2.3.2-121-g2834d0f8
examples
GatewayW5100MQTTClient
GatewayW5100MQTTClient.ino
* Created by Henrik Ekblad <
[email protected]
* Copyright (C) 2013-2026 Sensnology AB
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
* The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
* LED purposes:
* - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
* See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
* nRF24L01+ ESP8266
* VCC VCC
* CE GPIO4
* CSN/CS GPIO15
* SCK GPIO14
* MISO GPIO12
* MOSI GPIO13
* Not all ESP8266 modules have all pins available on their external interface.
* This code has been tested on an ESP-12 module.
* The ESP8266 requires a certain pin configuration to download code, and another one to run code:
* - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch')
* - Connect GPIO15 via 10K pulldown resistor to GND
* - Connect CH_PD via 10K resistor to VCC
* - Connect GPIO2 via 10K resistor to VCC
* - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch')
* Inclusion mode button:
* - Connect GPIO5 via switch to GND ('inclusion switch')
//#define MY_PJON
// Set this node's subscribe and publish topic prefix
// Set MQTT client id
// W5100 Ethernet module SPI enable (optional if using a shield/module that manages SPI_EN signal)
//#define MY_W5100_SPI_EN 4
// Enable Soft SPI for NRF radio (note different radio wiring is required)
// The W5100 ethernet module seems to have a hard time co-operate with
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#define MY_SOFT_SPI_SCK_PIN 14
#define MY_SOFT_SPI_MISO_PIN 16
#define MY_SOFT_SPI_MOSI_PIN 15
// When W5100 is connected we have to move CE/CSN pins for NRF radio
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
// Enable these if your MQTT broker requires username/password
//#define MY_MQTT_PASSWORD "password"
#define MY_IP_ADDRESS 192,168,178,87
// MQTT broker ip address or url. Define one or the other.
//#define MY_CONTROLLER_URL_ADDRESS "m20.cloudmqtt.com"
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
// The MQTT broker port to to open
#define MY_PORT 1883
// Enable inclusion mode
123
126
//#define MY_INCLUSION_MODE_BUTTON_PIN 3
128
// Set blinking period
131
// Flash leds on rx/tx/err
133
134
138
#include <Ethernet.h>
139
#include <
140
141
void
143
144
145
146
void
147
148
149
150
151
void
152
154
155
Definition:
GatewayW5100MQTTClient.ino:151
Definition:
GatewayW5100MQTTClient.ino:146
Definition:
GatewayW5100MQTTClient.ino:141
