GatewayESP8266OTA.ino
21  * REVISION HISTORY
22  * Version 1.0 - Henrik Ekblad
23  * Contribution by tekka,
24  * Contribution by a-lurker and Anticimex,
25  * Contribution by Norbert Truchsess <[email protected]>
26  * Contribution by Ivo Pullens (ESP8266 support)
27  *
28  * DESCRIPTION
29  * The EthernetGateway sends data received from sensors to the WiFi link.
30  * The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
31  *
32  * VERA CONFIGURATION:
33  * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
34  * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
35  *
36  * LED purposes:
37  * - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
38  * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
39  * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
40  * - ERR (red) - fast blink on error during transmission error or receive crc error
41  *
42  * See https://www.mysensors.org/build/connect_radio for wiring instructions.
43  *
44  * If you are using a "barebone" ESP8266, see
45  * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
46  *
47  * Inclusion mode button:
48  * - Connect GPIO5 via switch to GND ('inclusion switch')
49  *
50  * Hardware SHA204 signing is currently not supported!
51  *
52  * Make sure to fill in your ssid and WiFi password below for ssid & pass.
53  */
55 // Enable debug prints to serial monitor
56 #define MY_DEBUG
58 // Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
59 #define MY_BAUD_RATE 9600
61 // Enables and select radio type (if attached)
62 #define MY_RADIO_RF24
63 //#define MY_RADIO_RFM69
64 //#define MY_RADIO_RFM95
66 #define MY_GATEWAY_ESP8266
68 #define MY_WIFI_SSID "MySSID"
69 #define MY_WIFI_PASSWORD "MyVerySecretPassword"
71 // Set the hostname for the WiFi Client. This is the hostname
72 // passed to the DHCP server if not static.
73 #define MY_HOSTNAME "ESP8266_GW"
75 // Enable UDP communication
76 //#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
78 // Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
79 //#define MY_IP_ADDRESS 192,168,178,87
81 // If using static ip you can define Gateway and Subnet address as well
82 //#define MY_IP_GATEWAY_ADDRESS 192,168,178,1
83 //#define MY_IP_SUBNET_ADDRESS 255,255,255,0
85 // The port to keep open on node server mode
86 #define MY_PORT 5003
88 // How many clients should be able to connect to this gateway (default 1)
89 #define MY_GATEWAY_MAX_CLIENTS 2
91 // Controller ip address. Enables client mode (default is "server" mode).
92 // Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere.
93 //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
95 // Enable inclusion mode
96 #define MY_INCLUSION_MODE_FEATURE
98 // Enable Inclusion mode button on gateway
99 //#define MY_INCLUSION_BUTTON_FEATURE
100 // Set inclusion mode duration (in seconds)
101 #define MY_INCLUSION_MODE_DURATION 60
102 // Digital pin used for inclusion mode button
103 #define MY_INCLUSION_MODE_BUTTON_PIN 3
105 // Set blinking period
106 // #define MY_DEFAULT_LED_BLINK_PERIOD 300
108 // Flash leds on rx/tx/err
109 // Led pins used if blinking feature is enabled above
110 #define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
111 #define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
112 #define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
114 #include <ArduinoOTA.h>
115 #include <MySensors.h>
117 void setup()
118 {
119  // Setup locally attached sensors
120  ArduinoOTA.onStart([]() {
121  Serial.println("ArduinoOTA start");
122  });
123  ArduinoOTA.onEnd([]() {
124  Serial.println("\nArduinoOTA end");
125  });
126  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
127  Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
128  });
129  ArduinoOTA.onError([](ota_error_t error) {
130  Serial.printf("Error[%u]: ", error);
131  if (error == OTA_AUTH_ERROR) {
132  Serial.println("Auth Failed");
133  } else if (error == OTA_BEGIN_ERROR) {
134  Serial.println("Begin Failed");
135  } else if (error == OTA_CONNECT_ERROR) {
136  Serial.println("Connect Failed");
137  } else if (error == OTA_RECEIVE_ERROR) {
138  Serial.println("Receive Failed");
139  } else if (error == OTA_END_ERROR) {
140  Serial.println("End Failed");
141  }
142  });
143  ArduinoOTA.begin();
144 }
145
147 {
148  // Present locally attached sensors here
149 }
150
151 void loop()
152 {
153  // Send locally attached sensors data here
154  ArduinoOTA.handle();
155 }
156
Definition: GatewayESP8266OTA.ino:151
Definition: GatewayESP8266OTA.ino:146
Definition: GatewayESP8266OTA.ino:117
