MyMultiMessage.h
15  * Multi message feature added by Constantin Petra <[email protected]>
16  * Copyright (C) 2022 Constantin Petra
17  *
18  * This program is free software; you can redistribute it and/or
19  * modify it under the terms of the GNU General Public License
20  * version 2 as published by the Free Software Foundation.
21  */
90 #ifndef MYMULTIMESSAGE_H
91 #define MYMULTIMESSAGE_H
92 #include "MyMessage.h"
98 {
99 private:
100  // A pointer to the "real" message
101  MyMessage *_msg;
103  // Current offset inside the message
104  size_t _offset;
106  // Common setup, returns a pointer to the next area that can be used, NULL if no more room
107  void *common(uint8_t type, uint8_t sensor, uint8_t ptype, uint8_t size, uint8_t cmd);
109 public:
114  explicit MyMultiMessage(MyMessage *msg);
123  bool set(uint8_t messageType, uint8_t sensorId, uint8_t value);
132  bool set(uint8_t messageType, uint8_t sensorId, uint16_t value);
133
141  bool set(uint8_t messageType, uint8_t sensorId, int16_t value);
151  bool set(uint8_t messageType, uint8_t sensorId, uint32_t value);
152
160  bool set(uint8_t messageType, uint8_t sensorId, int32_t value);
161
170  bool set(uint8_t messageType, uint8_t sensorId, float value, uint8_t decimals);
171
175  void reset();
176
181  bool setBattery(uint8_t value);
182
187  bool getNext(MyMessage &m);
188
189  ~MyMultiMessage();
190
191 };
192 #endif
type
uint8_t type
Definition: MyMessage.h:353
sensor
uint8_t sensor
Definition: MyMessage.h:354
MyMultiMessage::setBattery
Set battery level.
MyMultiMessage::reset
void reset()
Reset the message contents, so that in can be reused after send()
MyMultiMessage
A collection of APIs that convert a MyMessage object to a message group.
Definition: MyMultiMessage.h:97
MyMessage.h
API and type declarations for MySensors messages.
MyMultiMessage::set
Set payload to unsigned 8-bit integer value.
MyMultiMessage::MyMultiMessage
Definition: MyMessage.h:290
MyMultiMessage::getNext
get next message from the blob
