RF24.h
2 * The MySensors Arduino library handles the wireless radio link and protocol
3 * between your home built sensors/actuators and HA controller of choice.
4 * The sensors forms a self healing radio network with optional repeaters. Each
5 * repeater and gateway builds a routing tables in EEPROM which keeps track of the
6 * network topology allowing messages to be routed to nodes.
7 *
8 * Created by Henrik Ekblad <[email protected]>
9 * Copyright (C) 2013-2026 Sensnology AB
10 * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
11 *
12 * Documentation: http://www.mysensors.org
13 * Support Forum: http://forum.mysensors.org
14 *
15 * This program is free software; you can redistribute it and/or
16 * modify it under the terms of the GNU General Public License
17 * version 2 as published by the Free Software Foundation.
18 *
19 * Based on maniacbug's RF24 library, copyright (C) 2011 J. Coliz <[email protected]>
20 * RF24 driver refactored and optimized for speed and size, copyright (C) 2017 Olivier Mauti <[email protected]>
21 *
22 * Definitions for Nordic nRF24L01+ radios:
23 * https://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01P
24 *
25 */
59 #ifndef __RF24_H__
60 #define __RF24_H__
62 #include "RF24registers.h"
64 #if !defined(RF24_SPI)
65 #define RF24_SPI hwSPI
66 #endif
68 #if defined(ARDUINO_ARCH_AVR)
69 #define DEFAULT_RF24_CE_PIN (9)
70 #elif defined(ARDUINO_ARCH_ESP8266)
71 #define DEFAULT_RF24_CE_PIN (4)
72 #elif defined(ARDUINO_ARCH_ESP32)
73 #define DEFAULT_RF24_CE_PIN (17)
74 #elif defined(ARDUINO_ARCH_SAMD)
75 #define DEFAULT_RF24_CE_PIN (27)
76 #elif defined(LINUX_ARCH_RASPBERRYPI)
77 #define DEFAULT_RF24_CE_PIN (22)
78 //#define DEFAULT_RF24_CS_PIN (24)
79 #elif defined(ARDUINO_ARCH_STM32)
80 #define DEFAULT_RF24_CE_PIN (PB0)
81 #elif defined(TEENSYDUINO)
82 #define DEFAULT_RF24_CE_PIN (9)
83 #else
84 #define DEFAULT_RF24_CE_PIN (9)
85 #endif
87 #define DEFAULT_RF24_CS_PIN (SS)
90 #define LOCAL static
92 // SPI settings
93 #define RF24_SPI_DATA_ORDER MSBFIRST
94 #define RF24_SPI_DATA_MODE SPI_MODE0
96 #define RF24_BROADCAST_ADDRESS (255u)
98 // verify RF24 IRQ defs
99 #if defined(MY_RX_MESSAGE_BUFFER_FEATURE)
100 #if !defined(MY_RF24_IRQ_PIN)
101 #error Message buffering feature requires MY_RF24_IRQ_PIN to be defined!
102 #endif
103 // SoftSPI does not support usingInterrupt()
104 #ifdef MY_SOFTSPI
105 #error RF24 IRQ usage cannot be used with Soft SPI
106 #endif
107 // ESP8266 does not support usingInterrupt()
108 #ifdef ARDUINO_ARCH_ESP8266
109 #error RF24 IRQ usage cannot be used with ESP8266
110 #endif
111 #ifndef SPI_HAS_TRANSACTION
112 #error RF24 IRQ usage requires transactional SPI support
113 #endif
114 #else
115 #ifdef MY_RX_MESSAGE_BUFFER_SIZE
116 #error Receive message buffering requires RF24 IRQ usage
117 #endif
118 #endif
121 // RF24 settings
122 #if defined(MY_RX_MESSAGE_BUFFER_FEATURE)
123 #define RF24_CONFIGURATION (uint8_t) ((RF24_CRC_16 << 2) | (1 << RF24_MASK_TX_DS) | (1 << RF24_MASK_MAX_RT))
124 #else
125 #define RF24_CONFIGURATION (uint8_t) (RF24_CRC_16 << 2)
126 #endif
127 #define RF24_FEATURE (uint8_t)( _BV(RF24_EN_DPL))
128 #define RF24_RF_SETUP (uint8_t)(( ((MY_RF24_DATARATE & 0b10 ) << 4) | ((MY_RF24_DATARATE & 0b01 ) << 3) | (MY_RF24_PA_LEVEL << 1) ) + 1)
130 // powerup delay
131 #define RF24_POWERUP_DELAY_MS (100u)
133 // pipes
134 #define RF24_BROADCAST_PIPE (1u)
135 #define RF24_NODE_PIPE (0u)
137 // functions
142 LOCAL void RF24_csn(const bool level);
