != 0;
107  };
110  /* Returns the maximum number of attempts for each transmission: */
112  static uint8_t get_max_attempts()
113  {
114  return 5;
115  };
118  /* Returns the recommended receive time for this strategy: */
120  static uint16_t get_receive_time()
121  {
122  return ETCP_RECEIVE_TIME;
123  };
126  /* Handle a collision (empty because handled on Ethernet level): */
128  void handle_collision() { };
131  /* Receive a frame: */
133  uint16_t receive_frame(uint8_t *data, uint16_t max_length)
134  {
135  // Register supplied buffer as target for EthernetLink callback function
136  incoming_packet_buf_ptr = data;
137  current_buffer_size = max_length;
138  incoming_packet_size = 0;
139
140  // Receive a packet
141  uint16_t result = link.receive();
143  // Forget about buffer and return result size
144  uint16_t received_packet_size = incoming_packet_size;
145  incoming_packet_buf_ptr = NULL;
146  incoming_packet_size = 0;
147
148  return result == PJON_ACK ? received_packet_size : PJON_FAIL;
149  }
150
151
152  /* Receive byte response */
154  uint16_t receive_response()
155  {
156  return last_send_result;
157  };
158
159
160  /* Send byte response to package transmitter */
161
162  void send_response(uint8_t /*response*/) // Empty, ACK is always sent
163  {
164  };
165
166
167  /* Send a frame: */
168
169  void send_frame(uint8_t *data, uint16_t length)
170  {
171  if(length > 0)
172  last_send_result =
173  link.send((uint8_t)data[0], (const uint8_t*)data, length);
174  };
175 };
Definition: MyMessage.h:655
EthernetTCP
Definition: EthernetTCP.h:32
