Macros | Functions
+ Collaboration diagram for RF24:
RF24 driver-related log messages, format: [!]SYSTEM:[SUB SYSTEM:]MESSAGE
E SYS SUB Message Comment
RF24 INIT PIN,CE=%d,CS=%d Initialise RF24 radio, pin configuration: chip enable (CE), chip select (CS)
! RF24 INIT SANCHK FAIL Sanity check failed, check wiring or replace module
RF24 SPP PCT=%d,TX LEVEL=%d Set TX level, input TX percent (PCT)
RF24 RBR REG=%d,VAL=%d Read register (REG), value=(VAL)
RF24 WBR REG=%d,VAL=%d Write register (REG), value=(VAL)
RF24 FRX Flush RX buffer
RF24 FTX Flush TX buffer
RF24 OWP RCPT=%d Open writing pipe, recipient=(RCPT)
RF24 STL Start listening
RF24 SPL Stop listening
RF24 SLP Set radio to sleep
RF24 SBY Set radio to standby
RF24 TXM TO=%d,LEN=%d Transmit message to=(TO), length=(LEN)
! RF24 TXM MAX_RT Max TX retries, no ACK received
! RF24 GDP PYL INV Invalid payload size
RF24 RXM LEN=%d Read message, length=(LEN)
RF24 STX LEVEL=%d Set TX level, level=(LEVEL)
#define RF24_SPI   hwSPI
 default SPI
#define DEFAULT_RF24_CE_PIN   (9)
 DEFAULT_RF24_CE_PIN.
#define DEFAULT_RF24_CS_PIN   (SS)
 DEFAULT_RF24_CS_PIN.
#define LOCAL   static
 static
#define RF24_SPI_DATA_ORDER   MSBFIRST
 RF24_SPI_DATA_ORDER.
#define RF24_SPI_DATA_MODE   SPI_MODE0
 RF24_SPI_DATA_MODE.
#define RF24_BROADCAST_ADDRESS   (255u)
 RF24_BROADCAST_ADDRESS.
#define RF24_CONFIGURATION   (uint8_t) (RF24_CRC_16 << 2)
 RF24_CONFIGURATION.
#define RF24_FEATURE   (uint8_t)( _BV(RF24_EN_DPL))
 RF24_FEATURE.
#define RF24_RF_SETUP   (uint8_t)(( ((MY_RF24_DATARATE & 0b10 ) << 4) | ((MY_RF24_DATARATE & 0b01 ) << 3) | (MY_RF24_PA_LEVEL << 1) ) + 1)
 RF24_RF_SETUP, +1 for Si24R1 and LNA.
#define RF24_POWERUP_DELAY_MS   (100u)
 Power up delay, allow VCC to settle, transport to become fully operational.
#define RF24_BROADCAST_PIPE   (1u)
 RF24_BROADCAST_PIPE.
#define RF24_NODE_PIPE   (0u)
 RF24_NODE_PIPE.
#define RF24_readByteRegister(__reg)   RF24_RAW_readByteRegister(RF24_CMD_READ_REGISTER | (RF24_REGISTER_MASK & (__reg)))
 RF24_readByteRegister.
#define RF24_writeByteRegister(__reg, __value)   RF24_RAW_writeByteRegister(RF24_CMD_WRITE_REGISTER | (RF24_REGISTER_MASK & (__reg)), __value)
 RF24_writeByteRegister.
#define RF24_writeMultiByteRegister(__reg, __buf, __len)   RF24_spiMultiByteTransfer(RF24_CMD_WRITE_REGISTER | (RF24_REGISTER_MASK & (__reg)),(uint8_t *)__buf, __len,false)
 RF24_writeMultiByteRegister.
LOCAL void RF24_csn (const bool level)
 RF24_csn. More...
LOCAL void RF24_ce (const bool level)
 RF24_ce. More...
LOCAL uint8_t RF24_spiMultiByteTransfer (const uint8_t cmd, uint8_t *buf, const uint8_t len, const bool readMode)
 RF24_spiMultiByteTransfer. More...
LOCAL uint8_t RF24_spiByteTransfer (const uint8_t cmd)
 RF24_spiByteTransfer. More...
LOCAL uint8_t RF24_RAW_readByteRegister (const uint8_t cmd)
 RF24_RAW_readByteRegister. More...
LOCAL uint8_t RF24_RAW_writeByteRegister (const uint8_t cmd, const uint8_t value)
 RF24_RAW_writeByteRegister. More...
LOCAL void RF24_flushRX (void)
 RF24_flushRX.
LOCAL void RF24_flushTX (void)
 RF24_flushTX.
LOCAL uint8_t RF24_getStatus (void)
 RF24_getStatus. More...