147 LOCAL void RF24_ce(const bool level);
156 LOCAL uint8_t RF24_spiMultiByteTransfer(const uint8_t cmd, uint8_t *buf, const uint8_t len,
157  const bool readMode);
163 LOCAL uint8_t RF24_spiByteTransfer(const uint8_t cmd);
169 LOCAL uint8_t RF24_RAW_readByteRegister(const uint8_t cmd);
176 LOCAL uint8_t RF24_RAW_writeByteRegister(const uint8_t cmd, const uint8_t value);
177
178 // helper macros
179 #define RF24_readByteRegister(__reg) RF24_RAW_readByteRegister(RF24_CMD_READ_REGISTER | (RF24_REGISTER_MASK & (__reg)))
180 #define RF24_readMultiByteRegister(__reg,__buf,__len) RF24_spiMultiByteTransfer(RF24_CMD_READ_REGISTER | (RF24_REGISTER_MASK & (__reg)), (uint8_t *)__buf, __len, true)
181 #define RF24_writeByteRegister(__reg,__value) RF24_RAW_writeByteRegister(RF24_CMD_WRITE_REGISTER | (RF24_REGISTER_MASK & (__reg)), __value)
182 #define RF24_writeMultiByteRegister(__reg,__buf,__len) RF24_spiMultiByteTransfer(RF24_CMD_WRITE_REGISTER | (RF24_REGISTER_MASK & (__reg)), (uint8_t *)__buf, __len, false)
183
184
187 LOCAL void RF24_flushRX(void);
191 LOCAL void RF24_flushTX(void);
196 LOCAL uint8_t RF24_getStatus(void);
201 LOCAL uint8_t RF24_getFIFOStatus(void) __attribute__((unused));
206 LOCAL void RF24_openWritingPipe(const uint8_t recipient);
210 LOCAL void RF24_startListening(void);
214 LOCAL void RF24_stopListening(void);
218 LOCAL void RF24_sleep(void);
222 LOCAL void RF24_standBy(void);
226 LOCAL void RF24_powerDown(void);
230 LOCAL void RF24_powerUp(void);
239 LOCAL bool RF24_sendMessage(const uint8_t recipient, const void *buf, const uint8_t len,
240  const bool noACK = false);
245 LOCAL uint8_t RF24_getDynamicPayloadSize(void);
250 LOCAL bool RF24_isDataAvailable(void);
255 LOCAL uint8_t RF24_readMessage(void *buf);
260 LOCAL void RF24_setNodeAddress(const uint8_t address);
265 LOCAL uint8_t RF24_getNodeID(void);
270 LOCAL bool RF24_sanityCheck(void);
275 LOCAL bool RF24_initialize(void);
280 LOCAL void RF24_setChannel(const uint8_t channel);
285 LOCAL uint8_t RF24_getChannel(void) __attribute__((unused));
291 LOCAL void RF24_setRetries(const uint8_t retransmitDelay, const uint8_t retransmitCount);
296 LOCAL void RF24_setAddressWidth(const uint8_t addressWidth);
301 LOCAL void RF24_setRFSetup(const uint8_t RFsetup);
306 LOCAL void RF24_setFeature(const uint8_t feature);
311 LOCAL uint8_t RF24_getFeature(void);
316 LOCAL void RF24_setPipe(const uint8_t pipe);
321 LOCAL void RF24_setAutoACK(const uint8_t pipe);
326 LOCAL void RF24_setDynamicPayload(const uint8_t pipe);
331 LOCAL uint8_t RF24_getRFConfiguration(void) __attribute__((unused));
336 LOCAL void RF24_setRFConfiguration(const uint8_t configuration);
343 LOCAL void RF24_setPipeAddress(const uint8_t pipe, uint8_t *address, const uint8_t addressWidth);
349 LOCAL void RF24_setPipeLSB(const uint8_t pipe, const uint8_t LSB);
354 LOCAL uint8_t RF24_getObserveTX(void);
360 LOCAL uint8_t RF24_setStatus(const uint8_t status);
364 LOCAL void RF24_enableFeatures(void);
369 LOCAL uint8_t RF24_getTxPowerPercent(void);
374 LOCAL uint8_t RF24_getRawTxPowerLevel(void);
379 LOCAL int16_t RF24_getTxPowerLevel(void);
385 LOCAL bool RF24_setTxPowerPercent(const uint8_t newPowerPercent);
390 LOCAL int16_t RF24_getSendingRSSI(void);
404
405 #if defined(MY_RX_MESSAGE_BUFFER_FEATURE)
406
409 typedef void (*RF24_receiveCallbackType)(void);
418 LOCAL void RF24_registerReceiveCallback(RF24_receiveCallbackType cb);
419 #endif
420
421 #endif // __RF24_H__
422
RF24_ce
RF24_ce.
