2.3.2-97-g788a030c
examples
GatewayESP32MQTTClient
GatewayESP32MQTTClient.ino
* Created by Henrik Ekblad <
[email protected]
* Copyright (C) 2013-2026 Sensnology AB
* REVISION HISTORY
* Version 1.0 - tekka
* The ESP32 gateway sends data received from sensors to the WiFi link.
* The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
* Make sure to fill in your ssid and WiFi password below.
#define MY_GATEWAY_ESP32
// Set this node's subscribe and publish topic prefix
// Set MQTT client id
// Enable these if your MQTT broker requires usenrame/password
//#define MY_MQTT_PASSWORD "password"
// Set WIFI SSID and password
#define MY_WIFI_SSID "MySSID"
// passed to the DHCP server if not static.
#define MY_HOSTNAME "ESP32_MQTT_GW"
// MQTT broker ip address.
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 5
// The MQTT broker port to to open
#define MY_PORT 1883
#include <
void
void
void
// Send locally attech sensors data here
Definition:
GatewayESP32MQTTClient.ino:86
Definition:
GatewayESP32MQTTClient.ino:81
Definition:
GatewayESP32MQTTClient.ino:76
