2.3.2-121-g2834d0f8
examples
GatewayESP8266SecureMQTTClient
GatewayESP8266SecureMQTTClient.ino
* Created by Henrik Ekblad <
[email protected]
* Copyright (C) 2013-2026 Sensnology AB
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
* The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
* LED purposes:
* - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
* See https://www.mysensors.org/build/connect_radio for wiring instructions.
* If you are using a "barebone" ESP8266, see
* https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
* Inclusion mode button:
* - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
* SSL support by Eric Grammatico. You should have an updated version of MyGatewayTransportMQTTClient.cpp.
* Please see: https://forum.mysensors.org/topic/11941/esp8266-mqtt-gateway-ssl-connection
* The following constants have to be defined from the gateway code:
* MY_GATEWAY_ESP8266_SECURE In place of MY_GATEWAY_ESP8266 to go to secure connexions.
* MY_MQTT_CA_CERTx Up to three root Certificates Authorities could be defined
* to validate the mqtt server' certificate. The most secure.
* MY_MQTT_CA_CERT is deprecated and MY_MQTT_CA_CERT1 should
* be used instead.
* MY_MQTT_FINGERPRINT Alternatively, the mqtt server' certificate finger print
* could be used. Less secure and less convenient as you'll
* have to update the fingerprint each time the mqtt server'
* certificate is updated
* If neither MY_MQTT_CA_CERT1 nor MY_MQTT_FINGERPRINT are
* defined, insecure connexion will be established. The mqtt
* server' certificate will not be validated.
* MY_MQTT_CLIENT_CERT The mqtt server may require client certificate for
* MY_MQTT_CLIENT_KEY authentication.
* The certs.h file holds the mqtt server' fingerprint and root Certificate Authorities and
* client certificate and key. This a sample how to populate MY_MQTT_CA_CERTx, MY_MQTT_FINGERPRINT,
* MY_MQTT_CLIENT_CERT and MY_MQTT_CLIENT_KEY.
// Imports certificates and client key
#include "certs.h"
* MySensors node configuration
// General settings
#define SKETCH_NAME "MySensorsMQTTGW_Secure"
#define SKETCH_VERSION "0.6"
#define MY_NODE_ID 1
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
//#define MY_RF24_PA_LEVEL RF24_PA_LOW
* Secured connexion with ESP8266
#define MY_GATEWAY_ESP8266_SECURE
//** Set WIFI SSID and password
#define MY_WIFI_SSID "ssid"
#define MY_WIFI_PASSWORD "password"
//** Set the hostname for the WiFi Client. This is the hostname
// passed to the DHCP server if not static.
#define MY_HOSTNAME "esp8266-gw"
//** Certificate Authorities. One or two should be enough
#define MY_MQTT_CA_CERT1 cert_isrgrootx1_Authority
#define MY_MQTT_CA_CERT2 cert_isrgrootx2_Authority
//#define MY_MQTT_CA_CERT3 cert_letsEncryptR3_Authority
//** Server certificate validation with its fingerprint
// less secure and less convenient than with Certificate
// Authorities as server certificates are updated often.
// Will not be used if MY_MQTT_CA_CERT1 defined.
#define MY_MQTT_FINGERPRINT mqtt_fingerprint
123
//** The mqtt server may require client certificate for
// authentication.
#define MY_MQTT_CLIENT_CERT cert_client
126
#define MY_MQTT_CLIENT_KEY key_client
128
* MQTT_CLIENT configuration
131
133
134
//** MQTT broker if using URL instead of ip address.
// should correspond to the CN field in the mqtt server'
// certificate.
#define MY_CONTROLLER_URL_ADDRESS mqtt_host
138
139
//** The MQTT broker port to open
140
#define MY_PORT mqtt_port
141
//** Enable these if your MQTT broker requires username/password
143
//#define MY_MQTT_USER "<mqtt-user>"
144
//#define MY_MQTT_PASSWORD "<mqtt-passwd>"
145
//** Set MQTT client id
146
//#define MY_MQTT_CLIENT_ID "<mqtt-userID>"
147
148
//** Set this node's subscribe and publish topic prefix
149
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "esp8266-gw/out"
150
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "esp8266-gw/in"
151
152
// Enable inclusion mode
154
155
156
157
158
//#define MY_INCLUSION_MODE_DURATION 60
159
160
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
161
162
// Set blinking period
163
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
164
165
// Flash leds on rx/tx/err
166
167
168
169
170
#include <
171
172
void
173
174
175
// In order to speed up certs and keys verifications
176
system_update_cpu_freq(160);
177
178
179
180
void
182
183
184
185
186
void
187
188
189
190
Definition:
GatewayESP8266SecureMQTTClient.ino:186
Definition:
GatewayESP8266SecureMQTTClient.ino:181
Definition:
GatewayESP8266SecureMQTTClient.ino:172