LOCAL uint8_t RF24_getFIFOStatus (void) __attribute__((unused))
 RF24_getFIFOStatus. More...
LOCAL void RF24_openWritingPipe (const uint8_t recipient)
 RF24_openWritingPipe. More...
LOCAL void RF24_startListening (void)
 RF24_startListening.
LOCAL void RF24_stopListening (void)
 RF24_stopListening.
LOCAL void RF24_sleep (void)
 RF24_sleep.
LOCAL void RF24_standBy (void)
 RF24_standBy.
LOCAL void RF24_powerDown (void)
 RF24_powerDown.
LOCAL void RF24_powerUp (void)
 RF24_powerUp.
LOCAL bool RF24_sendMessage (const uint8_t recipient, const void *buf, const uint8_t len, const bool noACK=false)
 RF24_sendMessage. More...
LOCAL uint8_t RF24_getDynamicPayloadSize (void)
 RF24_getDynamicPayloadSize. More...
LOCAL bool RF24_isDataAvailable (void)
 RF24_isDataAvailable. More...
LOCAL uint8_t RF24_readMessage (void *buf)
 RF24_readMessage. More...
LOCAL void RF24_setNodeAddress (const uint8_t address)
 RF24_setNodeAddress. More...
LOCAL uint8_t RF24_getNodeID (void)
 RF24_getNodeID. More...
LOCAL bool RF24_sanityCheck (void)
 RF24_sanityCheck. More...
LOCAL bool RF24_initialize (void)
 RF24_initialize. More...
LOCAL void RF24_setChannel (const uint8_t channel)
 RF24_setChannel. More...
LOCAL void RF24_setRetries (const uint8_t retransmitDelay, const uint8_t retransmitCount)
 RF24_setRetries. More...
LOCAL void RF24_setAddressWidth (const uint8_t addressWidth)
 RF24_setAddressWidth. More...
LOCAL void RF24_setRFSetup (const uint8_t RFsetup)
 RF24_setRFSetup. More...
LOCAL void RF24_setFeature (const uint8_t feature)
 RF24_setFeature. More...
LOCAL uint8_t RF24_getFeature (void)
 RF24_getFeature. More...
LOCAL void RF24_setPipe (const uint8_t pipe)
 RF24_setPipe. More...
LOCAL void RF24_setAutoACK (const uint8_t pipe)
 RF24_setAutoACK. More...
LOCAL void RF24_setDynamicPayload (const uint8_t pipe)
 RF24_setDynamicPayload. More...
LOCAL void RF24_setRFConfiguration (const uint8_t configuration)
 RF24_setRFConfiguration. More...
LOCAL void RF24_setPipeAddress (const uint8_t pipe, uint8_t *address, const uint8_t addressWidth)
 RF24_setPipeAddress. More...
LOCAL void RF24_setPipeLSB (const uint8_t pipe, const uint8_t LSB)
 RF24_setPipeLSB. More...
LOCAL uint8_t RF24_getObserveTX (void)
 RF24_getObserveTX. More...
LOCAL uint8_t RF24_setStatus (const uint8_t status)
 RF24_setStatus. More...
LOCAL void RF24_enableFeatures (void)
 RF24_enableFeatures.
LOCAL uint8_t RF24_getTxPowerPercent (void)
 RF24_getTxPowerPercent. More...
LOCAL int16_t RF24_getTxPowerLevel (void)
 RF24_getTxPowerLevel. More...
LOCAL bool RF24_setTxPowerPercent (const uint8_t newPowerPercent)
 RF24_setTxPowerPercent. More...
LOCAL int16_t RF24_getSendingRSSI (void)
 RF24_getSendingRSSI. More...
LOCAL void RF24_enableConstantCarrierWave (void) __attribute__((unused))
 Generate a constant carrier wave at active channel & transmit power (for testing only).
LOCAL void RF24_disableConstantCarrierWave (void) __attribute__((unused))
 Stop generating a constant carrier wave (for testing only).
LOCAL bool RF24_getReceivedPowerDetector (void) __attribute__((unused))
 Retrieve latched RPD power level, in receive mode (for testing, nRF24L01+ only). More...
◆ RF24_ce()
LOCAL void RF24_ce ( const bool  level)
RF24_ce.
level
◆ RF24_csn()
LOCAL void RF24_csn ( const bool  level)
RF24_csn.
level
◆ RF24_getDynamicPayloadSize()
LOCAL uint8_t RF24_getDynamicPayloadSize ( void  )
Returns
◆ RF24_getFeature()
LOCAL uint8_t RF24_getFeature ( void  )
RF24_getFeature.
Returns
◆ RF24_getFIFOStatus()
LOCAL uint8_t RF24_getFIFOStatus ( void  )
RF24_getFIFOStatus.