RF24_getRFConfiguration.
RF24_setRFSetup
RF24_setRFSetup.
RF24_getReceivedPowerDetector
LOCAL bool RF24_getReceivedPowerDetector(void) __attribute__((unused))
Retrieve latched RPD power level, in receive mode (for testing, nRF24L01+ only).
RF24_powerDown
RF24_powerDown.
RF24_powerUp
RF24_powerUp.
RF24_getChannel
RF24_getChannel.
RF24_getDynamicPayloadSize.
RF24_setFeature
RF24_setFeature.
RF24_RAW_readByteRegister.
RF24_getNodeID
RF24_getNodeID.
RF24_enableConstantCarrierWave
LOCAL void RF24_enableConstantCarrierWave(void) __attribute__((unused))
Generate a constant carrier wave at active channel & transmit power (for testing only).
RF24_getRawTxPowerLevel.
RF24_getStatus
RF24_getStatus.
RF24_stopListening
RF24_stopListening.
RF24_sendMessage
LOCAL bool RF24_sendMessage(const uint8_t recipient, const void *buf, const uint8_t len, const bool noACK=false)
RF24_sendMessage.
RF24_getSendingRSSI
RF24_getSendingRSSI.
RF24_setAddressWidth.
RF24_getFIFOStatus
RF24_getFIFOStatus.
RF24_setRFConfiguration.
RF24_setRetries
RF24_setRetries.
RF24_initialize
RF24_initialize.
RF24_getTxPowerPercent.
RF24_enableFeatures
RF24_enableFeatures.
RF24_sleep
RF24_sleep.
__attribute__
struct @4::@5 __attribute__
Definition: DigitalPin.h:65
RF24_getObserveTX
RF24_getObserveTX.
RF24_openWritingPipe.
RF24_setDynamicPayload.
RF24_flushTX
RF24_flushTX.
RF24_startListening
RF24_startListening.
LOCAL uint8_t RF24_spiMultiByteTransfer(const uint8_t cmd, uint8_t *buf, const uint8_t len, const bool readMode)
RF24_spiMultiByteTransfer.
RF24_RAW_writeByteRegister.
RF24_setPipeAddress
RF24_setPipeAddress.
RF24_getFeature
RF24_getFeature.
RF24_setTxPowerPercent.
RF24_setPipe
RF24_setPipe.
RF24_isDataAvailable.
RF24_setChannel
RF24_setChannel.
RF24_setPipeLSB
RF24_setPipeLSB.
RF24_setNodeAddress
RF24_setNodeAddress.
RF24_disableConstantCarrierWave
LOCAL void RF24_disableConstantCarrierWave(void) __attribute__((unused))
Stop generating a constant carrier wave (for testing only).
RF24_setAutoACK
RF24_setAutoACK.
LOCAL
#define LOCAL
static
Definition: RF24.h:90
RF24_standBy
RF24_standBy.
RF24_setStatus
RF24_setStatus.
RF24_flushRX
RF24_flushRX.
RF24_readMessage
RF24_readMessage.
RF24_getTxPowerLevel.
RF24_sanityCheck
RF24_sanityCheck.
RF24_csn
RF24_csn.
RF24_spiByteTransfer.