Returns
◆ RF24_getNodeID()
LOCAL uint8_t RF24_getNodeID ( void  )
RF24_getNodeID.
Returns
◆ RF24_getObserveTX()
LOCAL uint8_t RF24_getObserveTX ( void  )
RF24_getObserveTX.
Returns
◆ RF24_getReceivedPowerDetector()
LOCAL bool RF24_getReceivedPowerDetector ( void  )
Returns
True when power level >-64dBm for more than 40us.
◆ RF24_getSendingRSSI()
LOCAL int16_t RF24_getSendingRSSI ( void  )
Returns
Pseudo-RSSI based on ARC register
◆ RF24_getStatus()
LOCAL uint8_t RF24_getStatus ( void  )
RF24_getStatus.
Returns
◆ RF24_getTxPowerLevel()
LOCAL int16_t RF24_getTxPowerLevel ( void  )
Returns
◆ RF24_getTxPowerPercent()
LOCAL uint8_t RF24_getTxPowerPercent ( void  )
Returns
◆ RF24_initialize()
LOCAL bool RF24_initialize ( void  )
RF24_initialize.
Returns
◆ RF24_isDataAvailable()
LOCAL bool RF24_isDataAvailable ( void  )
Returns
◆ RF24_openWritingPipe()
LOCAL void RF24_openWritingPipe ( const uint8_t  recipient)
recipient
◆ RF24_RAW_readByteRegister()
LOCAL uint8_t RF24_RAW_readByteRegister ( const uint8_t  cmd)
cmd
Returns
◆ RF24_RAW_writeByteRegister()
LOCAL uint8_t RF24_RAW_writeByteRegister ( const uint8_t  cmd,
const uint8_t  value
cmd
value
Returns
◆ RF24_readMessage()
LOCAL uint8_t RF24_readMessage ( void *  buf)
RF24_readMessage.
Returns
◆ RF24_sanityCheck()
LOCAL bool RF24_sanityCheck ( void  )
RF24_sanityCheck.
Returns
◆ RF24_sendMessage()
LOCAL bool RF24_sendMessage ( const uint8_t  recipient,
const void *  buf,
const uint8_t  len,
const bool  noACK = false
RF24_sendMessage.
recipient
buf
len
noACKset True if no ACK is required
Returns
◆ RF24_setAddressWidth()
LOCAL void RF24_setAddressWidth ( const uint8_t  addressWidth)
addressWidth
◆ RF24_setAutoACK()
LOCAL void RF24_setAutoACK ( const uint8_t  pipe)
RF24_setAutoACK.
pipe
◆ RF24_setChannel()
LOCAL void RF24_setChannel ( const uint8_t  channel)
RF24_setChannel.
channel
◆ RF24_setDynamicPayload()
LOCAL void RF24_setDynamicPayload ( const uint8_t  pipe)
pipe
◆ RF24_setFeature()
LOCAL void RF24_setFeature ( const uint8_t  feature)
RF24_setFeature.
feature
◆ RF24_setNodeAddress()
LOCAL void RF24_setNodeAddress ( const uint8_t  address)
address
◆ RF24_setPipe()
LOCAL void RF24_setPipe ( const uint8_t  pipe)
RF24_setPipe.
pipe
◆ RF24_setPipeAddress()
LOCAL void RF24_setPipeAddress ( const uint8_t  pipe,
uint8_t *  address,
pipe
address
addressWidth
◆ RF24_setPipeLSB()
LOCAL void RF24_setPipeLSB ( const uint8_t  pipe,
const uint8_t  LSB
RF24_setPipeLSB.
pipe
LSB
◆ RF24_setRetries()
LOCAL void RF24_setRetries ( const uint8_t  retransmitDelay,
RF24_setRetries.
retransmitDelay
retransmitCount
◆ RF24_setRFConfiguration()
LOCAL void RF24_setRFConfiguration ( const uint8_t  configuration)
configuration
◆ RF24_setRFSetup()
LOCAL void RF24_setRFSetup ( const uint8_t  RFsetup)
RF24_setRFSetup.
RFsetup
◆ RF24_setStatus()
LOCAL uint8_t RF24_setStatus ( const uint8_t  status)
RF24_setStatus.
status
Returns
status byte before setting new status
◆ RF24_setTxPowerPercent()
LOCAL bool RF24_setTxPowerPercent ( const uint8_t  newPowerPercent)
newPowerPercent
Returns
◆ RF24_spiByteTransfer()
LOCAL uint8_t RF24_spiByteTransfer ( const uint8_t  cmd)
cmd
Returns
◆ RF24_spiMultiByteTransfer()
LOCAL uint8_t RF24_spiMultiByteTransfer ( const uint8_t  cmd,
uint8_t *  buf,
const uint8_t  len,
const bool  readMode
cmd
buf
len
readMode
Returns
